Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help |
05-15-2015, 10:48 | #1 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | HUAWEI P6-u06 Brand "Wind", How Enter Sim-Unlock Code?? I've unlocked "Bootloader" w/o unofficial way, have installed all type of ROM/FW from J.B. to KK, have installed TWRP and ROTTED but all this not has solved my problem. I think that these Branded P6 have also Sim-Lock becouse Network is Unlocked, phone NOT requiere any type of "Network Code" if i insert other Sim of other operator in my country. Now i've purchase a payment service for to have all Code for unlock, all ok i have received 4 type of code: 1) Network code (Network PIN) 2) SP codes (Service Provider PIN) 3) SP codes (Service Provider PIN) 4) Simblock/Reset code Have tryed inserting other operator Sim Card but phone NOT requiere any Network Code, i think have Sim-Lock Wind and i've also all codes above. Please anybody know How Do for insert SP Code or Reset Code or any type of command/string for digit right Unlock Code? Now this Device is in this mode: Quote:
BR allumts | |
05-15-2015, 13:32 | #2 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | Hello! few months back i have invented a method to input code into sony xperia sol22 it was having same problem. link to thread try with same method take a dump unlock apk from same phone which ask for unlock code and put it into this phone and see if it asks for unlock code. |
05-15-2015, 13:50 | #3 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | I want to try with these command, only one question.... the 2 Quoted command are the same for this Huawei? Becouse phone whith Sim of operator that have branded it work good, not work with all other sim of my country only... I not have other Branded P6-U06 for Dump unlock .apk so cannot use this you linked procedure or i'm wrong? BR allumts |
05-15-2015, 15:24 | #4 (permalink) | |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | Quote:
{ Ps. If you are unable to do this commands step i will suggest you to root the phone and then install root explorer and put the SimlockUnlockApp.apk manually into system/app/ and reboot. } | |
The Following User Says Thank You to androidlabs For This Useful Post: |
05-15-2015, 15:27 | #5 (permalink) |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | first copy the SimlockUnlockApp.apk from same working phone don't copy the SimlockUnlockApp.apk which is posted on that thread it would be different. |
