12-04-2017, 09:46 | #1846 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2485027 Status: Offline Thanks Meter: 14 | team help me Checking security of card... card error bad activation level...FE Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-09-03-22 Log Saved GCPro SN:= GC0B738514 card error bad activation level...FE Checking server connection... Enter registration details for GCPro... Checking card.. Please update Card before using activation.. Fail at activation please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-09-17-17 Log Saved |
12-04-2017, 10:09 | #1847 (permalink) | ||
Insane Poster Join Date: Sep 2007 Location: Dasmariņas,Cavite, Phillipines Age: 55
Member: 591269 Status: Offline Thanks Meter: 23 | What happen, yesterday it's working, but now update pop up..so i did but ends up problem: this is the first logs Quote:
[IMG][/IMG] when i try again to update this is the 2nd logs, says card is lock Quote:
12-04-2017, 11:24 | #1849 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Update tool GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GC98648013 GCPRO Activation := CARD IS ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-15-21-18 |
12-04-2017, 11:25 | #1850 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Checking GCPro Card Details... Checking server connection... GCPro SN GC98648013 Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Please do not make any other task Card Update Started... New Version of Card Not found after Load Contact support for help. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-15-22-11 |
12-04-2017, 11:25 | #1851 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | GCPro found... ERROR 0x1_islocked Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-15-23-50 |
12-04-2017, 11:28 | #1852 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan/UAE/WorldWide Age: 29
Member: 2488504 Status: Offline Sonork: 100.1663349 Thanks Meter: 210 | Help Checking GCPro Card Details... Checking server connection... GCPro SN GC2F7CA072 Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Invalid card sn... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-15-07-44 |
12-04-2017, 11:35 | #1853 (permalink) |
No Life Poster Join Date: Sep 2004 Location: srbija Age: 49
Member: 80567 Status: Offline Thanks Meter: 53 | Checking GCPro Card Details... Checking server connection... GCPro SN GC84AE45E6 Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card error fail to start security session....6982 Fail to start security session,This CARD CAN NOT be updated,DO NOT TRY MORE.. Fail at verification... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-11-30-54 I have problem and I get ansver from support that I must replace card.... I cant believe, because its not my mistake.. Can you make solution to update card wbr P.S I also have same problem with update 55 and after help gc support everything be fine |
12-04-2017, 11:35 | #1854 (permalink) |
Junior Member Join Date: May 2017
Member: 2718991 Status: Offline Thanks Meter: 0 | help Checking GCPro Card Details... Checking server connection... Please check your internet connection...0 Please check your internet connection...0 GCPro SN GCB329AE2D Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Please do not make any other task Card Update Started... Please check your internet connection...0 Please do not REMOVE CARD or Power off PC.. Please check your internet connection...0 BACKUP OF NEW CARD IS SAVED.. !!! PLEASE COPY AT SAFE PLACE !!.. Backup Created.. Fail to report server card details.. please contact support.. do not delete or lost this log. Please check your internet connection...0 Fail to restore old card details contact support DO NOT TRY AGAIN... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-11-28-07 |
12-04-2017, 11:47 | #1855 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @lsuarez1977 Hello Please re download latest update. Please update your gcpro now and then register its solved. @samuel1003 Hello Contact me over skype look link you did not followed steps explained here.http://forum.gsmhosting.com/vbb/12819406-post2.html @adnastar Hello This card can not be updated.Contact reseller or GPG sales for replacement. http://forum.gsmhosting.com/vbb/12819945-post41.html @Imdad1 Hello This card can not be updated.Contact reseller or GPG sales for replacement. http://forum.gsmhosting.com/vbb/12819945-post41.html @mtp1711 Hello Your issue is already solved via skype. @shak_jon Hello Please re download latest update. Please update your gcpro now and then register its solved. @demonpyn Hello Contact me over skype @novin1234 Hello Please re download latest update. Contact reseller tell him to add in server. @harvindar Hello Contact me over skype look link you did not followed steps explained here.http://forum.gsmhosting.com/vbb/12819406-post2.html @asad.rana Hello Read steps carefully http://forum.gsmhosting.com/vbb/12819406-post2.html @datu Hello Contact me over skype |
The Following User Says Thank You to stanner_austin For This Useful Post: |
12-04-2017, 11:57 | #1856 (permalink) |
Insane Poster Join Date: Dec 2007 Location: india
Member: 666259 Status: Offline Thanks Meter: 28 | GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GCEB921474 GCPRO Activation := CARD IS ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-16-19-29 |
12-04-2017, 11:58 | #1857 (permalink) |
Member: 666259 Status: Offline Thanks Meter: 28 | Checking GCPro Card Details... Checking server connection... GCPro SN GCEB921474 Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-16-24-26 |
12-04-2017, 13:21 | #1859 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2130320 Status: Offline Sonork: [email protected] Thanks Meter: 9 | gc pro update error help me sir GCPro SN GC16B7E60A Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-17-44-00 Log Saved |
12-04-2017, 14:11 | #1860 (permalink) |
