04-08-2018, 09:13 | #286 (permalink) | |
Junior Member Join Date: Apr 2018
Member: 2827654 Status: Offline Thanks Meter: 3 | Quote:
On the back side of the display there is this number HT-9001-02P-140L-2017-XX-XX I tried to flash some firmware name CB-M 94V-0 trough Phoenix but the process does not even start. Up to now the firmware version that at least allowed me to turn on the device was A33-800X480-astar_y3-eng-4.4.2-KVT49L-20141224-test-keys but touch screen doesn't work and display can only be seen against the light. Thank you for your Help. Best regards | |
04-11-2018, 10:53 | #289 (permalink) |
Junior Member Join Date: Feb 2012 Location: Hungary
Member: 1719590 Status: Offline Thanks Meter: 0 | Hello! Need to firmware the AL-AX3-708-V1.1 (201551225) motherborad (eStar Beaty HD Quad Core MID7338). Original OS ver.: 5.1.1 Chip numbers: A33 FC006AA 6C71 AXP223 FA120AC 6B61 SK HYNIX H51C4G63CFR PBA 512V NW3DK86YSUU SANDISK X428107001 HNCY151022 WIFI: SV6051Z TAB5V CGS09 Display: MF0701683001A Touch: HC184104C1 FPC021H V2.0 HXS Touch control chip (in mainboard): GSL1680 K1F1E68492J I'm tested more A33 firmware... only working the Sanggeer-MB709Q5-8703-VITO_a33_v3.3rc5_5.1.1_2015070601_.img 3 problem: -touch mirrored (not good build prop LCD rotating settings... rotate with touch) -wifi not start (bad driver) -after 2-3 min: slow down All other A33 firmware: start without display (boot sound played) The service centre say: The tab firmware not public, service price = big money. In gsmhosting link to easy-firmware.com - only downloadable 25$. 30$ = working other used tab. Not good... Free method??? Please help, and send link to estar or other working firmware! Thanks! Mainboard: Original firmware info: |
04-24-2018, 07:33 | #291 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2820620 Status: Offline Thanks Meter: 0 | Hi, Have anybody found the firmware for this tablet Hi, Have anybody found the firmware for this tablet A33 QuadCore Wifi: ESP8089 Touch: GSL3675 POWER: AXP 223 MB: M100_MB V1.1 And that's not this because the only thing that works is the screen M1025A_TZX_RASK_TZX0233_DBL2855_ESP8089_GSL3675_HD _20150206 |
05-15-2018, 19:50 | #295 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2436206 Status: Offline Thanks Meter: 1 | Olá! Eu preciso de firmware para tablet Como Max Quad A0011-C Motherboard Junto AL-A33-751S-V3.0 data 2016.05.07 Chip A33 Toque GSL1680 WIFI SV6051Z |
The Following User Says Thank You to bsbwilson For This Useful Post: |
05-21-2018, 14:09 | #299 (permalink) |
Junior Member Join Date: May 2018
Member: 2839037 Status: Offline Thanks Meter: 0 | Please help I can't find firmware needed Firmware needed for Q8V-V1.6 2016 0623. Allwinner A33. Please help I can't find it anywhere. I have tried the 2016 0414 one but it doesn't work at all. |
