12-08-2017, 17:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | ** NOTE 8 - Cert Write & UNLOCK using GCPRO !! ** ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Details. SM-N950W,MSM8998.00,N950WVLU2BQJA,N950WVLU2BQJA,N950W VL Model := SM-N950W UNIQID := CE0617XXXXXXXX Phone IMEI := 352919XXXXXXXXX Device Knox Warranty is := Not Void MSL Address:= R38F8XXXXX Local msl-db found.. MSL CODE Found using it.. MSL Autho Pass.. Update IMEI Ok.. SKEY := 0778 QCOM(QUALCOMM) detected.. Checking imeisign... IMEI-1 SIGN PASS.. Update Simlock Ok.. Wifi_mac := DCEFCAXXXXX Wifi_mac update ok. ROOT KEY GOOD.. Fixing FTM ok.. Sync Backups... Repairing finish... !!! SUCCESS !!!! Total Time Take...00:01:58 Log Saved Note - Gcpro / Stanner do not provide cert or msl at the moment. DO NOT ASK!! its just posted to show that GCPRO can write certs on Note 8. |
The Following 8 Users Say Thank You to ysr84 For This Useful Post: |
01-11-2018, 12:49 | #6 (permalink) | |
Junior Member Join Date: Nov 2013 Location: Định Quán,VN
Member: 2057842 Status: Offline Thanks Meter: 5 | Quote:
01-13-2018, 00:45 | #8 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
The Following User Says Thank You to CHANDARAKK For This Useful Post: |
01-13-2018, 12:45 | #9 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Yeah I've seen that a while ago, but they don't specify which pins the resistors go in between. Anybox is a just an interface box, basically it applies the resistor depending on cable and function. By knowing the cable pinout I could build my own resistor cable. | |
01-14-2018, 00:39 | #10 (permalink) | |
so how ur cable build with reistor it work? | |
01-16-2018, 00:51 | #13 (permalink) | |
It works but needs a specific resistor value between 2 pins (looks like ground and CC(1)) but needs confirmation. Forget about trying to write, first test it by using any terminal and send command "AT" and you should get an "OK", otherwise it won't work no matter what you do. I have also noticed that when flashed with combi firmware, AT write works even through regular usb. | |
