08-21-2014, 12:53 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: GSM World!! Age: 35
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | BlackBerry Exclusive Features BB9320 PIN repair Done!!![The Future is Our Present] |
The Following 8 Users Say Thank You to resident2011 For This Useful Post: |
08-21-2014, 13:07 | #2 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | ah...you did it ,bro Great !!! Please check here for first condition! http://forum.gsmhosting.com/vbb/f907...-team-1850312/ Br, ARD |
08-22-2014, 14:36 | #3 (permalink) |
Freak Poster Join Date: Aug 2013 Location: spookeybox
Member: 2008809 Status: Offline Sonork: 100.1653171 Thanks Meter: 764 | Thanks for nice result bro resident2011 Note : Spookey can repair pin FFFFFF but make sure u can put imei/pin from sticker imei/pin.. and must original not from other pcb. if not have stiker or emptyboard can't repair it.. because Blackberry device have many signature.. spookey just only restore or write pin/imei after changing from other tools. Not Recalculate signature from emptyboard. Br, SpookeyBox |
09-14-2014, 20:24 | #5 (permalink) | |
Member: 2008809 Status: Offline Sonork: 100.1653171 Thanks Meter: 764 | Quote:
If something Need Repair = means Broken Old thing possible can be fixed Spookey supported just Repair , not to change!! Br, SpookeyBox | |
12-30-2015, 15:06 | #6 (permalink) |
Freak Poster Join Date: May 2010 Location: Tebing Tinggi
Member: 1306699 Status: Offline Sonork: GC Thanks Meter: 21 | Connecting to Device in progress, please wait... Device [1] connected. Get device info... Device Info: PIN: FFFFFFFF BSN: -1 Bootrom Version: 5.11.0.4 Hardware ID: 0x0E001507 RIM BlackBerry Device HW ID Override: None Hardware OS ID: None BR ID: 0xFF000000 Metrics Version: 6.25 Build Date: Mar 21 2011 Build Time: 16:17:23 Build User: ec_agent Security: Disabled Supported Options: 0x00000009 Drivers: 0x00000010 Processor: 0x00000001 FlashID: 0x00000000 LDR Blocks: 0x5C0267F0 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A JTAG SW Support: Unknown RPMB Support: Unknown WP Mode: Unknown Slack Mode: Unknown OS Blocking by Date: Not supported HWV: Board Revision 0x01 - 0x0D CPU Version 0x02 - 0x31 SW Compatibility 0x03 - 0x01 POP Revision 0x04 - 0x0B Power Mgt Hardware 0x07 - 0x3C POP Security 0x0B - 0x02 GPS 0x0C - 0x06 ROM MASK Version 0x0D - 0x0A Hearing Aid Compat 0x37 - 0x01 WCDMA Band supported 0x3B - 0x00 BSIS support 0x41 - 0x01 NFC 0x49 - 0x07 Mem Config Table (ver 1.24): Flash Chip: blocks 0-8191, Chip 0, Sub 0 Boot0 MMC: blocks 0-1, total = 2, flags = 0x0003 User MMC: blocks 2-8191, total = 8190, flags = 0x0003 Bootrom: blocks 0-1 MCT: block 2 OS NV: blocks 3-60, total 58 Branding: blocks 61-66 OS Dynamic: blocks 67-???? FS Dynamic: blocks ????-7352 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15130003 0x00000000 RAM Chip: 0xB0000000-BFFFFFFF, Bank Size 67108864 RAM Chip: 0xC0000000-CFFFFFFF, Bank Size 67108864 CRC: 0xE109BB85 Mem Config Table (ver 1.27) (actual): Flash Chip: blocks 0-8191, Chip 0, Sub 0 Boot0 MMC: blocks 0-1, total = 2, flags = 0x0003 User MMC: blocks 2-8191, total = 8190, flags = 0x0003 Bootrom: blocks 0-1 MCT: block 2 OS NV: blocks 3-60, total 58 Branding: blocks 61-66 OS Fixed: blocks 67-588 UMP Fixed: blocks 589-955, total = 367 FS Fixed: blocks 956-7352, total = 6397 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15130003 0x00000000 RAM Chip: 0xB0000000-BFFFFFFF, Bank