10-06-2014, 21:55 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Brazil
Member: 1977936 Status: Offline Sonork: 100.1667835 Thanks Meter: 20 | i9300 - Power supply of the Device is out! I need help in my gpgemmc box. Please see log in i9300 06/10/2014 15:51:41 >> Device Ready... 06/10/2014 15:51:41 >> Device Ready...OK! 06/10/2014 15:51:41 >>ID check... 06/10/2014 15:51:42 >>Level (V): VCC V18 VCCQ D0 CMD CLK 06/10/2014 15:51:42 >>3.3 Pullup: 0.01 0.02 0.00 0.71 0.78 0.00 06/10/2014 15:51:42 >>Power On : 2.83 1.77 2.48 0.72 0.75 0.01 06/10/2014 15:51:42 >>Set Low : 2.83 1.78 2.48 0.05 0.03 0.00 06/10/2014 15:51:42 >>Set High: 2.83 1.78 2.48 2.02 2.04 2.03 06/10/2014 15:51:42 >>... 06/10/2014 15:51:42 >>Work Voltage: 2.83 1.77 2.48 1.03 1.73 0.02 06/10/2014 15:51:42 >>--------------------------------------------------- 06/10/2014 15:51:42 >>eMMC ORC: C0FF8080 FF 06/10/2014 15:51:42 >>eMMC CID: 15010056545530304DF17A1E66DA6F 06/10/2014 15:51:42 >>eMMC CSD: D02701320F5903FFF6DBFFFF8E4040 06/10/2014 15:51:42 >>ID check: 00010015 06/10/2014 15:51:42 >>Product name: VTU00M 06/10/2014 15:51:42 >>User partition size: 3AB400000 ( 15028M / 14.675G), 15758000128 Bytes 06/10/2014 15:51:42 >>Boot partition size: 0x200000 ( 2.0M ) 06/10/2014 15:51:42 >>RPMB partition size: 0x20000 ( 0.1M ) 06/10/2014 15:51:42 >>ID check...OK! 06/10/2014 15:51:42 >>Erase chip...Boot1 06/10/2014 15:51:45 >>Erase chip: 3.15 sec. 06/10/2014 15:51:45 >>Blank check chip...Boot1 06/10/2014 15:51:46 >>Blank check chip: 0.81 sec. 06/10/2014 15:51:46 >>Erase chip...Boot2 06/10/2014 15:51:49 >>Erase chip: 3.12 sec. 06/10/2014 15:51:49 >>Blank check chip...Boot2 06/10/2014 15:51:50 >>Blank check chip: 0.80 sec. 06/10/2014 15:51:50 >>Erase chip...User 06/10/2014 15:51:57 >>Erase chip: 7.00 sec. 06/10/2014 15:51:57 >>Blank check chip...User 06/10/2014 15:52:06 >>Blank check chip: 9.31 sec. 06/10/2014 15:52:06 >>Power supply of the Device is out! 06/10/2014 15:52:07 >>Erase chip lost! Box is damaged?? Thanks Last edited by brunobbtj; 10-06-2014 at 22:01. |
10-08-2014, 15:00 | #2 (permalink) |
No Life Poster Join Date: May 2012 Location: In Your Heart Age: 37
Member: 1759636 Status: Offline Sonork: 100.1591515 Thanks Meter: 785 | Brother you write file on i9300 and your connectivity is wrong USB cable is disconnect therefore you have facing this problem always connect your pinouts correctly . now you erace the whole chip and write file again. if you have same problem then came online by sonork we will do it by TV. okay br WBGSM |
11-09-2014, 05:31 | #3 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Quote:
No, its not box problem. 1st i9300 has vtoon EMMC chip which has much problem as we have already mentioned in the section. Secondly, you did not use the GPG Power Adapteor So, better give more detail of this device, use power adapter, use short wire between device and GPG EMMC box. For more: http://forum.gsmhosting.com/vbb/10012636-post5.html and http://forum.gsmhosting.com/vbb/10470361-post2.html and http://forum.gsmhosting.com/vbb/10419568-post4.html Still, you can't solve your problem, change the EMMC IC of your device. GOOD LUCK!!! BR Dipendra Pathak | |
