Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 10-30-2019, 14:05   #31 (permalink)
Member: 15156
Thanks Meter: 73
Yes got the right firmware same variant downgraded version doesn't flash using memory card upgrade mode
Old 10-30-2019, 14:06   #32 (permalink)
Member: 15156
Thanks Meter: 73
If u done plenty how come u have a few posts of ur phones failing to flash
Old 10-30-2019, 14:42   #33 (permalink)
Member: 15156
Thanks Meter: 73
firmware version MAR-L01MEA 9.1.0.241(C316E6R1P5
i downloaded this file Marie-L01MEA 9.1.0.215(C316E6R1P5)_Firmware_9.0.0_r3_EMUI9.1.0_ 05015SLH put on sd card but it failed
Old 10-30-2019, 14:47   #34 (permalink)
Registered User
Member: 731353
Thanks Meter: 254
Originally Posted by arif0899 View Post
Huawei P30 Lite 9.0.1 New FRP Lock Problem Need Solution
No work Emergency Call
No work secrets code
No work sim
Help
hello new hauwei P30 lite 9.1 frp problam
watch below the video
http://www.youtube.com/watch?v=SawLdiwFAyY
Old 10-30-2019, 14:51   #35 (permalink)
Member: 15156
Thanks Meter: 73
Tried same method doesn't work
Old 10-30-2019, 23:28   #36 (permalink)
Member: 1636627
Thanks Meter: 24
Not possible to write previous security patch level on p30 lite
Old 11-04-2019, 10:40   #37 (permalink)
Member: 2680038
Thanks Meter: 10
thats because it took me 6 weeks to attempt to flash huawei to remove frps ive ask the forum for help but no one know or even wanted to help.
i would of shared the information at start if you wasnt so rude about the situation in this post or the other post.
Use Dload Method and flash with otg dongle with pen drive/sd card read. read the notes on the firmware it actually tells you how to flash the files as each phone is different, for p30 lite it looks like you got to have MAR-L01A_hw_eea folder ( should have 2 files inside ) and followed by update_sd_base.zip in dload folder. if you still say it dont work then im sorry you must be doing something wrong.
Old 11-04-2019, 10:53   #38 (permalink)
Member: 2680038
Thanks Meter: 10
[QUOTE=bambootest;13883696]thats because it took me 6 weeks to attempt to flash huawei to remove frps ive ask the forum for help but no one know or even wanted to help.
Use Dload Method and flash with otg dongle with pen drive/sd card read. read the notes on the firmware it actually tells you how to flash the files as each phone is different and have to have it in the right order for the phone to flash. if you still say it dont work then im sorry you must be doing something wrong.
Old 11-04-2019, 13:06   #39 (permalink)
Member: 2680038
Thanks Meter: 10
also check out e recovery it is still showing as 9.1.0.215 to download on C431 9.1.0.241 device.
Old 11-05-2019, 21:46   #40 (permalink)
Member: 15156
Thanks Meter: 73
Perhaps u can make a video of how it's done?
Old 11-12-2019, 13:12   #41 (permalink)
Member: 2803071
Thanks Meter: 46
i did exactly like you said but still can't downgrade
Old 11-12-2019, 13:23   #42 (permalink)
Member: 328688
Thanks Meter: 2,282
Originally Posted by bambootest View Post
flash 9.1.0.215 then safe mode method.
tested cant downgrade it stop by vendor phone stuck in recovery dont try it
Old 11-14-2019, 02:39   #43 (permalink)
Member: 2788479
Thanks Meter: 7
Old 11-14-2019, 02:39   #44 (permalink)
Member: 2788479
Thanks Meter: 7
The Following User Says Thank You to zuoruixu For This Useful Post:
Old 11-14-2019, 18:51   #45 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, the files are tested, I do not know how you have done it and if you have tried it, do not spam.
Page generated in 0.21747 seconds with 8 queries
