10-21-2020, 19:23 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Brazil Age: 30
Member: 1963068 Status: Offline Sonork: amauri.tec Thanks Meter: 81 | SM-A505GT BS5 Pacth NG Printing phone history Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505GT Carrier ID: ZTO Sales Code: ZTO Country Code: Brazil Timezone: America/Sao_Paulo Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Oct 2 03:46:14 KST 2020 PDA Version: A505GTUBS5BTJ1 [october 2020, rev1] Phone Version: A505GDXS5ATA2 [january 2020, rev2] CSC Version: A505GTOWO5BTI1 [september 2020, rev1] Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: Imei: 3544xxxxxxx Imei2: 354xxxxxxxxxx Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.21.20 15:14:23] WorkID: 112209424 Phone Status: NG Why? |
