04-12-2018, 17:22 | #1 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2353137 Status: Offline Thanks Meter: 3 | Problem unlocking S550TL gcpro(SOLVED) Using Version...1.0.0.0056 Selected Port SAMSUNG Mobile USB Serial Port COM24 Selected Model GT-I5503 Selected Task SAMSUNG Exynos Unlock SAMSUNG Exynos Unlock started... Searching phone... Device Detected... SELinux := Enforcing model:= SM-S550TL ANDROID-ID = 920128d94a02240f_0000B7BAB2 Phone Found Please Wait... Version := S550TLUDU1APG1 CHIPID := 03080000 Hmac Verify ok..1 Phone is Locked.. Unsupported code data... Bad data imei..skiping.2 !!! Success !!!! Total Time Take...00:02:09 Says success but it's still locked, invalid sim card I've tried with 2 different phones and 2 different pc's and the same result. Regards |
04-12-2018, 19:51 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @brokench0rd Hello Exynos unlock can be used 2 way. One is MODEM PORT where its use old exploit. will direct unlock or read code depend on what you select. Second is Exynos DIAG PORT where its use new exploit. will read code if possible and cert. For such model use MODEM PORT. *#0808# MTP,ADB |
The Following 3 Users Say Thank You to stanner_austin For This Useful Post: |
04-13-2018, 00:54 | #3 (permalink) | |
Member: 2353137 Status: Offline Thanks Meter: 3 | Quote:
I've selected the diagnostic port "SAMSUNG Mobile USB Serial Port" generated with that method and i previously did some with that way, i don't why i can't now. Or it has any relation with the new version, i will try with the modem and i'll post the results. Regards | |
04-13-2018, 01:28 | #4 (permalink) | |
Thanks again Stanner, GCPro always GCBest. Regards | |
