09-03-2015, 04:41 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | SM-J100VPP Unlock Help Code: Chimera Mobile Phone Utility version: 7.61.1649 @ 2015-09-03 [Get info started] Unable to detect imei number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J100VPP Android Version: 5.0.2 Sales Code: VZW PDA Version: J100VPPVRU2AOF2 [june 2015, rev2] Phone Version: J100VPPVRU2AOF2 [june 2015, rev2] CSC Version: J100VPPVZW2AOF2 [june 2015, rev2] Board Platform: MSM8916 Serial Number: R28G70HJDAV Battery Status: 3.96V (60%) SIM Status: ABSENT Knox Version: v00 Warranty Bit: 0 Finished successfully. Finished at local time: [09.03.15 16:29:37] WorkID: 6775246 Chimera Mobile Phone Utility version: 7.61.1649 @ 2015-09-03 [Unlock phone started] Unable to detect imei number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J100VPP Android Version: 5.0.2 Sales Code: VZW PDA Version: J100VPPVRU2AOF2 [june 2015, rev2] Phone Version: J100VPPVRU2AOF2 [june 2015, rev2] CSC Version: J100VPPVZW2AOF2 [june 2015, rev2] Board Platform: MSM8916 Serial Number: R28G70HJDAV Battery Status: 3.96V (60%) SIM Status: ABSENT Knox Version: v00 Warranty Bit: 0 Checking custom root image... This model is not available custom root image. Unable to root. Retry or root manually. Click here to download rooting tools. Finished at local time: [09.03.15 16:29:52] WorkID: 6775247 |
09-03-2015, 08:29 | #2 (permalink) | |
Freak Poster Join Date: Jul 2010 Location: Dharmapuri,Tamilnadu
Member: 1343981 Status: Offline Thanks Meter: 30 | Root By IROOT Dear Br Try To Root Via IROOT Its Succes Many handset Of J100 Best Of Luck Br SatcomSingaram Quote:
09-04-2015, 03:06 | #4 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, Try root with SRSRoot... Sucees Root: SM-J100VPP (Build: LRX22G.J100VPPVRU2AOF2) Android 5.0.2 |
The Following User Says Thank You to Shensohau For This Useful Post: |
09-11-2015, 01:48 | #6 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Phone not rooted Code: ---= SRS One-Click-Root v5.1 =--- 1:45:06 PM - Starting ADB Server.. 1:45:12 PM - Manufacturer: samsung 1:45:12 PM - Model: SM-J100VPP 1:45:12 PM - Android Version: 5.0.2 1:45:12 PM - Build ID: LRX22G.J100VPPVRU2AOF2 1:45:12 PM - Board ID: msm8916 1:45:12 PM - Chipset Platform: msm8916 1:45:12 PM - Getting OffSets.. : error: only position independent executables (PIE) are supported. (False) 1:45:13 PM - Query Server for Best Method.. Found Rootkit: 8 ----= Start Rooting Process.. Please Wait =---- 1:45:14 PM [+] Testing exploit: root8 (please wait..) 1:45:15 PM [+] Remounting /system Filesystem as R/W.. 1:45:15 PM [+] Installing SU Binary... 1:45:16 PM [+] Installing SuperUser APK... 1:45:16 PM [+] Remounting /system Filesystem as R/O.. 1:45:22 PM [+] Rooting Complete ! Code: ---= SRS One-Click-Root v5.1 =--- 1:46:00 PM - Starting ADB Server.. 1:46:05 PM - Manufacturer: samsung 1:46:05 PM - Model: SM-J100VPP 1:46:05 PM - Android Version: 5.0.2 1:46:05 PM - Build ID: LRX22G.J100VPPVRU2AOF2 1:46:05 PM - Board ID: msm8916 1:46:05 PM - Chipset Platform: msm8916 1:46:05 PM - Getting OffSets.. : error: only position independent executables (PIE) are supported. (False) [x] Device is not rooted, UnRooting not needed. |
09-11-2015, 09:25 | #7 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear Sir, Here is a link maybe that could help you. There is some sw to root the phone. https://chimeratool.com/help/Samsung-Rooting Best Regards Chimera Team Quote:
09-15-2015, 17:13 | #8 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: Lima Age: 42
Member: 138423 Status: Offline Sonork: 75171702 Thanks Meter: 12 | Quote:
But any tool listed in this link work for J100VPP have a tested tool for this??? | |
09-16-2015, 09:33 | #9 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear Henry Nicolas, You can use each one from our list, each one software trusted. Could you write the androis version what you use on that phone? Best regards Nicole Chimera Team |
09-16-2015, 14:09 | #10 (permalink) | |
Enviado desde mi LG-D855 mediante Tapatalk | |
The Following User Says Thank You to henrynicolas For This Useful Post: |
09-16-2015, 14:17 | #11 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear Henry Nicolas, did you tried to repair that phone with the chimeratool too? If yes, could you write me an work id please? Best regards Nicole Chimera Team |
09-17-2015, 09:22 | #13 (permalink) | |
Freak Poster Join Date: May 2008 Location: kampala, uganda. East Africa
Member: 770206 Status: Offline Sonork: Eed07 Thanks Meter: 23 | Quote:
SM-J100VPP Android 5.0.2 Baseband: J100VPPVRU1AOE2 Build No: LRX22G.J100VPPVRU1AOE2 | |
09-17-2015, 13:50 | #14 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear HenryNicolas, the phone is not rooted correctly and the firmware update was unsuccessful too. Please try to use an newer FW, if you could not find newer FW, please try to flash the phone with Odin. Best regards Chimera Team |
