03-22-2020, 18:24 | #16 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,770 | Printing phone history Device Info 3/22/2020 4:23:18 PM SW Change 3/21/2020 5:53:08 PM SW Change 3/21/2020 5:45:56 PM SW Change 3/21/2020 5:34:56 PM SW Change 3/16/2020 1:23:56 PM Firmware update started Processing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-A307F, Region: EUR, Provider: OPEN, PDA: A307FNXXU2ASKA Valid PIT file can be found in the firmware: A30S_EUR_OPEN.pit Use the Enable PIT Write option if you want to use it. Reading PIT from phone. Flashing boot.img Flashing recovery.img Flashing dt.img Flashing dtbo.img Flashing system.img Flashing vendor.img Flashing userdata.img Flashing vbmeta.img Flashing sboot.bin Flashing param.bin Flashing cm.bin Flashing vbmeta.img Flashing modem.bin Flashing modem_debug.bin Flashing cache.img Flashing omr.img Flashing product.img Restarting phone. Successfully finished. Finished at local time: [03.22.20 18:22:07] WorkID: 92429307 |
03-25-2020, 19:28 | #17 (permalink) |
Junior Member Join Date: Sep 2019 Location: Pakistan
Member: 2929898 Status: Offline Thanks Meter: 0 | I had the same issue It's due to KG Lock prenormal state. Try to use the phone for a week then the KG State will change from prenormal to normal Google how to change KG state Sent from my A37fw using Tapatalk |
03-25-2020, 23:31 | #18 (permalink) | |
Member: 1677653 Status: Offline Thanks Meter: 2,770 | Quote:
my phone only stuck on samsung logo. how can i use not power to menu phone for one week? | |
03-26-2020, 14:41 | #19 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,111 | I'm wondering if the EFS on your phone is now corrupted. just now find the EFS for flash with Download mode. Also I'm done another phone today's. Code: Chimera Mobile Phone Utility version: 24.13.1846 @ 2020-03-26 Printing phone history Patch Certificate 3/26/2020 12:31:10 PM Repair IMEI 3/26/2020 11:53:43 AM Repair IMEI 3/26/2020 11:35:42 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A307FN Sales Code: DBT Country Code: Germany Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Nov 27 16:56:01 KST 2019 PDA Version: A307FNXXU2ASKA [november 2019, revA] Phone Version: A307FNXXU2ASKA [november 2019, revA] CSC Version: A307FNOXM2ASKA [november 2019, revA] Product Code: DBT HIDSw Version: A307FNXXU2ASKA/A307FNOXM2ASKA/A307FNXXU2ASKA/A307FNXXU2ASKA Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8MA03EAVW Imei: 356 Unique Number: CDU00E2E55FB296 Connections: AT,MTP Battery Status: 3.85V (49%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-11-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.26.20 14:32:28] WorkID: 92585382
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
03-26-2020, 18:41 | #22 (permalink) | |
Thanks in advance... | |
