06-19-2015, 09:55 | #1 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2407251 Status: Offline Thanks Meter: 1 | Problem wich EMMC box cant write or read emmc not over isn not over adapter all do on clear installed windows 7 32 and latest utility/driver when try to read or write dump it has give me an error... Connecting... SN:00000102434 Get License data... Verify Liecnse data... Version:V3.2 Device Ready...OK! ------------------------------------------------------ >> Disconnected, please re-connect. after some trys it can give another error, even if chip is not inserted Connecting... SN:00000102434 Get License data... Verify Liecnse data... Version:V3.2 Device Ready...OK! ------------------------------------------------------ Read Info... Pin Check up... Short circuit if i remove a connection test after some try's it begin read but after some secnds it give a error Connecting... SN:00000102434 Get License data... Verify Liecnse data... Version:V3.2 Device Ready...OK! ------------------------------------------------------ Read Info... Device Ready... Device Ready...OK! ID check... >>ID check lost! |
06-24-2015, 09:37 | #2 (permalink) | |
No Life Poster Join Date: Apr 2015
Member: 2385015 Status: Offline Thanks Meter: 884 | Quote:
Sir . PLease please check on windows XP and let us know the results BR Natashah. | |
06-25-2015, 06:04 | #3 (permalink) |
Freak Poster Join Date: May 2014 Location: In the Chip Level
Member: 2187058 Status: Offline Thanks Meter: 41 | ID check lost happens due to Power Adapter. Use GPG EMMC latest power adapter while you start work with GPG EMMC. It is free while you buy GPG EMMC 1st version box and you will get it inside if you buy 2nd version box (Yellow) WBR Micro Mind |
06-25-2015, 07:40 | #4 (permalink) |
Member: 2407251 Status: Offline Thanks Meter: 1 | already understand, sorry for inconvinience, but there is another problem wich 64G emmc i post it in another tread... http://forum.gsmhosting.com/vbb/f899...25/index2.html |
06-29-2015, 14:26 | #6 (permalink) |
Member: 2407251 Status: Offline Thanks Meter: 1 | i have box version 2 (yellow) it do not need power adapter it inside, on this box i try to read or write 64G chips (any) it has give an error wich one i post before otherway same box read and write 32 16 8 G chips without a problem... we have 2 box v2 it all have same defect and one box version 1 wich external adapter it has write all chips (even 64g) without a problem. seems here some kind of problem wich powersupply in box v2... real dissapointing... 16G- Code: Read Info... Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 3.3 Pullup: 0.01 0.00 0.00 0.58 0.58 0.00 Power On : 2.73 1.75 2.48 0.81 0.82 0.00 Set Low : 2.73 1.75 2.48 0.01 0.01 0.00 Set High: 2.73 1.75 2.48 2.46 2.47 2.47 ... Work Voltage: 2.73 1.75 1.65 0.85 2.47 0.01 --------------------------------------------------- eMMC ORC: C0FF8080 AF eMMC CID: 90014A484147326504020B4DD18B60 eMMC CSD: D02701320F5903FFFFFFFFEF8A4040 ID check: 4A010090 Product name: HAG2e_ User partition size: 3AB800000 ( 15032M / 14.679G), 15762194432 Bytes Boot partition size: 0x400000 ( 4.0M ) RPMB partition size: 0x400000 ( 4.0M ) ID check...OK! >>ID check success. time:0.87 sec. Code: Read Info... Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 3.3 Pullup: 0.01 0.00 0.00 0.58 0.56 0.00 Power On : 2.72 1.75 2.48 0.85 0.86 0.00 Set Low : 2.73 1.75 2.48 0.01 0.01 0.01 Set High: 2.73 1.76 2.48 2.46 2.47 2.47 ... Work Voltage: 2.72 1.75 2.48 0.86 2.47 0.01 --------------------------------------------------- eMMC ORC: C0FF8080 AF eMMC CID: 45010053454D36344712026CC47F71 eMMC CSD: D00F00320F5903FFFFFFFFFF8A4040 ID check: 00010045 Product name: SEM64G User partition size: E8F800000 ( 59640M / 58.242G), 62537072640 Bytes Boot partition size: 0x400000 ( 4.0M ) RPMB partition size: 0x400000 ( 4.0M ) ID check...OK! >>Chip information acquisition in error, please modify the VCCQ value and then try again. |
07-02-2015, 13:07 | #7 (permalink) |
Crazy Poster Join Date: Apr 2015
Member: 2384973 Status: Offline Thanks Meter: 17 | Give Full Info Problem .. What Error Got...Handset Brand & Model ...Chip Detail...Jtag Or Direct Emmc...It Seems Having Issue With Jtag Read & Write....CPU Id Came Or Not Best Regards Osva |
07-21-2015, 13:24 | #8 (permalink) |
Member: 2407251 Status: Offline Thanks Meter: 1 | 1)What Error Got... >>Chip information acquisition in error, please modify the VCCQ value and then try again. 2)...Chip Detail ANY 64GB chip, 32 and 16 is ok 3)Jtag Or Direct Emmc... Direct emmc and over adapter in emmc mode still need help.... i have yellow EMMCbox which internal power adapter... it DONT work which 64GB emmc's always give error about VCCQ |
08-07-2015, 05:08 | #10 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Quote:
Seems your mobile has short circuit or wires are connected each other or like that....check above. BR Dipendar Pathak | |
08-07-2015, 08:41 | #11 (permalink) |
Member: 2407251 Status: Offline Thanks Meter: 1 | this problem already solvet i have new one - in http://forum.gsmhosting.com/vbb/f899.../#post11136758 i use BGA_169E adapter to dump and write chips DIRECT metod my problem what i cant do anything which 64G memory which all other 32,16,8 work normally i have new yellow box, my collegue who have REDone has no such problem |
