05-26-2014, 22:29 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Location: spookeybox
Member: 2008809 Status: Offline Sonork: 100.1653171 Thanks Meter: 764 | SPOOKEY V1.2.2.1 Update - Whole World is gonna know! Exclusive Rtas Remove Os6&7 Instruction : Uninstall old version and delete all spookey folder with manually then install the new version. and after New Spookey version has Installed, do Update Module It's Must ! Here is Download Link Caution!! Dont share your PIN and IMEI ...or Spookey will take it ! Complation of List device which supported RTAS Remove Code: 8100 8110 8120 8130 8130m 8200-8220 8230 8230m 8300 8310 8320 8330 8330m 8350 8520 8530 8700 8707 8800 8820 8830 8830m 8900 8910 8980 9000 9100-9105 9300 9315-9320 9330 9500 9520 9530 9550 9630 9650 9670 9700 9780 9788 9800 9810 9850 9860 9900 9930 p9981 SpookeyBox Last edited by SPOOKEY V2; 05-28-2014 at 09:07. |
The Following 29 Users Say Thank You to SPOOKEY V2 For This Useful Post: |
05-26-2014, 23:44 | #5 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Kanada
Member: 737720 Status: Offline Thanks Meter: 1,421 | What is world first? Talking abt RTAS? Who care abt Rtas now. Sumsung update is most important now unlocking N repair imei spacialy new model like note3 N s5 and others ok amigos. Spookey should comes with boom update. Otherwise forget it. |
The Following 5 Users Say Thank You to jawi For This Useful Post: |
05-26-2014, 23:49 | #6 (permalink) | |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Quote:
Not your concept. Now enjoy this update. Have a nice day! Br, ARD | |
The Following 3 Users Say Thank You to .::ARD::. For This Useful Post: |
05-27-2014, 01:27 | #8 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: GSM World!! Age: 35
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | Error In Disable RTAS BB8520? Device Info: PIN: 2135b5ee Bootrom Version: 5.6.0.20 Hardware ID: 0x8C000F03 RIM BlackBerry Device HW ID Override: None OS ID: None Supported Bands: 0x000F Metrics Version: 6.9 Build Date: May 13 2009 Build Time: 13:25:04 Build User: rdagg Security: Enabled Supported Options: 0x00000003 Drivers: 0x00000004 Processor: 0x00000001 LDR Blocks: 0x87FEB474 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x05 CPU Version 0002 - 0x32 SW Compatibility 0003 - 0x01 POP Revision 0004 - 0x03 Power Mgt Hardware 0007 - 0x27 POP Security 000B - 0x01 Mem Config Table (ver 1.16): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1983 OS NV: blocks 1984-2000, total 17 CRC: 0xBE91091F Flash: Number of chips: 1 Flash ID: NAND blocks 0-2020 Device ID: 0x44 Vendor ID: 0xEC Version ID: 0 Total Size: 252.6 MB Memory Map: NAND Blocks: 2021 * 128 Kb RAM Base: 0x80000000 IRAM Base: no IRAM! OS Range: 2 - 85 File System: Memory Map: 86 - 1983 Sectors: 1898 Branding: VendorID: 214 OS Version: 4.2.0.15 Hardware ID: 0x8C000F03 RIM BlackBerry Device Supported Bands: 0x0000FFFF Metrics Version: 3.16 FS Code Version: 10.0.0.0 FAT Code Version: 2.18 Package Version: "" Build Date: Jul 6 2011 Build Time: 18:17:30 Build User: SCM SV Number: 1 OS Address: 0x80000000-0x80A6478B App Start: * No Application Linked * Companion Binary: 0.0.0.0 RAM usage: 0x874FFFFC-0x87FFFFFC IRAM End: 0x4009E378 DSP ROM2 Address: *not present* OS Extended Addr: 0x809473D8 LDR Blocks: 0x80A2EC40 API Checksum: 0x00000000 JumpTable (<3): 0x80000310 JumpTable (>2): 0x80001F74 Radio Code: Orpheus radio code linked OS API Version: 109.40 STP Protocol Ver: 5.259.1 (factory OS) HWV: Board Revision 0001 - [0x01 - 0xFF], 0x01 POP Revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0x00 - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x01], 0x01 Power Mgt Hardware 0007 - [0x24 - 0xFF], 0x01 Version Table: OS API Version: 109.40 STP protocol version: 5.259.1 BlockFS API Version: 10.0.0.0 USB driver version: 02.01 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 NVSIG RTAS key: 1.0 FAT FS Version: 2.18 Block map version: 2.15 WLAN radio version: 2.5.0.73 Kernel Version: 1.11.0.273 Hardware ID: 0x8C000F03 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Jul 6 2011 Build Time: 17:26:13 Build User: SCM Preparing device, please wait.. Done Disable RTAS Failed!!!!!........................ What is This Error? Quote:
The Following User Says Thank You to resident2011 For This Useful Post: |
05-27-2014, 01:29 | #9 (permalink) |
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | OS6/7 [BB9300/9320] Is supported for Repair PIN or IMEI in This Update? OS6 [BB9300] Is supported for Repair PIN or IMEI in This Update? OS7 [BB9320] Is supported for Repair PIN or IMEI in This Update? Thanks in Advanced!!!!
05-27-2014, 01:37 | #10 (permalink) |
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | Factory OS & Normal OS .. Working In BB8520!!! Normal OS Tested!!! Connecting to Device in progress, please wait... Device [1] connected. GUID = 4FE721ECFCF30443AB3745DBDDEF68AA9093BA4A PIN = 2135B5EE Go to Normal OS in progress, please wait... Done |
05-27-2014, 02:02 | #13 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Singapore Age: 37
Member: 888712 Status: Offline Thanks Meter: 308 | Spookey team promises us many things but inside nothing ............... Why like that ?please explain us.spokey box is not free tool right ? Why they do like that ????????? .......???????? Last edited by mrrobin; 05-27-2014 at 02:10. |
