12-05-2017, 03:48 | #1921 (permalink) |
Registered User Join Date: Jul 2010 Location: Kingston, Jamaica
Member: 1348820 Status: Offline Thanks Meter: 11 | Checking server connection... GCPro SN GCF8632DAC Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Invalid card sn... Job finish and when i try to open software i get this error "Card not Found..... Error 33111" . "update 58" is now obselete so i cannot use that instead of "update 59" as i did yesterday so now my dongle has no use untill a working solution is posted. It would be really profiting and stress free if the team can come up with quick and working solution in a few hours or maybe days if thats the case. Or it would also be ok if the team would allow us (the people that are having problems with update 59) to continue to use update 58 untill a working solution is released, that way people successfully using update 59 and people using update 58 because of updating errors will still have access to there GCPRO instead of having it as a no purpose tool. this is just my opinion of keeping customers satisfied untill they all are on the same path because i am one person with a sleeping gcpro box. thank you looking forward to permanent solution. |
12-05-2017, 03:50 | #1922 (permalink) |
Junior Member Join Date: Mar 2015 Location: H.Matamoros, Mexico
Member: 2357113 Status: Offline Thanks Meter: 2 | Checking GCPro Card Details... Checking server connection... GCPro SN GC Card OsVer 0000 Invalid card sn... Fail to update security details contact support DO NOT TRY AGAIN... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-20-50-43 Log Saved |
12-05-2017, 04:43 | #1923 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Dominican Republic Age: 36
Member: 1993261 Status: Offline Sonork: 100.1678139 Thanks Meter: 66 | please help 2 pc some problem Checking GCPro Card Details... Checking server connection... GCPro SN GCD16030DC Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Fail to start error := 2 Please install JAVA before update & restart computer before using. https://java.com/en/download/ error := Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...04-12-2017-19-41-56 Log Saved Last edited by stanner_austin; 12-05-2017 at 11:05. Reason: quote removed |
12-05-2017, 05:42 | #1924 (permalink) | |
Junior Member Join Date: Dec 2008
Member: 924461 Status: Offline Thanks Meter: 0 | Quote:
Same issue after Updated to 59. Please hlep,thanks | |
12-05-2017, 07:20 | #1925 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2590103 Status: Offline Thanks Meter: 0 | Help please, i need my gcprokey working, need unblock some phones Checking server connection... Server access ok.. Making sure card is locked or not.. ERROR 0x1_islocked Reading Details.. Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. GCPro SN := GCC025A9F3 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-00-07-45 |
12-05-2017, 08:37 | #1926 (permalink) |
Crazy Poster Join Date: Jan 2008
Member: 669307 Status: Offline Thanks Meter: 6 | have same pbGCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GCB26FB216 GCPRO Activation := CARD IS ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-08-33-26 Log Saved |
12-05-2017, 09:04 | #1927 (permalink) |
Member: 669307 Status: Offline Thanks Meter: 6 | solution here my one goodMake sure latest Java installed in pc if not use this link to install it. https://java.com/en/download/ |
12-05-2017, 09:56 | #1928 (permalink) |
Insane Poster Join Date: Apr 2017 Location: Albania
Member: 2703335 Status: Offline Thanks Meter: 22 | i need help PLZ! Checking GCPro Card Details... Checking server connection... GCPro SN GCXXXXXX Card OsVer 0002 Checking security of card... CARD IS LOCKED CONTACT SUPPORT.. Card crypto verify ok.. Please do not make any other task Card Update Started... Card is not Allowed to UPDATE Contact reseller or GCPro_Team for more help.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-09-49-41 Log Saved |
12-05-2017, 11:53 | #1929 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Chang Alvarez Hello Please Re download latest update59 again, Use update tool and update card again. @rodny19 Hello Already solved via skype. @Elmoursi Hello Please Re download latest update59 again, Use update tool and update card again. @rubenzt Hello Please Re download latest update59 again, Tell your reseller to add in server for register allowed. @kikiperez Hello Please Re download latest update59 again, Use update tool and update card again. @kingsley32 Hello Please Re download latest update59 again, Use update tool and update card again. @all other who hide there serial. Please post correct log. Find last failed to update log copy it. download latest update 59 again without delete anything. Read gcpro details and post both log here. If you can not understand English please ask your reseller or any person who can understand English more better. |
12-05-2017, 13:36 | #1930 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Quote:
Code: Checking GCPro Card Details... Checking server connection... GCPro SN GC0DBB9D15 Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Please do not make any other task Card Update Started... Please do not REMOVE CARD or Power off PC.. fail with 6982 BACKUP OF NEW CARD IS SAVED.. !!! PLEASE COPY AT SAFE PLACE !!.. Backup Created.. Seed:= HcfZCQUwCAXRlty9fkZj+i/pLQwcmF3KuELv6Gs2E5ZReJQbfv8KwkH4yry1g/U2D45j+tI1Lp1M3l1tCQwmCeWFvN5I+Uc449HoJAU563wA Fail to update security 3... Fail to restore old card details contact support DO NOT TRY AGAIN... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...03-12-2017-13-27-36 Log of read info after update failed: Code: GCPro found... Card verify ok... Card OsVer 0000 GCPro SN:= GC1438DC64 GCPRO Activation := NOT ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...03-12-2017-13-33-08 Log after download again update 59 Code: GCPro found... Card verify ok... Card OsVer 0000 GCPro SN:= GC1438DC64 GCPRO Activation := NOT ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-08-34-13 Log Saved | |
12-05-2017, 14:11 | #1931 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2541692 Status: Offline Thanks Meter: 0 | porque dice eso mi dongle esta nueva Card verify ok... Card OsVer 0002 GCPro SN:= GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. Please update Card before using activation.. Fail at activation please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-09-01-21 Log Saved Last edited by luiyi; 12-05-2020 at 04:45. |
12-05-2017, 14:50 | #1933 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: Dominican Republic
Member: 2235918 Status: Offline Thanks Meter: 127 | Quote:
12-05-2017, 15:17 | #1934 (permalink) |
Crazy Poster Join Date: Apr 2012 Location: ETHIOPIA
Member: 1744601 Status: Offline Thanks Meter: 43 | Checking GCPro Card Details... Checking server connection... GCPro SN GCC879EADB Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE Card crypto verify ok.. Please do not make any other task Card Update Started... New Version of Card Not found after Load Contact support for help. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...05-12-2017-16-59-02 |
12-05-2017, 15:18 | #1935 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: San Luis Potosi, Mexico
Member: 2109200 Status: Offline Thanks Meter: 40 | Quote:
According to stanner he says we can think whatever we want and it is not his problem .- so we are the idiots for updating card Sent from my iPhone using Tapatalk | |
