Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Spookey box
Old 08-21-2014, 12:53   #1 (permalink)
resident2011's Avatar
Member: 1530237
Sonork: 100.1614868
Thanks Meter: 5,598
Exclamation BlackBerry Exclusive Features BB9320 PIN repair Done!!![The Future is Our Present]
The Following 8 Users Say Thank You to resident2011 For This Useful Post:
Old 08-21-2014, 13:07   #2 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
ah...you did it ,bro
Great !!!
Please check here for first condition!
http://forum.gsmhosting.com/vbb/f907...-team-1850312/
Br,
ARD
Old 08-22-2014, 14:36   #3 (permalink)
Member: 2008809
Sonork: 100.1653171
Thanks Meter: 764
Thanks for nice result bro resident2011
Note :
Spookey can repair pin FFFFFF but make sure u can put imei/pin from sticker imei/pin.. and must original not from other pcb.
if not have stiker or emptyboard can't repair it..
because Blackberry device have many signature..
spookey just only restore or write pin/imei after changing from other tools.
Not Recalculate signature from emptyboard.
Br,
SpookeyBox
Old 08-27-2014, 03:29   #4 (permalink)
Member: 1125624
how when BSN is missing to?still can be repair with spookey?without knowing ori BSN or have an backup for it?
Old 09-14-2014, 20:24   #5 (permalink)
Member: 2008809
Sonork: 100.1653171
Thanks Meter: 764
If something Missing = need to change with new one!!
If something Need Repair = means Broken Old thing possible can be fixed
Spookey supported just Repair , not to change!!
Br,
SpookeyBox
Old 12-30-2015, 15:06   #6 (permalink)
Member: 1306699
Sonork: GC
Thanks Meter: 21
Connecting to Device in progress, please wait...
Device [1] connected.
Get device info...
Device Info:
PIN: FFFFFFFF
BSN: -1
Bootrom Version: 5.11.0.4
Hardware ID: 0x0E001507 RIM BlackBerry Device
HW ID Override: None
Hardware OS ID: None
BR ID: 0xFF000000
Metrics Version: 6.25
Build Date: Mar 21 2011
Build Time: 16:17:23
Build User: ec_agent
Security: Disabled
Supported Options: 0x00000009
Drivers: 0x00000010
Processor: 0x00000001
FlashID: 0x00000000
LDR Blocks: 0x5C0267F0
Bootrom Size: 0x00020000
External MCT/HWV: Enabled
Boot Mode: N/A
Boot OS Count: N/A
JTAG SW Support: Unknown
RPMB Support: Unknown
WP Mode: Unknown
Slack Mode: Unknown
OS Blocking by Date: Not supported
HWV:
Board Revision 0x01 - 0x0D
CPU Version 0x02 - 0x31
SW Compatibility 0x03 - 0x01
POP Revision 0x04 - 0x0B
Power Mgt Hardware 0x07 - 0x3C
POP Security 0x0B - 0x02
GPS 0x0C - 0x06
ROM MASK Version 0x0D - 0x0A
Hearing Aid Compat 0x37 - 0x01
WCDMA Band supported 0x3B - 0x00
BSIS support 0x41 - 0x01
NFC 0x49 - 0x07
Mem Config Table (ver 1.24):
Flash Chip: blocks 0-8191, Chip 0, Sub 0
Boot0 MMC: blocks 0-1, total = 2, flags = 0x0003
User MMC: blocks 2-8191, total = 8190, flags = 0x0003
Bootrom: blocks 0-1
MCT: block 2
OS NV: blocks 3-60, total 58
Branding: blocks 61-66
OS Dynamic: blocks 67-????
FS Dynamic: blocks ????-7352
NAND Config: type 0, data 0x00001000 0x00010000
NAND Config: type 1, data 0x15130003 0x00000000
RAM Chip: 0xB0000000-BFFFFFFF, Bank Size 67108864
RAM Chip: 0xC0000000-CFFFFFFF, Bank Size 67108864
CRC: 0xE109BB85
Mem Config Table (ver 1.27) (actual):
Bootrom: blocks 0-1
MCT: block 2
OS Fixed: blocks 67-588
UMP Fixed: blocks 589-955, total = 367
FS Fixed: blocks 956-7352, total = 6397
CRC: 0xACB10FAB
Flash:
Number of chips: 1
Flash ID: NAND blocks 0-7361
Device ID: 0x1
Vendor ID: 0xFE
Manufacturer Name: Numonyx
OEM/Application ID: 0x14E
Product Name: MMC512
Product Revision: 0x26
Product Serial Number: 0x100092E6
Manufacturing Date: Year 2011, Month 2
MMC Partition Info:
Boot0: 512 KB
Boot1: 512 KB
User: 471040 KB
Total Size: 460.1 MB
Memory Map:
NAND Blocks: 7362 * 64 Kb
RAM Base: 0xB8000000
IRAM Base: 0x5C000000
OS Range: 67 - 588
File System:
Memory Map:
956 - 7352
Sectors: 6397
Branding:
Vendor ID: 1
OS Version: 9.6.0.162
Metrics Version: 3.18
FS Code Version: 10.0.0.0
FAT Code Version: 2.34
Package Version: "9.6.0.162"
Build Date: Sep 26 2013
Build Time: 23:15:54
SV Number: 52
OS Address: 0xB8000000-0xBA09D603
App Start: 0xB91F0DDC