Size 67108864 RAM Chip: 0xC0000000-CFFFFFFF, Bank Size 67108864 CRC: 0xACB10FAB Flash: Number of chips: 1 Flash ID: NAND blocks 0-7361 Device ID: 0x1 Vendor ID: 0xFE Manufacturer Name: Numonyx OEM/Application ID: 0x14E Product Name: MMC512 Product Revision: 0x26 Product Serial Number: 0x100092E6 Manufacturing Date: Year 2011, Month 2 MMC Partition Info: Boot0: 512 KB Boot1: 512 KB User: 471040 KB Total Size: 460.1 MB Memory Map: NAND Blocks: 7362 * 64 Kb RAM Base: 0xB8000000 IRAM Base: 0x5C000000 OS Range: 67 - 588 File System: Memory Map: 956 - 7352 Sectors: 6397 Branding: Vendor ID: 1 OS Version: 9.6.0.162 Hardware ID: 0x0E001507 RIM BlackBerry Device Metrics Version: 3.18 FS Code Version: 10.0.0.0 FAT Code Version: 2.34 Package Version: "9.6.0.162" Build Date: Sep 26 2013 Build Time: 23:15:54 Build User: ec_agent SV Number: 52 OS Address: 0xB8000000-0xBA09D603 App Start: 0xB91F0DDC Companion Binary: 0.0.0.0 RAM usage: 0xBDDFFFFC-0xBEFFFFFC IRAM End: 0xD1000000 DSP ROM2 Address: *not present* OS Extended Addr: 0xB99F0328 LDR Blocks: 0xB9AD7B90 API Checksum: 0x00000000 JumpTable (<3): 0xB80003CC JumpTable (>2): 0xB800306C Radio Code: Janus radio code linked OS API Version: 156.51 STP Protocol Ver: 5.291.4 (release OS) HWV Map: Board Revision 0x01 - [0x0C - 0xFF], 0x01 POP Revision 0x04 - [0x00 - 0xFF], 0x01 CPU Version 0x02 - [0x30 - 0xFF], 0x01 ROM MASK Version 0x0D - [0x0A - 0x0A], 0x00 SW Compatibility 0x03 - [0x00 - 0x02], 0x01 WTE supported 0x3C - [0x01 - 0xFF], 0x00 Version Table: OS API Version: 156.51 STP protocol version: 5.291.4 BlockFS API Version: 10.0.0.0 USB driver version: 02.32 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 NVSIG RTAS key: 1.0 FAT FS Version: 2.34 Block map version: 0.0 NDK ABI version: 0.1 WLAN radio version: 4.5.0.303 Radio version: 1.2.3.4.7 Kernel Version: 3.2.0.716 Hardware ID: 0x0E001507 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Sep 26 2013 Build Time: 22:37:48 Build User: SCM App: Version: 7.1.0.1098 (0x0701044A) Metrics Version: 1.7 Build Date: Sep 26 2013 Build Time: 23:26:17 Build User: RIM Memory Map: 0xB91F0DDC-0xB99F0327 App c_main: 0xB92ADF0C API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 AppFSVersion: 3.0.0.0 AppFSSize: 0x0 OS API Version: 156.51 RAM Map: 0xBDC00000-0xBDDFFFD8 IRAM Map: Unused App Type: JVM UMP: Name: NFC_java.elf Size: 740012 bytes, blocks 589-600, offset 0 Name: OlympiaWebKit.elf Size: 6669000 bytes, blocks 600-702, offset 19728 Name: OlympiaWebKitLDLL.ldll Size: 11674308 bytes, blocks 702-880, offset 4668 Name: SaaS.elf Size: 4506312 bytes, blocks 880-948, offset 13624 Name: dhcpd.elf Size: 402648 bytes, blocks 948-955, offset 64100 Preparing device, please wait.. Done How to repair this? |
03-11-2016, 14:57 | #8 (permalink) |
Member: 1306699 Status: Offline Sonork: GC Thanks Meter: 21 | how to repair this? Connecting to Device in progress, please wait... Device [1] connected. Get device info... Device Info: PIN: FFFFFFFF BSN: -1 Bootrom Version: 5.11.0.9 Hardware ID: 0x0E001507 RIM BlackBerry Device HW ID Override: None Hardware OS ID: None BR ID: 0xFF000000 Metrics Version: 6.25 Build Date: Jun 27 2011 Build Time: 12:44:12 Build User: ec_agent Security: Enabled Supported Options: 0x00000009 Drivers: 0x00000010 Processor: 0x00000001 FlashID: 0x00000000 LDR Blocks: 0x5C026CF0 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A JTAG SW Support: Unknown RPMB Support: Unknown