07-16-2017, 10:52 | #1 (permalink) |
Insane Poster Join Date: Jul 2016
Member: 2598737 Status: Offline Thanks Meter: 4 | LG LS997 Unlock Success but not permanent and no data upload And here is the major issue, the mobile data upload does not work at all, it's 0 mbps all the time. I need some help to fix these issues. Here is the LOG: Using Version...1.0.0.0048 Selected Model LG Android Selected Task LG SPRINT UNLOCK Searching ADB device Please wait.. Device Detected... SELinux := Enforcing model:= LG-LS997 Androids Version:= 7.0 Description Version:= elsa_spr_us-user 7.0 NRD90M 171391546e1c2 release-keys Platform:= msm8996 [ elsa ] [ msm ] Baseband:= MPSS.TH.2.0.1.c3-00027-M8996FAAAANAZM-1.77269.3.79643.3 Factory Ver := LGLS997AT-00-VZV7-SPR-US-MAY-19-2017-ARB00+04 Model & Firmware Ver := LS997ZV7 Security Patch := 01-05-2017 Simstatus:= CARD_IO_ERROR ANDROID-ID = LGLS9972c3a39b7_0000B0D8A4 Device is not rooted LG Sprint Unlocking Started.. Please Wait while... Loader Ok Starting task... spc can't find.. Direct Unlock Success.. Restart Phone if not auto... Total Time Take...00:01:06 |
07-17-2017, 09:40 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @dorin1993 Hello GCPro LG Sprint unlock bug is closed by lg at 04-2017 google update. Most possible reason you won't get data bcs ITSON is ENABLE check via ##3282# view ITSON or via adb command getprop Team is working to get new solution its gona take time. About temp unlock its not GCPro unlock related.. Unlocking done same way as sprint do over air.. if your phone is never active or reset via 786 code you lost activation so unlocking is only stored as data not as permanent.. Before making LG Sprint unlock on supported version make activation via sprint sim. then unlock is permanent. |
The Following 4 Users Say Thank You to stanner_austin For This Useful Post: |
07-17-2017, 23:55 | #3 (permalink) | |
Freak Poster Join Date: Sep 2011 Location: El Salvador
Member: 1655844 Status: Offline Thanks Meter: 25 | Quote:
07-18-2017, 16:48 | #4 (permalink) | |
Member: 2598737 Status: Offline Thanks Meter: 4 | re Quote:
+1 to the comment above, I have the same issue on LG G6 | |
07-21-2017, 09:23 | #7 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @dorin1993 Hello This details say phone is unlocked with GCPro and should work with all data type. Check your APN etc for configuration i have no idea why you can't get data. |
07-21-2017, 11:58 | #8 (permalink) |
Member: 2598737 Status: Offline Thanks Meter: 4 | Issues present on multiple devices Well ... I have 4 different phones (G6 and x3 V20) - all of them were unlocked by Sprint unlock method and all of them have no data upload. It's not related to APN settings because I have tried 3 different sim cards from different operators, same issue everywhere. |
07-21-2017, 22:05 | #9 (permalink) | |
07-22-2017, 01:41 | #11 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Quote:
Try to change apn type to default Otherwise try 786 code or scrtn code and then unlock again Br Shahzaib Jahangir #Unlockerplus | |
The Following User Says Thank You to shahsoft For This Useful Post: |
07-22-2017, 09:33 | #13 (permalink) | |
Member: 2598737 Status: Offline Thanks Meter: 4 | Quote:
I did scrtn reset and it does not change anything + putting ipv4/ipv6 in apn settings also doesn't help. Also you can't activate the phone via sprint sim outside US as it will fail to register on network and the unlock will not be permanent. | |
07-22-2017, 10:02 | #14 (permalink) |
Member: 2598737 Status: Offline Thanks Meter: 4 | Forgot to mention that my LG G6 didn't have this problem with hands free activation before the reset, it was activated via sprint sim before as some of V20s and these unlock are not permanent in any case. |
07-23-2017, 14:12 | #15 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Really good info... Stanner, I was just wondering what does the ITSON feature do in simple terms? | |
The Following User Says Thank You to BillA For This Useful Post: |
