04-22-2017, 21:22 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: 574 Age: 31
Member: 2567774 Status: Offline Thanks Meter: 255 | SM-N920T Cert_Write Success + DRK repair Full repair Flash Noble Kernel just for Permissive mode root in Odin AP slot: (this Old Kernel Root is only temporary in these steps and has been tested on 5.1.1 firmware, see Step 5) <ID:0/007> Added!! <ID:0/007> Odin engine v(ID:3.1101).. <ID:0/007> File analysis.. <ID:0/007> SetupConnection.. <ID:0/007> Initialzation.. <ID:0/007> Get PIT for mapping.. <ID:0/007> Firmware update start.. <ID:0/007> SingleDownload. <ID:0/007> boot.img <ID:0/007> NAND Write Start!! <ID:0/007> recovery.img <ID:0/007> RQT_CLOSE !! <ID:0/007> RES OK !! <ID:0/007> Removed!! <ID:0/007> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) Noble Kernel .Tar for Odin: https://drive.google.com/open?id=0B4...UNxZDJzelZvVDg 2. Reset EFS Place in Download mode and connect USB, Samsung Modem port Select EXYNOS EFS Reset Using Version...1.0.0.0044 Selected Port ssudmdm0000 = COM7 Selected Model SM-N920T Selected Task SAMSUNG ExynosEFS RESET Searching phone... Device Found.. MODEL=SM-N920T;UN=0715F719032D2532;CAPA=32;VENDOR=SAMSUNG;F WVER=0301;PRODUCT=KLUBG4G1BD-E0B2;PROV=PASS; Init ok.. Samsung Exynos EFS Reset Success.. Samsung Exynos CPEFS Reset Success.. !!! Success !!!! Restart Phone if not auto... Total Time Take...00:00:32 Log Saved 3. Prepare Cert Write Most case KNOX = 1 Void after root (less use other root or file) so use Bypass_KNOX under Samsung tab to prepare cert write operation. Make sure USB debug is on. Using Version...1.0.0.0044 Selected Model SM-N920T Selected Task SAMSUNG Bypass Knox ADB Searching ADB device Please wait.. Device Detected... model:= SM-N920T Androids Version:= 5.1.1 Description Version:= nobleltetmo-user 5.1.1 LMY47X N920TUVU2COI5 release-keys Platform:= exynos5 [ samsungexynos7420 ] [ SHANNON333 ] Baseband:= N920TUVU2COI5 VER:= N920TUVU2COI5/N920TTMB2COI5/N920TUVU2COI5/N920TUVU2COI5 Carrier := TMB_USA EFS CSC := TMB Network Mode := 0 Simstatus:= ABSENT BusyBox version := 1.23.2 ANDROID-ID = 0715f719032d2532_0000CA60A0 Detected su binary at /xbin type1 root exploit possible. SU Version..2.79:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... SAMSUNG Bypass Knox started... Please Wait while... Loader Ok Starting task... !!! Success !!!! Repair imeicert,meid cert,imei repair etc now without restarting phone... Total Time Take...00:00:39 4. Write IMEI Cert *This method used box with UART c3303k cable. If have box: Dial *#0*# keep phone unplugged for now. Select correct box com port. Select Sam Cert Write and wait till you see searching phone in the log box and connect UART cable quickly. If have dongle of GC Pro: only use USB and select IMEICERT Write USB and scan to select modem port Select Valid Cert file for this model. (you can check with CERTFILE_Verify at bottom of list. Must know SKey ID number) Using Version...1.0.0.0044 Selected Port VCP0 = COM3 Selected Model SM-N920T Selected Task SAM CERT WRITE ALL SAMSUNG CERT WRITE STARTED.. Searching Phone Please wait... Phone Found Wait... TEST MODE OK.. Details. SM-N920T,N,N920TUVU2COI5,N920TUVU2COI5,N920TUVU2COI5, N, Model := SM-N920T UNIQID := 0715F719032D253 Phone IMEI := 00000000000000 Device Knox Warranty is := Void Default MSL NO NEED RESET EFS... MSL Autho Pass.. Update SerialNumber ok.. Update IMEI Ok.. SKEY := 0448 EXYNOS Type Detected.. Checking imeicert... IMEI-1 CERT PASS.. Update Simlock Ok.. Wifi_mac := EC1F72957E8B Wifi_mac update ok. ROOT KEY NOT GOOD.. Fixing FTM ok.. Repairing finish. !!! SUCCESS !!!! Total Time Take...00:00:36 Log Saved 5. Fix DRK and flash over full firmware Notice if Root Key is shown Not Good in the cert write log. It was bad, so again we will use box port with UART cable in this method to fix DRK. Dial *#0*# press start with DRK_Repair, plug cable when it shows log moving. If no box: Use DRK_Repair_ADB via USB cable. Using Version...1.0.0.0044 Selected Port VCP0 = COM3 Selected Model SM-N920T Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... Phone Found Wait... TEST MODE OK.. Details. SM-N920T,N,N920TUVU2COI5,N920TUVU2COI5,N920TUVU2COI5, N, Model := SM-N920T UNIQID := 0715F719032D253 Phone IMEI := 35312007****** Phone MEID := 35312007****** Default MSL NO NEED RESET EFS... ROOTKEY IS NOW GOOD.. !!! Success !!!! Total Time Take...00:00:52 Log Saved Place in Download mode and flash stock firmware set in Odin or upgrade to a new Rev version. SEAndroid will be back to Enforcing and stock with your chosen firmware. Factory reset could be recommended after flash. DONE with trusty GC PRO Box! |
The Following 2 Users Say Thank You to Stunman112 For This Useful Post: |
04-22-2017, 21:32 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello You explained well but many solution is missed. 1) you do not need root if u gona use exynos efs reset. u can skip cf auto. 2) bypass knox & exynos efs reset can be skip if you use imeicert write ADB. may not work at 02-2017 or newer baseband at moment. 3) old basebands 08-2016 or older do not need root,do not need exynos efs reset, just use exynos unlock & imeicert write usb. no drk damage or warrnty void. |
The Following User Says Thank You to stanner_austin For This Useful Post: |
04-22-2017, 22:52 | #3 (permalink) | |
Member: 2567774 Status: Offline Thanks Meter: 255 | Quote:
