10-28-2021, 10:49 | #1 (permalink) |
Freak Poster Join Date: Dec 2017
Member: 2792776 Status: Offline Sonork: 1577835 Thanks Meter: 82 | Y8p aqm-lx1 huawei id not removed Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Rebooting phone to USB update mode Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [10.28.21 14:46:02] WorkID: 156016777 |
10-28-2021, 14:08 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear User, The Factory reset was done after the ID remove process? Best regards Sab Chimera Team Quote:
11-02-2021, 11:18 | #4 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear User, We provide a solution for the ID removal, issues could and will appear based on the continuously evolving market, and Huawei securities. You as a License owner are guaranteed that you will receive updates for the methods. Currently, we are working on the ID removal. Hopefully, within a short amount of time, we can release a fix for it. Best regards Sab Chimera Team |
