03-20-2018, 21:30 | #1 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1926856 Status: Offline Thanks Meter: 1 | How do i Direct unlock Samsung G530T with GCPRO i select the "ask/rpl" option. What are the options i should choose to get this done? |
03-21-2018, 09:52 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @darkchild7 Hello If you have credits just use tick mark on top USE SERVER. and it will be direct unlocked. Its already explain in http://forum.gsmhosting.com/vbb/f922...tions-1838017/ and http://forum.gsmhosting.com/vbb/f922...nlock-2300486/ some time we need to read carefully. |
03-21-2018, 20:14 | #3 (permalink) | |
Member: 1926856 Status: Offline Thanks Meter: 1 | Quote:
03-22-2018, 10:00 | #4 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @darkchild7 Hello GCPro charge only credit if successful and create backup of RPL in same pc. In case if you try again it will ask you to use WRITE RPL option not ask read it will refuse to read ask if RPL is exist so credit won't be double charged. Unless its network issue your or server side this can not be happen but we are here to help show me log of phone like readinfo adb or your gcpro sn so i can check and refund you if need. |
03-26-2018, 12:47 | #5 (permalink) | |
03-26-2018, 13:11 | #6 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @darkchild7 Hello You try to unlock phone 2 time even after RPL is created. imei 35xxxx2581 done correctly first try. Once RPL is created only use NO option on ASK/RPL to write RPL do not make ASK read again it will be charged every time you do. We added check on RPL if exist it will continue ask read unless you deleted RPL this won't happen.. 4dxx9b refunded this time won't be possible next time if you do mistake your self. |
03-26-2018, 13:16 | #7 (permalink) | |
