09-16-2015, 18:41 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Try another SIM card or: The block call settings for the BlackBerry Z10 attempt to modify a network setting that is not supported by T-Mobile. Any attempt to change these settings will ask for a password, which is not available. To block incoming calls, follow these steps: From any Home screen, tap the Phone icon. Touch the Status bar and slide down. Tap Settings. Scroll down to and tap Call Blocking. Perform one of the following actions: Tap the Block All Incoming Calls switch to turn on. Tap the Block All Incoming Calls While Roaming switch to turn on. To block outgoing calls, follow these steps: From any Home screen, tap the Phone icon. Touch the Status bar and slide down. Tap Settings. Tap Call Blocking. Perform one of the following actions: Tap the Block All Outgoing Calls switch to turn on. Tap the Block All Outgoing International Calls switch to turn on. Tap the Block All Outgoing International Calls While Roaming switch to turn on. |
09-17-2015, 09:11 | #4 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear Sir, thank you for your feedback. If you have any another problem in a future, you can contact us here or you can write us email to the [email protected] Best regards Chimera Team |