WP Mode: Unknown Slack Mode: Unknown OS Blocking by Date: Not supported HWV: Board Revision 0x01 - 0x10 CPU Version 0x02 - 0x35 SW Compatibility 0x03 - 0x01 POP Revision 0x04 - 0x2B Power Mgt Hardware 0x07 - 0x3C POP Security 0x0B - 0x01 GPS 0x0C - 0x06 ROM MASK Version 0x0D - 0x0A Hearing Aid Compat 0x37 - 0x01 WCDMA Band supported 0x3B - 0x08 BSIS support 0x41 - 0x02 Device variant 0x42 - 0x01 NFC 0x49 - 0x07 Mem Config Table (ver 1.26): Flash Chip: blocks 0-8191, Chip 0, Sub 0 Boot0 MMC: blocks 0-7, total = 8, flags = 0x0003 User MMC: blocks 8-8191, total = 8184, flags = 0x0003 Bootrom: blocks 0-7 MCT: block 8 OS NV: blocks 9-66, total 58 Branding: blocks 67-72 OS Dynamic: blocks 73-???? FS Dynamic: blocks ????-7358 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15140003 0x00000000 RAM Chip: 0xB0000000-BFFFFFFF, Bank Size 67108864 RAM Chip: 0xC0000000-CFFFFFFF, Bank Size 67108864 CRC: 0x4FC705A8 Mem Config Table (ver 1.27) (actual): Flash Chip: blocks 0-8191, Chip 0, Sub 0 Boot0 MMC: blocks 0-7, total = 8, flags = 0x0003 User MMC: blocks 8-8191, total = 8184, flags = 0x0003 Bootrom: blocks 0-7 MCT: block 8 OS NV: blocks 9-66, total 58 Branding: blocks 67-72 OS Fixed: blocks 73-276 UMP Fixed: blocks 277-283, total = 7 FS Fixed: blocks 284-7358, total = 7075 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15140003 0x00000000 RAM Chip: 0xB0000000-BFFFFFFF, Bank Size 67108864 RAM Chip: 0xC0000000-CFFFFFFF, Bank Size 67108864 CRC: 0x65C644AB Flash: Number of chips: 1 Flash ID: NAND blocks 0-7359 Device ID: 0x1 Vendor ID: 0x90 Manufacturer Name: Hynix OEM/Application ID: 0x14A Product Name: HYNIX Product Revision: 0xF Product Serial Number: 0x6F7C3C Manufacturing Date: Year 2012, Month 4 MMC Partition Info: Boot0: 512 KB Boot1: 512 KB User: 470528 KB Total Size: 460 MB Memory Map: NAND Blocks: 7360 * 64 Kb RAM Base: 0xB8000000 IRAM Base: 0x5C000000 OS Range: 73 - 276 File System: Memory Map: 284 - 7358 Sectors: 7075 Branding: Vendor ID: 613 OS Version: 8.0.0.486 Hardware ID: 0x0E001507 RIM BlackBerry Device Metrics Version: 3.18 FS Code Version: 10.0.0.0 FAT Code Version: 2.34 Package Version: "" Build Date: Oct 25 2011 Build Time: 16:01:03 Build User: ec_agent SV Number: 1 OS Address: 0xB8000000-0xB8CBA493 App Start: * No Application Linked * Companion Binary: 0.0.0.0 RAM usage: 0xBDDFFFFC-0xBEFFFFFC IRAM End: 0xD1000000 DSP ROM2 Address: *not present* OS Extended Addr: 0xB86C6AB0 LDR Blocks: 0xB87AE318 API Checksum: 0x00000000 JumpTable (<3): 0xB80003A8 JumpTable (>2): 0xB8002E10 Radio Code: Janus radio code linked OS API Version: 147.8 STP Protocol Ver: 5.255.1 (factory OS) HWV Map: Board Revision 0x01 - [0x04 - 0xFF], 0x01 POP Revision 0x04 - [0x00 - 0xFF], 0x01 CPU Version 0x02 - [0x00 - 0xFF], 0x01 ROM MASK Version 0x0D - [0x0A - 0x0A], 0x00 SW Compatibility 0x03 - [0x00 - 0x01], 0x01 WTE supported 0x3C - [0x01 - 0xFF], 0x00 Version Table: OS API Version: 147.8 STP protocol version: 5.255.1 BlockFS API Version: 10.0.0.0 USB driver version: 02.31 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 NVSIG RTAS key: 1.0 FAT FS Version: 2.34 Block map version: 0.0 NDK ABI version: 0.1 WLAN radio version: 4.4.0.217 Kernel Version: 3.0.0.871 Hardware ID: 0x0E001507 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Oct 25 2011 Build Time: 15:29:45 Build User: SCM UMP: Name: NFC_fos.elf Size: 411396 bytes, blocks 277-283, offset 0 Preparing device, please wait.. Done |
