12-31-2021, 14:36 | #1 (permalink) |
Product Supporter Join Date: Feb 2013 Location: UAE
Member: 1881342 Status: Offline Sonork: NA Thanks Meter: 398 | 😀EME Mobile Tool (EMT) Standard Edition License 😀EME Mobile Tool (EMT) Standard Edition License 👀Improved the stability of MTK Module Special tab functions (Supported to MTK Dimensity 1200), Supported No Auth / No Credits / OneKey Factory Reset, Reset FRP, Erase Userdata/FRP, Unlock / Relock Bootloader, Auth Service, Flash etc functions! Added Xiaomi Blackshark 4/4S/4PRO/4SPRO, Redmi NOTE 11_4G etc models, Supported Flash, Factory Reset, Reset FRP etc functions! Added VIVO Y50T, Y20T etc models, Supported Factory Reset, Reset FRP etc functions! 👉ADDED MTK MODULE: No Auth / No Credits / OneKey CPU's Supported All Brands Models: MT6735, MT6737, MT6739, MT6750, MT6753, MT6755, MT6757, MT6758, MT6761, MT6762, MT6763, MT6765, MT6768, MT6771, MT6779, MT6785, MT6781, MT6785, MT6795, MT6797, MT6799, MT6833, MT6853, MT6873, MT6875, MT6877, MT6883, MT6885, MT6889, MT6893, MT6891Z, MT6893 - Factory Reset - Reset FRP - Erase Userdata/FRP - Unlock Bootloader - Relock Bootloader - Authentication Service - Flash 👉XIAOMI MODULE: Need Auth Service (For Find Device is OFF) Following Models by EDL Mode: Read Info, Flash, Read/Erase/Write Partition, Factory Reset, Reset FRP, Partition File Manager - BLACKSHARK 4 (PENROSE) - BLACKSHARK 4S (PENROSE) - BLACKSHARK 4 PRO (KAISER) - BLACKSHARK 4S PRO (KAISER) No Auth / No Credits Following Models by Flash Mode: Read Info, Flash, Read/Erase/Write Partition, Factory Reset, Reset FRP, Reset ID, Partition File Manager - REDMI NOTE 11_4G (SELENES) TIPS: If phone relock after network connect, need to install VPN and disable the xiaomi etc apk network first! 👉VIVO MODULE: Following Models by EDL Mode: Factory Reset, Reset FRP, Reset ID - Y50T (PD2023E) - Y20T (PD2093F) CHANGED - Added "Erase Userdata/FRP" function for MTK Module, Supported Onekey Factory Reset/Reset FRP - Improved the stability of MTK Module Special tab functions - Improved "Factory Reset" function for Huawei module - Improved "Factory Reset (Meta)" function for each module - Fixed Reset FRP bugs for VIVO Y30, Y20, IQOO U1X etc models - Fixed Known bugs 👉INFO How to use the "Special" tab function of MTK Module: 1.Install MTK drivers (Home > Drivers) 2.Uninstall UsbDk Runtime Libraries (If installed already) 3.Install UsbDk Runtime Libraries (Home > Tools) 4.Reboot pc and then try again Download from gsmfastest.com https://drive.google.com/drive/folde...G_v2oiCvaHWa2t ⬇️MediaFire http://www.mediafire.com/folder/8vzzmpkjqvx0i/EMT Last edited by gsmfastest; 12-31-2021 at 15:12. |
The Following User Says Thank You to gsmfastest For This Useful Post: |
