11-03-2016, 19:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | Looking for G928V G928A 6.0.1 ENG BOOT or sBoot for FRP Removal I am really looking for someone to share both G928V and G928A ENG BOOT, sBOOT, Combination File or something to remove FRP lock off this phone. I have tried searching forum and cannot find anything. I need file for 6.0.1 G928V and G928A. Thanks! DO not post on my thread asking me to PM you because you are trying to sell me file. If I wanted to buy the file I would have done so already. |
11-03-2016, 20:05 | #2 (permalink) |
Major Poster Join Date: Jul 2016
Member: 2597590 Status: Offline Thanks Meter: 18 | G928V FRP removal you dont need eng sboot or sboot from combination. just enable adb from maintenance menu on boot. G928AUCU3APH2 this is the file you need, no one is going to share it.. users rare share special files and read your post bother and im sorry but you only ask for favors, solutions and files please one day buy a file and share it. Last edited by cellshop183; 11-03-2016 at 20:12. |
The Following 3 Users Say Thank You to cellshop183 For This Useful Post: |
11-03-2016, 21:03 | #3 (permalink) | |
Member: 2146046 Status: Offline Thanks Meter: 62 | Quote:
11-03-2016, 21:31 | #4 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Quote:
Me also have but why me share ........ | |
11-04-2016, 15:42 | #5 (permalink) |
Member: 2146046 Status: Offline Thanks Meter: 62 | Ok so I am able to enable MAINTENANCE MODE and enable USB Debugging / ADB. I went to run FRP RMEOVE_ADB and phone is detected and FRP bypass works. But when I got to settings and hard reset the phone...FRP Lock is still ON. Any reason why this is happening? Can someone explain please? |
11-04-2016, 16:28 | #6 (permalink) |
Member: 2597590 Status: Offline Thanks Meter: 18 | after you go to setting, enable oem bootloader to disable frp. thats the reason ppl around dont help, too much typing for nothing |
The Following 2 Users Say Thank You to cellshop183 For This Useful Post: |
11-10-2016, 00:27 | #7 (permalink) |
Freak Poster Join Date: May 2015 Location: Los Angeles Age: 29
Member: 2400231 Status: Offline Thanks Meter: 124 | G928A PH2 ENG SBoot Flash PH2 Eng Sboot https://www.dropbox.com/s/5t5pprpvp2...sboot.bin?dl=0 Reset FRP through download mode Flash PHA sboot https://www.dropbox.com/s/m3zoygbfvx...sboot.bin?dl=0 That's it |
The Following 4 Users Say Thank You to CloseCOder For This Useful Post: |
11-10-2016, 14:55 | #9 (permalink) |
Member: 2146046 Status: Offline Thanks Meter: 62 | Thanks for your help everyone! I was able to remove them. I found easier method as well. For G928V I just flashed G928VVRU2AOJ2 5.1.1 downgrade firmware and can remove easy without any custom files. |
11-16-2016, 10:31 | #10 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pako new road,Nepal
Member: 257603 Status: Offline Sonork: 100.1605284 Thanks Meter: 147 | Device Detected... model:= SM-G928V Androids Version:= 6.0.1 Description Version:= zenltevzw-user 6.0.1 MMB29K G928VVRS3BPI1 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ mdm2 ] Baseband:= G928VVRS3BPI1 VER:= G928VVRS3BPI1/G928VVZW3BPI1/G928VVRS3BPI1/G928VVRS3BPI1 Carrier := VZW_USA Simstatus:= ABSENT ANDROID-ID = 0815f83bee1d1601_00000B9FDF Device is not rooted ANDROID FRP REMOVE STARTED... No ROOT FRP Bypass Started... !!! Success !!!! Restarted phone... Total Time Take...00:00:11 Log Saved |
03-10-2017, 03:38 | #13 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Just for clarification the above files are for G928A UCU3APHx That's for any bootloader version 3 (4th digit), and not only for UCU3APH2 or UCU3APHA Make sure to flash back the appropriate version sboot once done, which can be extracted from the stock tar. | |
The Following User Says Thank You to BillA For This Useful Post: |
05-17-2017, 21:01 | #14 (permalink) | |
Junior Member Join Date: Dec 2007
Member: 657517 Status: Offline Thanks Meter: 3 | sboot not working your sboot files does not work. please verify before post Quote:
05-21-2017, 11:39 | #15 (permalink) |
Member: 2400231 Status: Offline Thanks Meter: 124 | This Eng Sboot is for revision 4 bootloader for G928A https://www.dropbox.com/s/p9wce3qvkt...sboot.bin?dl=0 The sboot wont fully boot device, hence the stuck samsung galaxy logo with green writing. Only used to remove FRP from download mode. Then flash back stock sboot or reflash firmware |