Companion Binary: 0.0.0.0
RAM usage: 0xBDDFFFFC-0xBEFFFFFC
IRAM End: 0xD1000000
DSP ROM2 Address: *not present*
OS Extended Addr: 0xB99F0328
LDR Blocks: 0xB9AD7B90
API Checksum: 0x00000000
JumpTable (<3): 0xB80003CC
JumpTable (>2): 0xB800306C
Radio Code: Janus radio code linked
OS API Version: 156.51
STP Protocol Ver: 5.291.4 (release OS)
HWV Map:
Board Revision 0x01 - [0x0C - 0xFF], 0x01
POP Revision 0x04 - [0x00 - 0xFF], 0x01
CPU Version 0x02 - [0x30 - 0xFF], 0x01
ROM MASK Version 0x0D - [0x0A - 0x0A], 0x00
SW Compatibility 0x03 - [0x00 - 0x02], 0x01
WTE supported 0x3C - [0x01 - 0xFF], 0x00
Version Table:
STP protocol version: 5.291.4
BlockFS API Version: 10.0.0.0
USB driver version: 02.32
Bugdisp RTAS key: 1.0
STP RTAS key: 1.0
NVSIG RTAS key: 1.0
FAT FS Version: 2.34
Block map version: 0.0
NDK ABI version: 0.1
WLAN radio version: 4.5.0.303
Radio version: 1.2.3.4.7
Kernel Version: 3.2.0.716
Metrics Version: 1.1
Build Time: 22:37:48
Build User: SCM
App:
Version: 7.1.0.1098 (0x0701044A)
Metrics Version: 1.7
Build Time: 23:26:17
Build User: RIM
Memory Map: 0xB91F0DDC-0xB99F0327
App c_main: 0xB92ADF0C
JumpTable (<3): 0x00000000
JumpTable (>2): 0x00000000
AppFSVersion: 3.0.0.0
AppFSSize: 0x0
RAM Map: 0xBDC00000-0xBDDFFFD8
IRAM Map: Unused
App Type: JVM
UMP:
Size: 740012 bytes, blocks 589-600, offset 0
Size: 6669000 bytes, blocks 600-702, offset 19728
Size: 11674308 bytes, blocks 702-880, offset 4668
Size: 4506312 bytes, blocks 880-948, offset 13624
Size: 402648 bytes, blocks 948-955, offset 64100
Preparing device, please wait..
Done
How to repair this?
Old 12-30-2015, 15:08   #7 (permalink)
Member: 1306699
Sonork: GC
Thanks Meter: 21
Model : 9360
Pin : FFFFFFFF
Old 03-11-2016, 14:57   #8 (permalink)
Member: 1306699
Sonork: GC
Thanks Meter: 21
how to repair this?
Get device info...
Device Info:
PIN: FFFFFFFF
BSN: -1
Bootrom Version: 5.11.0.9
BR ID: 0xFF000000
Build Date: Jun 27 2011
Build Time: 12:44:12
Security: Enabled
Drivers: 0x00000010
FlashID: 0x00000000
LDR Blocks: 0x5C026CF0
Boot Mode: N/A
Boot OS Count: N/A
WP Mode: Unknown
Slack Mode: Unknown
HWV:
Board Revision 0x01 - 0x10
CPU Version 0x02 - 0x35
POP Revision 0x04 - 0x2B
POP Security 0x0B - 0x01
GPS 0x0C - 0x06
WCDMA Band supported 0x3B - 0x08
BSIS support 0x41 - 0x02
Device variant 0x42 - 0x01
NFC 0x49 - 0x07
Mem Config Table (ver 1.26):
Boot0 MMC: blocks 0-7, total = 8, flags = 0x0003
User MMC: blocks 8-8191, total = 8184, flags = 0x0003
Bootrom: blocks 0-7
MCT: block 8
OS NV: blocks 9-66, total 58
Branding: blocks 67-72
OS Dynamic: blocks 73-????
FS Dynamic: blocks ????-7358
NAND Config: type 1, data 0x15140003 0x00000000
CRC: 0x4FC705A8
Bootrom: blocks 0-7
MCT: block 8
OS Fixed: blocks 73-276
UMP Fixed: blocks 277-283, total = 7
FS Fixed: blocks 284-7358, total = 7075
CRC: 0x65C644AB
Flash:
Number of chips: 1
Flash ID: NAND blocks 0-7359
Device ID: 0x1
Vendor ID: 0x90
Manufacturer Name: Hynix
OEM/Application ID: 0x14A
Product Name: HYNIX
Product Revision: 0xF
Product Serial Number: 0x6F7C3C
Manufacturing Date: Year 2012, Month 4
MMC Partition Info:
Boot0: 512 KB
Boot1: 512 KB
User: 470528 KB
Total Size: 460 MB
Memory Map:
NAND Blocks: 7360 * 64 Kb
OS Range: 73 - 276
File System:
Memory Map:
284 - 7358
Sectors: 7075
Branding:
Vendor ID: 613
OS Version: 8.0.0.486
Package Version: ""
Build Date: Oct 25 2011
Build Time: 16:01:03
SV Number: 1
OS Address: 0xB8000000-0xB8CBA493
App Start: * No Application Linked *
OS Extended Addr: 0xB86C6AB0
LDR Blocks: 0xB87AE318
JumpTable (<3): 0xB80003A8
JumpTable (>2): 0xB8002E10
OS API Version: 147.8
STP Protocol Ver: 5.255.1 (factory OS)
HWV Map:
Board Revision 0x01 - [0x04 - 0xFF], 0x01
CPU Version 0x02 - [0x00 - 0xFF], 0x01
SW Compatibility 0x03 - [0x00 - 0x01], 0x01
Version Table:
STP protocol version: 5.255.1
USB driver version: 02.31
STP RTAS key: 1.0
NVSIG RTAS key: 1.0
WLAN radio version: 4.4.0.217
Kernel Version: 3.0.0.871
Build Time: 15:29:45
Build User: SCM
UMP:
Size: 411396 bytes, blocks 277-283, offset 0
Done
Page generated in 0.28790 seconds with 8 queries
