01-22-2017, 19:06 | #1 (permalink) |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Unlock for J320VPP, for use GSM. Easy steps With this intall and odin 3.11.1 you will not have problems. This intall ok Finish the start wizard and Done Now you can use your hpone with any GSM carriers. But it does not work on all frequencies, check first. https://mega.nz/#!MQtiDTrZ!NmVJ7RM0f...P6m8THRQLyJQRw If you wanna stop the verizon notification just install "Package Disabler Pro_7.0" You can disable the system processes and Work without root https://mega.nz/#!oJlWjR6S!mfUzAwP3J...bOHmJ3bgjfK4iU |
The Following 36 Users Say Thank You to Alexandroid For This Useful Post: |
01-23-2017, 04:07 | #2 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
The Following 4 Users Say Thank You to CHANDARAKK For This Useful Post: |
01-23-2017, 04:24 | #3 (permalink) |
Member: 2395490 Status: Offline Thanks Meter: 515 | I don't know exactly. Right now I know that don't work in Cuba GSM 900 Work in Texcel Mexico Work in USA Carriers like T-mobile, Cricket. But it work for GSM. The method is basically to change the firmware and convert the phone in a j320V. |
The Following 5 Users Say Thank You to Alexandroid For This Useful Post: |
01-26-2017, 20:51 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | Hello In my country Cuba the frequency of the GSM network is 900Mhz. After this process the GSM network appears in the menu but does not pick up signal. Could you make any modifications that make it possible to add the band of 900 Mhz? Thank you mfeliu07 |
The Following User Says Thank You to mfeliu07 For This Useful Post: |
02-18-2017, 16:11 | #5 (permalink) |
Freak Poster Join Date: Mar 2012 Location: the moon
Member: 1740779 Status: Offline Thanks Meter: 143 | Worked perfectly had no issues at all and picks up all frequencies including 900Mhz which is Digicel in El Salvador. Didn't need the second file because at setup i activated over wifi with an original Verizon SIM so I never got any notices, at least that's my assumption as to why I didn't get the notices. |
The Following 6 Users Say Thank You to vaevictus0321 For This Useful Post: |
04-08-2017, 11:03 | #10 (permalink) |
Freak Poster Join Date: May 2008 Location: india Age: 40
Member: 776810 Status: Offline Sonork: 100.1627706 Thanks Meter: 19 | frp j320vpp lock open but stop in frp..any 1 have combination file... plz help |
The Following User Says Thank You to firose4u For This Useful Post: |
04-08-2017, 15:13 | #11 (permalink) | |
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
https://mega.nz/#!FEFkQIDD!qZz-5k7Zi...3s0DuPnAPFZ8yk But to remove FRP you can use only boot from combo to enable adb and remove frp with any box or comands. Extract boot.img and make a tar file. If you need help to extract boot tell me and i will help you. | |
The Following 3 Users Say Thank You to Alexandroid For This Useful Post: |
04-09-2017, 04:03 | #12 (permalink) | |
Junior Member Join Date: Apr 2017
Member: 2704751 Status: Offline Thanks Meter: 3 | Quote:
The Following 2 Users Say Thank You to DAR95 For This Useful Post: |
04-09-2017, 15:22 | #13 (permalink) | |
I did it before with success 100%. | |
The Following 4 Users Say Thank You to Alexandroid For This Useful Post: |
04-10-2017, 02:58 | #14 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2318226 Status: Offline Thanks Meter: 29 | phone version 8gb hd 5.71gb system now 2.29 gb free wtf we need another firm o edit firm some help Last edited by cold4501; 04-10-2017 at 03:05. |
The Following User Says Thank You to cold4501 For This Useful Post: |
04-10-2017, 18:03 | #15 (permalink) | |
https://androidfilehost.com/?fid=745425885120692230 | |
