Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 08-13-2016, 18:05   #1 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
[GUIDE] Unbrick and Flash Y625-U32 (EncUnsuccess - 9008)
HUAWEI
Y625-U32
Unbrick & Flashing
Guide
Summary of The Problem
Huawei Y625 phone is one of the worst phones in the market,
Phone have a lot of problems which is related to EMMC, as a result, phone will have one of these cases,
(stuck at logo, FCs msgs and Encryption unsuccessful problem)
Now to fix those problems we need to re-program (restructure) that EMMC,
But with that model it's a little hard process,
In most cases phone won't go to Recovery so you can flash FWs from there, and if it enters Recovery, it will show error while flashing,
Now, since this is a Qualcomm based phone, that means it has a Qualcomm Download mode (qdloader),
From there we are going to do whatever we want!
Unbrick/Flashing Guide
#1 Enable QDloader Mode
1. Disassemble the phone,
2. Short these two pins with a tweezers,
3. Connect phone to PC (without battery),
4. Check Device Manager > Ports,
5. Now your phone in Qualcomm Download Mode,
Let's move to the next part.
#2 Flashing the phone
1. Download required files from Download Section,
2. Run Huyie Download tool as Administrator,
3. Follow these images,
4. Disconnect the phone and Power it on,
You're done
Download Section
Huawei Y625-U32 Firmware
< H E R E >
< H E R E >
< The tool is included with the firmware >
This is not an SD_Upgrade package,
This is the factory firmware which is used to flash the phone in Qualcomm Download Mode.
Final Word
This method not only works with Y625-U32, it should work for all Huawei Qualcomm based phones,
but you'll need to find the Testpoint and the Factory firmware.
I have tested this method myself with a lot of Y625, and they're just working fine now.
In case this guide was helpful for you,
Just hit "Thanks"
Best Regards
The Following 150 Users Say Thank You to MiRoOo For This Useful Post:
Old 08-13-2016, 18:30   #2 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
Repair IMEI & BB
1. Download this file,
Y625-U32_BB_IMEI_Repair
2. Root the phone and Install BusyBox,
3. Connect phone to PC and run CMD,
4. Run these commands one by one,
adb push modem.img /data/local/tmp/modem.img
adb shell su -c "dd if=/data/local/tmp/modem.img of=/dev/block/mmcblk0p12"
adb push modemst1.img /data/local/tmp/modemst1.img
adb shell su -c "dd if=/data/local/tmp/modemst1.img of=/dev/block/mmcblk0p7"
adb push modemst2.img /data/local/tmp/modemst2.img
adb shell su -c "dd if=/data/local/tmp/modemst2.img of=/dev/block/mmcblk0p8"
5. Reboot phone
Now just check your IMEI it should be now repaired
Ok, Here's another way for IMEI repair that works when your Baseband is good, but you still have IMEI:null or IMEI:0,
we're going to write a QCN file which contains an IMEI that's diffrent from yours for sure,
So, as long as this process is a little hard for some ppl, if you decide to just write the file and forget about your orignal IMEI, then skip to the write part of guide,
Otherwise, follow the whole guide, and i promise to make it easy as i can,
Let's begin,
< DOWNLOAD >
< H E R E >
All the tools and files you need for this process included in this zip
< GUIDE >
#1 Edit QCN
In this part we will edit the QCN file and replace it's IMEIs with ours,
1. Install HEX Editor which is included in the zip,
2. Open "y625.qcn" file with HEX Editor,
3. Find these addresses:
IMEI_1: 00001790
IMEI_2: 0000e490 + 0000e4a0
Now we know where IMEIs live in our QCN,
It's time to replace it with our IMEIs.
3. Run "IMEI_Converter.exe"
4. Write your IMEI_1 in the "ENTER IMEI" area then Hit "< CONVERT IMEI >",
5. Do the same for IMEI_2 ,
Copy the converted values and keep it in a txt file.
6. Now just go back to HEX Editor and replace the values with the new ones,
IMEI_1
IMEI_2
7. Now we need to save the file with the new changes,
Now we have a QCN file which contains our original IMEIs,
Great, let's move to the next part.
#2 Enable DIAG Mode
In order to Backup or Restore QCN, phone needs to enter a special mode called "DIAG",
Huawei like many other manufacturers disabled that mode by default,
But that's not a problem at all since we can simply activate it by adb shell commands,
Let's see how,
1. ROOT the phone using iRoot or any other root tool,
2. Connect phone to PC then run these commands one by one,
adb shell
su
setprop sys.usb.config diag,adb
3. Now check your "Device Manager", under "Ports" you should see this
Now you've successfully activated "DIAG" mode, and your phone is ready for QCN Restore part.
