03-15-2016, 15:38 | #1 (permalink) |
Insane Poster Join Date: May 2015
Member: 2394513 Status: Offline Thanks Meter: 8 | PROBLEM samsung s6 g920p no signal after update android 6 |
03-20-2016, 04:50 | #6 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Simple solution enable all option in mobil network-roamming enable 4 options ,work for me |
The Following 6 Users Say Thank You to maxpatri9 For This Useful Post: |
03-21-2016, 14:06 | #11 (permalink) |
Member: 2394513 Status: Offline Thanks Meter: 8 | this problem is a little weird but i find a fix... 1. get the spc/msl with gcprokey for an unknown reason the gcprokey get the spc/msl from android 6 but not on android 5.1.1 2. make a downgrade to android 5.1.1 3 in settings get the menu activate this device on the menu press two times volume up and 3 times volume down you will get a menu with choices...select th one that says ##rtn## press reset enter the msl/spc you get 4. when the process finish you will get your phone debrading you need to reconnect to gcprokey and unlock it again .... 5. this fix prevent the phone to get updates from sprint and by the way is a fix for the no signal issue any questions post it here |
The Following 2 Users Say Thank You to w1n73rf3ll For This Useful Post: |
03-21-2016, 14:44 | #12 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @w1n73rf3ll Hello Read document in helpfiles\akey_spc_helpfile If sprint unlock do not show spc its not mean GCPro can not read spc. |
03-21-2016, 14:58 | #13 (permalink) |
Member: 2394513 Status: Offline Thanks Meter: 8 | @stanner_austin you mistaken my words!... gcprokey get the spc/msl is the phone is rooted! this happen on android 5..... but i see ... in android 6 not need to be rooted to get the spc/msl for that reason i post this guide |
03-21-2016, 15:02 | #14 (permalink) |
Member: 2394513 Status: Offline Thanks Meter: 8 | @stanner_austin see this log Device Detected... model:= SM-G920P Androids Version:= 6.0.1 Description Version:= zerofltespr-user 6.0.1 MMB29K G920PVPU3CPB6 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ mdm2 ] Baseband:= G920PVPU3CPB6 VER:= G920PVPU3CPB6/G920PSPT3CPB6/G920PVPU3CPB6/G920PVPU3CPB6 Carrier := SPR_USA Network Mode := 3 Simstatus:= READY IMEI-1 = null or empty ANDROID-ID = 04157df493242d09_00007985EA Device is not rooted SAMSUNG ALL SPRINT UNLOCKING STARTED... Checking Data... Waiting for Loader... Loader Ok... Direct Unlock Success... MSL/SPC IS := 496486 |
03-21-2016, 16:30 | #15 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | againg i do that 1-settings 2-mobil network 3-data roaming 4-on all options in data roaming ,this is all if the phone are unlock for gsm |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
