Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 03-03-2020, 14:27   #31 (permalink)
Member: 2537939
Sonork: 100.1670350
Thanks Meter: 708
same here still problem remain other sounds working but not at call sent and receive voice
Old 03-24-2020, 09:59   #32 (permalink)
Member: 18234
Thanks Meter: 97
need backup nwm and full emmc - erase emmc, and write firmware and nwm zone.if you emmx dont erase - this problem emmc ic
Old 07-07-2020, 08:17   #33 (permalink)
Member: 196365
Thanks Meter: 35
small tip:
if You flashing, then checking sound, then flashing, checking, flashing, checking.... and no results at all, REMEMBER to fit back plastic cover which has metal pin under it, which is used to connect ear speaker to mainboard connector.
I have flashed my phone, assembled, no sound, my plastic plate was there, 100% software fault, then I have spent hours to flash different files... no results, then I have noticed that I'm checking phone after flashing without plastic plate. I'm sure that You have removed this plate as it hiding TP pins.
Old 03-14-2021, 06:59   #34 (permalink)
Member: 1861126
Thanks Meter: 32
but after fix sound
singel imei show only
i many file flash but not fix anybody help
Old 03-14-2021, 08:25   #35 (permalink)
Member: 2675854
Sonork: n/a
Thanks Meter: 17
Originally Posted by alitabraiz83 View Post
but after fix sound
If u want show dual imei use hcu client/Sigma box
The Following User Says Thank You to SharifBD1 For This Useful Post:
Page generated in 0.13106 seconds with 8 queries
