08-03-2018, 09:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | J327t cert backup fail Selected Port SAMSUNG Mobile USB Serial Port COM446 Selected Model GT-I5500 Selected Task SAMSUNG Exynos Unlock SAMSUNG Exynos Unlock started... Searching phone... Device Detected... SELinux := Permissive model:= SM-J327T ANDROID-ID = 42007965d4705407_0000710DF5 Phone Found Please Wait... Version := J327TUVS2ARC1 CHIPID := 03050000 Can not detect security Unsupported Phone for exynos unlock...1 !!! Fail !!!! Total Time Take...00:00:26 |
08-03-2018, 10:41 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Aamir_Zia Hello As you can see log. and if you search bit in forum you can already find answer. As for unlock you do not need flash or root.. just select correct option for example tmobile unlock with use server tick.credits will be charged as per http://forum.gsmhosting.com/vbb/f922...018-a-2371739/ |
08-03-2018, 11:09 | #3 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | DRK problem in phone ... so in order to repair DRK i have to apply EXYNOS EFS RESET but first IMEI BACKUP is necessary . |
The Following User Says Thank You to Aamir_Zia For This Useful Post: |
08-03-2018, 11:12 | #4 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Aamir_Zia Hello Exynos unlock over diag exploit closed in RA firmware if you use search a bit you can find that explained.. flash combination may help on this case. make sure using U2 rev only. What is problem to repair drk without exynos efs reset ? why you not posted that log ? |
08-03-2018, 13:23 | #8 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | with Combination Firmware U2 Using Version...1.0.0.0058 Selected Port SAMSUNG Mobile USB Serial Port COM27 Selected Model GT-I5500 Selected Task SAMSUNG Exynos Unlock SAMSUNG Exynos Unlock started... Searching phone... Device Detected... SELinux := Permissive model:= SM-J327T ANDROID-ID = 4200b3d5ee522453_000024271F Fail to detect phone Please make sure diag port is selected....1 !!! Fail !!!! Total Time Take...00:00:24 Log Saved with STOCK FIRMWARE U2 Using Version...1.0.0.0058 Selected Port SAMSUNG Mobile USB Serial Port COM446 Selected Model GT-I5500 Selected Task SAMSUNG Exynos Unlock SAMSUNG Exynos Unlock started... Searching phone... Device Detected... SELinux := Permissive model:= SM-J327T ANDROID-ID = 42007965d4705407_0000DB8D78 Phone Found Please Wait... Version := J327TUVS2ARC1 CHIPID := 03050000 Can not detect security Unsupported Phone for exynos unlock...1 !!! Fail !!!! Total Time Take...00:00:26 Log Saved |
08-03-2018, 13:28 | #9 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | DRK Repair error without EXYNOS EFS RESET Using Version...1.0.0.0058 Selected Port USB Serial Port COM11 Selected Model GT-I5500 Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... Phone Found Wait... TEST MODE OK.. Details. SM-J327T,REV0.1,FA70_J327TUVU2ARC2,FA70_J327TUVU2ARC2 ,J Model := SM-J327T SWVer := FA70_J327TUVU2ARC2 UNIQID := CQ300B3D5EE5224 Phone IMEI := 35560308638952 Phone MEID := 35560308638952 MSL Address:= R28J504WRN ROOTKEY FAIL..fYxLDoAgEEOvxAhOdclHrvHufwsEVm5MmpemaRszsaGC OnH5TVV0I0OOdyT0YJVAnm1Pc/DKD9zRiRJWPhdh9xfa32jmRroG !!! Fail !!!! Total Time Take...00:02:34 Log Saved |
08-03-2018, 13:48 | #10 (permalink) | |
Freak Poster Join Date: Apr 2016 Location: the boss of samsung
Member: 2558211 Status: Offline Thanks Meter: 90 | for the info Quote:
08-03-2018, 17:04 | #12 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | for test bro if sure https://mega.nz/#!MCBmnKyZ!wZRqIyOZW...okBLhcJTKFujgY ITS rc2 combo modem bro. |
08-03-2018, 17:50 | #13 (permalink) | |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Quote:
still same error in cert backup Using Version...1.0.0.0058 Selected Port SAMSUNG Mobile USB Serial Port COM446 Selected Model GT-I5500 Selected Task SAMSUNG Exynos Unlock SAMSUNG Exynos Unlock started... Searching phone... Device Detected... SELinux := Permissive model:= SM-J327T ANDROID-ID = 42007965d4705407_0000EB8770 Phone Found Please Wait... Version := J327TUVS2ARC1 CHIPID := 03050000 Can not detect security Unsupported Phone for exynos unlock...1 !!! Fail !!!! Total Time Take...00:00:26 Log Saved | |
08-03-2018, 18:09 | #14 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Error from Z3x ... Searching Samsung modem... detected COM447 Reading phone info... Model: SM-J327T AP version: J327TUVS2ARE1 CSC version: J327TTMB2ARE1 CP version: J327TUVS2ARC1 Product code: TMB Phone SN: R28J61FZL5X IMEI: 359617081381608 Unique number: CQ3007965D47054 Incorrect model selected. This may damage your phone. Continue? Yes Searching Samsung diag port... detected COM446 Reading phone info... OK CP version: J327TUVS2ARC1 CP build: Mar 2 2018 10:04:14 Reading data from phone... error (1) Done with Samsung Tool PRO v.33.5 |
08-04-2018, 08:57 | #15 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Aamir_Zia Hello If you already able to boot phone in stock why you want to repair DRK ? its already ok because stock boot phone fine. Also you doing method totally wrong. You need STOCK FIRMWARE and COMBINATION MODEM only to use diag exynos unlock. |
