08-19-2014, 10:20 | #1 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Flash tools Error collection_possible sulotin here Lot of unknown Error we faced in SP flash tools although WE don't know about them why this kind of error happen here is few solution Credits Goes to SP tools 1.BROM Error S_UNKNOWN_TARGET_BBCHIP [Description] lUnsupported target baseband chip type! [Solution] lPlease upgrade to the latest Flash Tool then try again. S_UNSUPPORTED_VER_OF_BOOT_ROM [Description] lUnsupported Boot ROM! [Solution] lPlease upgrade to the latest Flash Tool then try again. S_SEC_INFO_NOT_FOUND [Description] lYour ROM files doesn't enable secure feature! Secure-on BB must boot up with secure-on ROM files! [Solution] lPlease use a secure-on ROM file then try again. S_BROM_DOWNLOAD_DA_FAIL [Description] l[H/W] Fail to download DA to baseband chip's internal SRAM! [Reason] 1.There’s a cable communication problem between Flash Tool and Boot ROM. 2.Target might be shutdown unexpectedly or target lost power supply. 3.The DA is not correct. [Solution] 1.Try again. 2.Proceed H/W checking in download cable and target side com port. 3.Monitor if power-drop occurred in target side. S_BROM_BBCHIP_HW_VER_INCORRECT [Description] l[H/W] Target baseband chip is inconsistent with bin files! [Solution] lPlease select the correct image files for the target's baseband chip. S_BROM_AUTOBAUD_FAIL [Description] l[H/W] Boot ROM start command passed but fails to multiple Boot ROM baud rate! [Reason] 1.There's a cable communication problem between Flash Tool and Boot ROM. 2.Target might be shutdown unexpectedly. [Solution] 1.Try again. 2.Speed-Up Boot ROM baud rate” in advance mode (CTRL+ALT+V) then try again. 3.Proceed H/W checking in download cable and target side UART path. 4.Monitor if power-drop occurred in target side. S_BROM_EXCEED_MAX_DATA_BLOCKS [Description] l[MAUI] The number of Multi-Bin files is more than 10! [Solution] 1.Please don't build more than 10 binary files. S_DA_INT_RAM_ERROR [Description] lThe download image is not match with phone memory. [Solution] lPlease select correct image to match with phone memory and try again. S_DA_EXT_RAM_ERROR [Description] l[H/W] DA didn't detect external RAM! [Solution] lIt maybe a SMT or an EMI issue, please use another phone to download. S_DA_NAND_BLOCK_DATA_UNSTABLE [Description] l[H/W] Data of the block is unstable after erasing NAND Flash! [Reason] lIt maybe a SMT issue. [Solution] lPlease format all flash or use another phone to download. S_SECURITY_SLA_INVALID_AUTH_FILE [Description] l[User] An invalid authentication file is used! [Solution] lThis error message will occurs with MSP (MTK Secure Platform) code, Please keep up the MSP code and ask for help. S_SECURITY_SF_SECURE_VER_CHECK_FAIL [Description] l[User] The secure version of the secure-MAUI is older than that in the handset! [Solution] lPlease choose a secure-MAUI with an equal or newer secure version. S_SECURITY_DAA_FAIL [Description] lDA Security download error! [Solution] lSecurity DA is not signed by a correct key, please select correct DA and try again. S_DA_UPDATE_BOOTLOADER_EXIST_MAGIC_NOT_MATCHED [Description] lDA DSP_BL check exist error. [Solution] lThere is no DSP_BL in previous load on target, please format all and download again. http://forum.gsmhosting.com/vbb/f606...-logo-1840313/ [IMG]****************************/convkey/0fa4/qq0zcyol0fmauiu6g.jpg[/IMG] Br_gsm mithun roy |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
