Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 01-17-2015, 14:04   #1 (permalink)
mediaextensions's Avatar
Member: 1123079
Sonork: 100.1586814
Thanks Meter: 439
Samsung SM-N910A Note 4 Done Sucessfully.
1. Wipe EFS Without ROOT ( Credit goes to jusmejose for this method )
Here is the method to wipe the EFS without Root.
i. Open dialer and dial *#9090#
ii. Press Menu Enter Q
iii. Press Menu and hit Back, After Enter Key 0000
Wait for couple of seconds.
You will be Prompted into MAIN MENU
iv. Select UE SETTINGS & INFO, SYSTEM, NV BACKUP TEST, ERASE ALL EFS1/2/3 and Select YES.
v. EFS WIPE is done without ROOT.
***Warning!!! I'm not responsible for anything that happens to your Device***
2. Write IMEICERT to your phone. (NB. Use UART Cable and remember battery trick.)
3. All is DONE , Phone is UNLOCKED
Also remember to back up QCN.
QCN Backup
Using Version...1.0.0.0012
Selected Port ssudserd0001 = COM11
Selected Model Samsung GSM
Selected Task SAMSUNG NV READ
Searching phone...
Prepairing Android first time use fix...
!!! Phone is in offline !!! ACCEPT CONNECT IN PHONE OR RECONNECT...
Device Detected...
model:= SAMSUNG-SM-N910A
Androids Version:= 4.4.4
Description Version:= trlteuc-user 4.4.4 KTU84P N910AUCU1BNK3 release-keys
Platform:= apq8084
Device Hardware:= qcom
Baseband:= N910AUCU1BNK3
PDA:= N910AUCU1BNK3
Simstatus:= ABSENT
CSC:= N910AATT1BNK3
SAMVER:= N910AUCU1BNK3
BOOT:= N910AUCU1BNK3
IMEI-1 = 356XXXXXXXXXXXXXX
IMEI-2 = null or empty
ANDROID-ID = 7382ce2a_356XXXXXXXXXXX
Device is not rooted
Build...MPSS.DI.3.0.c5-00300-M962
Please wait will we reading...
!!! Success !!!
Saved QCN..C:\Documents and Settings\mediagsm\Desktop\gcprokey 3\SAMSUNG-SM-N910A_N910AUCU1BNK3_7382ce2a17_01_15_10_49_04_AM_. qcn
All Finish...
Total Time Take...00:03:06
Uart Info After EFS Reset
Searching phone...
Phone Found Please Wait...
Details. SM-N910A,N,N910AUCU1BNK3,N910AUCU1BNK3,N910AUCU1BNK3, N,
Model := SM-N910A
UNIQID := CR2007382CE2A91
Phone IMEI := null/empty
Phone MEID := null/empty
Good Default MSL Add Found..
ROOT KEY GOOD..
SKEY := 0772
QCOM(QUALCOMM) detected..
IMEISIGN_FAIL..
Phone is SIM-Unlocked..
not detected lock status.
Reading Information Finish...
Total Time Take...00:00:30
Log Saved
Write IMEICERT
Selected Port VCP0 = COM14
Selected Task SAM CERT WRITE
ALL SAMSUNG CERT WRITE STARTED..
Searching Phone Please wait...
Phone Found Wait...
TEST MODE OK..
Model := SM-N910A
Default MSL found..
MSL Autho Pass..
Update IMEI Ok..
SKEY := 0772
Checking imeicert...
IMEISIGN PASS..
Update Simlock Ok..
Wifi_mac := F409D8DE9B6E
Wifi_mac update ok.
Update SerialNumber ok..
Fixing FTM ok..
Repairing finish...
!!! SUCCESS !!!!
Total Time Take...00:00:38
Log Saved
Regards ,
Mediaextensins.
The Following 5 Users Say Thank You to mediaextensions For This Useful Post:
Old 01-18-2015, 17:46   #2 (permalink)
Member: 955311
Thanks Meter: 241
But which box you use for write cert? As you said you use the uart cable. Tanks
Old 01-18-2015, 19:03   #3 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Hello
You can use any FTDI interface you have.
if you don't have then you can buy one from gpg with cable set too.
Regards
Chevli
GCPROKEY
Old 01-25-2015, 06:39   #4 (permalink)
Member: 2279734
Thanks Meter: 2
did you had signal issues ? can you share the QCN file ?
Old 01-27-2015, 04:38   #5 (permalink)
Member: 1591979
Thanks Meter: 25
Can you share this qcn or cer N910A ?
The Following User Says Thank You to hoangps For This Useful Post:
Old 01-27-2015, 22:58   #6 (permalink)
Member: 1984599
Sonork: PM For Sonork Id ;P
Thanks Meter: 37
Does this changes imei?
Old 01-28-2015, 18:50   #7 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
how did u root n910a ?
Old 01-29-2015, 19:52   #8 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Thank you for the credit ... I didn't wanted to release this stuff but I seen a lot people breaking their heads trying to wipe the EFS ... I also have another method with Odin just incase if the "Hidden Menu" gets patched by Samsung OTA
Old 01-29-2015, 19:53   #9 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Here is a clean QCN N910A I you guys need it ..
SM-N910A_MPSS.DI.3.0.c5-00300-M9625TAARANAZM-1.7892.2_26-1-2015_20-30-29
The Following 6 Users Say Thank You to jusmejose For This Useful Post:
Old 02-04-2015, 02:34   #10 (permalink)
Member: 2279734
Thanks Meter: 2
@JUSMEJOSE whats the right way to write this QCN ? do I have to wipe efs then write qcn then cert ? or just directly ? any help ? thanks
Old 02-04-2015, 22:25   #11 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
After you write your "IMEI Cert" load the "QCN"/
Or back your own QCN before you wipe "EFS" using "QPST,z3x,Octopus" or any dongle/Box that supports "QCN" BackUP/Restore ....
The Following User Says Thank You to jusmejose For This Useful Post:
Old 02-04-2015, 22:38   #12 (permalink)
Member: 955311
Thanks Meter: 241
you can't write by qpst may be cdma workshop work. Or z3x
Old 02-04-2015, 22:38   #13 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
**Note: Make sure is the correct model when loading the QCN , Because sometimes it will work and sometimes it wont!, I suggest if you just want to unlock just buy code "Online Server" this "IMEI cert" and "EFS: wipe is for Advanced users that that know what their doing, and if you have Unique "IMEI cert" ... Im not saying that your Dumb but you will save your self "Headaches" with your Customer ... **
Old 02-04-2015, 22:39   #14 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Yes you can ... If you get "Forced Closed" you must be doing wrong ...
Old 02-04-2015, 22:41   #15 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Yeah with CDMA workshop also ... If you know the "Memory Address"
Page generated in 0.24617 seconds with 8 queries
