Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 09-17-2019, 22:06   #1 (permalink)
Member: 310418
Thanks Meter: 13
Mar-lx1a frp ...?
Hello,
is there any Tool for MAR-LX1A FRP ?
~lampik
Old 09-19-2019, 10:29   #2 (permalink)
Member: 1420889
Post Huawei P30 Lite new Frp 9.1 solution need !!
Huawei P30 Lite 9.0.1 New FRP Lock Problem Need Solution
No work Emergency Call
No work secrets code
No work sim
Help
hello new hauwei P30 lite 9.1 frp problam
Old 09-21-2019, 20:33   #3 (permalink)
Member: 2925280
i have the same issues this is new
Old 09-21-2019, 21:34   #4 (permalink)
Member: 2117710
Thanks Meter: 70
buy frp key..........
The Following User Says Thank You to sbtech For This Useful Post:
Old 09-22-2019, 03:40   #5 (permalink)
mediapeople's Avatar
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
For new Huawei you need frp key
Old 09-29-2019, 08:35   #6 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
Originally Posted by lampik View Post
Hello,
~lampik
Try These Manual Methods
Huawei P30 lite MAR-LX1A. Remove Google Account,Bypass FRP
ALL HUAWEI 2019 EMUI 9.0.1/9.0 Pie FRP/Google Lock Bypass | Latest Call Method | NO CODE NO TALKBACK
Post Results
Best regards
Sagar Jaiswal
Press Thanks if Helped
The Following User Says Thank You to sagarjais For This Useful Post:
Old 09-29-2019, 23:56   #7 (permalink)
Member: 310418
Thanks Meter: 13
ee, it does.nt work for me ;(
Does MRT do this phone ?
Old 09-30-2019, 06:25   #8 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
you can give a try using mrt huawei tool
Old 09-30-2019, 10:56   #9 (permalink)
Member: 310418
Thanks Meter: 13
i jjust bought mrt key, we will see how it goes, but is it on the list ?
Old 10-07-2019, 14:53   #10 (permalink)
Member: 1464287
Thanks Meter: 41
https://www.youtube.com/watch?v=29F03RRN2jw
Old 10-07-2019, 20:09   #11 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
No work sim
Help
Good, flash board firmware of this Huawei model.
Old 10-07-2019, 20:54   #12 (permalink)
blinet's Avatar
Member: 17405
Thanks Meter: 345
HAHAHAHA nice joke
The Following User Says Thank You to blinet For This Useful Post:
Old 10-08-2019, 17:06   #13 (permalink)
Member: 15156
Thanks Meter: 73
Anyway to read sn of the phone with professional tools?
Old 10-08-2019, 18:12   #14 (permalink)
Member: 1439198
Sonork: 22311495
Thanks Meter: 4
same problem with test point
--------- 2019-10-08 18:08:09 ---------
SigmaKey 2.33.07b3 HiSi: Remove FRP / Huawei ID
HUAWEI USB COM 1.0 (COM336), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 06/11/2015, USB\VID_12D1&PID_3609&REV_0100
HiSilicon: Kirin 970 (v2)
Sending boot...Failed
The Following 2 Users Say Thank You to by-slimanto For This Useful Post:
Old 10-16-2019, 09:04   #15 (permalink)
Member: 2680038
Thanks Meter: 10
i disagree, just need the right firmware for the device to boot into safe mode.
try firmware 9.1.0.215. once flash boot phone into recovery mode then hard reset device and boot into safe mode. once phone boot up you should be able to go into setting reset all setting restart phone then factory reset device from settings menu, FRP done.
Page generated in 0.21813 seconds with 8 queries
