02-17-2021, 21:15 | #752 (permalink) |
Freak Poster Join Date: Feb 2014 Location: MEA Age: 30
Member: 2119579 Status: Offline Thanks Meter: 44 | Seems that you used "Format All + Download" function? (using SP Flash Tool) If so, you have to write developer firmware or eng firmware then repair using META mode and for some reason only IMEI 2 can accept the repair process, as may give you "NV Data corrupted" while phone boots up if you repaired both IMEI. If you did only "Download only" function, then check your baseband if it's unknown or has value. If it has value you have to use META mode as mentioned above If it doesn't have value then format NVRAM area from SP Flash Tool as the address in scatter file. Hope that solves your issue ????? |
02-18-2021, 14:15 | #753 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | i have repaired the Imei with the ENG Firmware and i noticed the WIFI menu has NVRAM WARNING :Err=0x10 .Now the problem i have is when i write the stock room MIUI 11.0.4.0 the imei disappear and am only left with Serial number, Where am i going wrong? Below is the screenshot with the engineers firmware |
02-18-2021, 14:32 | #754 (permalink) |
Member: 2119579 Status: Offline Thanks Meter: 44 | Well... NVRAM Error... can be resolved using SP META PC program, there are plenty of guides to solve this error or you can write SN again using SN Write Tool also using META mode. Disappeared IMEI, I have no any previous experience with... ????? |
02-18-2021, 15:12 | #756 (permalink) | |
Member: 2119579 Status: Offline Thanks Meter: 44 | Quote:
https://xiaomifirmwareupdater.com/mi...0.4.0.QJOMIXM/ ????? | |
02-18-2021, 20:55 | #761 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | ok a i just finished downloading the fast boot rom let me try and see if i wont lose my imei and meanwhile may i have the link for the guide to repair NVRAM WARNING: Err=0x10 |
02-18-2021, 21:28 | #762 (permalink) | |
Here you have something close and may help shorturl.at/pvLY3 | |
02-18-2021, 21:58 | #763 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | I just finished flashing the rom i downloaded from the site you guided and i have now lost the two imei number and when i type*#06# only serial comes out, Checking the imei 1& 2 both says null. Baseband looks ok but Wifi has the NVRAM Warning: Err=0x10 ,The phone has network as you can see but can receive call nor dial out. This time now i need full guidance step by step |
