10-28-2015, 16:13 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Belize
Member: 803361 Status: Offline Thanks Meter: 132 | Help write cert G925P ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Model := SM-G925P UNIQID := 03157DF315771B3 Phone IMEI := null/empty Default MSL NO NEED RESET EFS... MSL autho fail Reset EFS or RESET MSL & Retry Please...pY9LCoBADEOvZNRmxqX4uca7/y10RgUFXQkhFJq0SaxERgsaiTofrAFNqEcdacAJryQaZNTgItg pk5aHz3FhwjNucYd3g7Drmf7Xdrx9eMOZNX9lVemUYwM= !!! FAIL !!!! Total Time Take...00:00:15 Log Saved |
10-28-2015, 16:49 | #2 (permalink) |
Member: 803361 Status: Offline Thanks Meter: 132 | This is how my status look inside *#0011# Cert says Failed, can we fix to sucess http://imgur.com/5WqdKoM |
10-29-2015, 10:02 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @visions2008 Hello If you have G925P cert use MEID CERT WRITE option with UART cable.. All details help in update27\helpfile\how to write meid cert Read it once.. |
03-04-2016, 18:55 | #5 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 712887 Status: Offline Sonork: gokuu2011 Thanks Meter: 349 | Quote:
you try write certificate g925a/i/t on g925p is totally wrong, sprint is qualcom and used key id 0449. | |
06-30-2016, 15:08 | #13 (permalink) |
Freak Poster Join Date: Jan 2015 Location: La Habana, Cuba
Member: 2324261 Status: Offline Thanks Meter: 117 | i have g925p cert i have a g925p cert, i share if anybody tell me how to written the cert correctly.. because i write with octoplus etc but IMEI CERTI FAIL and the phone doesnt have signal.. |
06-30-2016, 16:11 | #14 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @armandogarriga Hello It will be lot easy if you start reading helpfiles. ENABLE UART WITHOUT ROOT NEED to dial *#0*# plug c3303k cable if plunged already remove and re plug. Select box port any model from list. Use MEIDCERT Write press start. Select cert file wait till process finish. |
06-30-2016, 16:53 | #15 (permalink) |
Member: 2324261 Status: Offline Thanks Meter: 117 | Hello Stanner and thanks for reply to my answer..but nothing I Dial ... the phone go to a white screen with sensors etc ... , i plug cable (i try z3x and octoplus as interface), use meidcert, press start but error Phone Not Found Retry Please. Enter *#7284# select UART > PDA Enter *#0808# select AP > MTP+ADB MUST USE UART C3303K !!!RJ45 CABLE!!! ON ALL NEW SAMSUNG DEVICES. DIAL *#0*# AND TRY AGAIN... !!! Fail !!!! Total Time Take...00:00:03 Log Saved |