#3 Restore QCN
This is where we write the QCN file to the phone using QPST,
QPST is an official tool made by Qualcomm itself and they are using it to deal with their phones and modems as it has a lot of functions,
One of it's functions the QCN Backup and Restore, which we're going to use here,
1. Install QPST which is included in the zip,
2. Run "QPST Configutration",
You'd see something like this,
This means that QPST has successfully see your "DIAG" port and can communicate with your phone.
3. From the menu, go to "Start Client" and select "Software Download",
4. From the tabs choose "Restore", click "Browse" and choose your QCN file,
Hit "Start",
5. When "Restore" process finish, Just reboot your phone,
6. Check your IMEI, it should be there,
< DONE >
This guide is not about Y625 only, this is how to deal with QCN for most Qualcomm based devices not only phones,
I hope that i made myself useful to some of you by this guide,
< BEST REGARDS >
The Following 54 Users Say Thank You to MiRoOo For This Useful Post:
Old 09-16-2016, 16:54   #3 (permalink)
Member: 1745142
Thanks Meter: 344
Hello. this procces would work with Huawei G526. Encryption unsuccessful problem ?
The Following User Says Thank You to markshake For This Useful Post:
Old 09-17-2016, 16:38   #4 (permalink)
Member: 1770631
Sonork: id
Thanks Meter: 89
at step 8 i get error===failed to read the command from the opened port
any help...thanks
The Following 2 Users Say Thank You to kumenger For This Useful Post:
Old 09-17-2016, 17:09   #5 (permalink)
Member: 1770631
Sonork: id
Thanks Meter: 89
i manged to flash using another pc..but EncUnsuccess still exits..what wrong
Old 09-17-2016, 19:25   #6 (permalink)
Member: 1770631
Sonork: id
Thanks Meter: 89
@ MiRoOo please help i flahed it 3 times still the same ..as i can see from you screen-shoot your log your pass result is at ID 239 mine pass ID IS 224..and you counting number end at 189 mine ends at 99..any help..
Old 09-21-2016, 21:51   #7 (permalink)
Member: 2339474
Sonork: 100.1662352
Thanks Meter: 332
hi
i want y530-u00 and g630-u10 factory firmware for unbrick.
The Following 3 Users Say Thank You to metalgold23 For This Useful Post:
Old 09-22-2016, 11:51   #8 (permalink)
hungsun_mobile's Avatar
Member: 723166
Sonork: 100.1590944
Thanks Meter: 129
hi bro!
please hepl me!
flash eror
Old 09-22-2016, 22:57   #9 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
Yes, it would, but only if you know where to TP to get qdload mode and have the right files to use.
any help...thanks
This is most likely EMMC corruption problem,
Sorry, you need to replace it.
Also, there is nothing wrong with the time, it's normal to vary.
Originally Posted by metalgold23 View Post
hi
Originally Posted by hungsun_mobile View Post
hi bro!
please hepl me!
flash eror
Try this:
1. Update your Qualcomm drivers
2. Use another COM/PORT (you can change it from devicemanager)
3. Use another PC or another Windows inside VMware
Hope you get it to work,
The Following 2 Users Say Thank You to MiRoOo For This Useful Post:
Old 09-23-2016, 02:32   #10 (permalink)
Member: 723166
Sonork: 100.1590944
Thanks Meter: 129
you can share Qualcomm drivers
Old 09-24-2016, 11:09   #11 (permalink)
Member: 154346
Thanks Meter: 37
where we can download this tool and factory firmwares?
Old 09-24-2016, 11:38   #12 (permalink)
Member: 154346
Thanks Meter: 37
i need firmware for y625-u21 .best regards
The Following User Says Thank You to klodi For This Useful Post:
Old 10-01-2016, 12:43   #13 (permalink)
JONONItelecom™'s Avatar
Member: 1076772
Sonork: 100.1601881
Thanks Meter: 2,847
Flash Done. but Encryption unsuccessful problem
Last edited by ...:::::NP™:::::...; 01-26-2019 at 18:04. Reason: quote hasbeen removed
The Following 2 Users Say Thank You to JONONItelecom™ For This Useful Post:
Old 10-02-2016, 04:14   #14 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
Originally Posted by JONONItelecom[emoji769
;12073410]
Since "Encryption Unsuccessful" problem is related to bad EMMC, this solution will work with 40% of devices, other 60% needs it's EMMC to be replaced.
Sent from my iPhone 6 using Tapatalk.
The Following 4 Users Say Thank You to MiRoOo For This Useful Post:
Old 10-02-2016, 21:13   #15 (permalink)
Member: 1770631
Sonork: id
Thanks Meter: 89
can you guide as how to prepare official dload firmware to be extracted so that it can be flashed through Qualcomm 9008 port
Page generated in 0.35423 seconds with 8 queries
