Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA Box
Old 01-02-2017, 20:43   #1 (permalink)
Hua Supporter's Avatar
Member: 2179353
Thanks Meter: 17,022
Cool *********HUA BOX AND FRP TOOL and UBTOOL MANUALS(step by step)***********
HOW TO DIRECT UNLOCK MTK PHONES?
-NEED ROOT AND USB DEBUGGING
-PRESS ON BUTTON FIRST THEN INSERT USB CABLE TO PHONE
HOW TO READ UNLOCK CODE MTK PHONES?
The Following 4 Users Say Thank You to Hua Supporter For This Useful Post:
Old 01-02-2017, 20:48   #2 (permalink)
Member: 2179353
HOW TO REPAIR IMEI MTK PHONES?
WE HAVE 8 METHOD FOR REPAIR IMEI BY ADB MODE
and
1 METHOD BY META MODE
MOST METHODS ARE PERMANENT
PERMANENT FIX IS FOR Serial No. : 0123456789ABCDEF(NEED REPAIR BY ASAN METHOD FIRST AND THEN USE PERMANENT FIX METHOD)
The Following 3 Users Say Thank You to Hua Supporter For This Useful Post:
Old 01-02-2017, 20:51   #3 (permalink)
Member: 2179353
HOW TO REPAIR INVALID IMEI BY RII FILE?
-NEED ROOT AND USB DEBUGGING AND BUSYBOX FOR REPAIR
-RII FILE ARE ON HUA TEAM TELEGRAM CHANNAL
Old 01-02-2017, 20:52   #4 (permalink)
Member: 2179353
HOW TO REPAIR INVALID IMEI WITHOUT SELECT FILE?
-NOT SUPPORTED ALL MTK CPU
The Following User Says Thank You to Hua Supporter For This Useful Post:
Old 01-02-2017, 20:54   #5 (permalink)
Member: 2179353
HOW TO READ AND WRITE NVRAM.TAR OR NVRAM.BIN?
-YOU CAN WRITE NVRAM BIN+TAR ON PHONE BY THIS METHOD
Old 01-02-2017, 20:56   #6 (permalink)
Member: 2179353
HOW TO REPAIR IMEI MOST SPD PHONES WITHOUT ROOT?
-NEED CONNECT PHONE TO DIAG MODE(DRIVER)
-PRESS ON BUTTON FIRST THEN REMOVE BATTERY AND INSERT USB CABLE TO PHONE
Old 01-02-2017, 20:57   #7 (permalink)
Member: 2179353
Old 01-02-2017, 20:59   #8 (permalink)
Member: 2179353
HOW TO UNLOCK SAMSUNG EXYNOS PHONES WITHOUT ROOT?
-NO NEED ROOT
-JUST 11 SEC
-CONNECT PHONE TO MODEM MODE
-CHECK MODEM PORT ON DEVICE MANANGER BEFORE PRESS UNLOCK
-CHECK MODEM MODE ON PHONE SETTING IF NOT SHOW ON PC
Old 01-02-2017, 21:02   #9 (permalink)
Member: 2179353
HOW TO UNLOCK SAMSUNG QUALCOMM PHONES WITHOUT ROOT?
-NO NEED ROOT
-JUST 3 SEC
-CONNECT PHONE TO DIAG MODE(*#0808# OR ENABLE DIAG PORT BUTTONT ON HUA)
-CHECK DIAG PORT ON DEVICE MANANGER BEFORE PRESS UNLOCK
-CHECK DIAG MODE(RNDIS+DM+MODEM)ON PHONE SETTING IF NOT SHOW ON PC
Old 01-02-2017, 21:07   #10 (permalink)
Member: 2179353
HOW TO UNLOCK FRP/REACTIVATION/SAM ACCOUNT SAMSUNG QUALCOMM 2015/2016 PHONES BY DOWNLOAD MODE?
-CONNECT PHONE TO DOWNLOAD MODE/ODIN MODE
RESET FRP QUALCOMM NEW LIST MODELS (1).txt
Old 01-02-2017, 21:11   #11 (permalink)
Member: 2179353
HOW TO UNLOCK FRP/REACTIVATION/SAM ACCOUNT SAMSUNG EXYNOS 2015/2016 PHONES BY DOWNLOAD MODE?
EXYNOS FRP LIST MODELS.txt
Old 01-02-2017, 21:15   #12 (permalink)
Member: 2179353
HOW TO RESET FRP LG QUALCOMM PHOMES WITHOUT ROOT?
DRIVER IS Important FOR RESET
With Power-off Phone Hold Volume+ then Connect USB Cable to Phone
Install needed drivers
Select LG Usb Serial Port
Old 01-02-2017, 21:21   #13 (permalink)
Member: 2179353
HOW TO REPAIR IMEI LG QUALCOMM PHONE WITHOUT ROOT?
-JUST 3 SEC
-DRIVER IS IMPORTANT FOR CONNECTION
-NEED ENABLE DIAG PORT BEFORE REPAIR
-NEED SELECT DIAG PORT ON PORT SETTING
-USE ENABLE DIAG PORT ON HUA/LG TAB OR ENTER CODE FOR DIAG
VIDEO
Please, make sure that You perform these steps:To connect the phone in Normal Mode, do the next: Select "Charge Phone" in "USB PC Connection" menu. Type ##3424#, go to "Diag" menu and select "Enable". This menu is blocked by SPC/MSL.
277634#*# -> Port check Test -> set Enabled. Reconnect device.
Select "tethering mode" after usb connection
Just enable usb developer mode(adb) plug phone
enter code: *#546368#*855#
Then in meniu choose SVC Menu
Then choose Port Check Test
And must enable it.
After all You can connect phone to PC by USB cable.
Then must install drivers.
Enable Diagnostic Port
1. 277634#*# or 3845#*#
2. Select Port Check Test
3. Enable Port Check Test
Reconnect Mobile
Please Type 277634#*# then find and set 'Port Check Test' to 'Enable',
use 3845#*505# OR *#546368#*505#
Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will apear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu.
277634#*#
3845#*631#
*#546368#*631#
In case you can not get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone.
DIAG mode serial found.
Please, type ##3424# to get SPC / MSL / Service Code...OK
Go to "Diag" menu and select "Enable" option.
The Following 2 Users Say Thank You to Hua Supporter For This Useful Post:
Old 01-02-2017, 21:23   #14 (permalink)
Member: 2179353
HOW TO UNLOCK LG QUALCOMM PHONE WITHOUT ROOT?
-JUST 3 SEC
VIDEO
And must enable it.
Reconnect Mobile
277634#*#
3845#*631#
*#546368#*631#
Old 01-02-2017, 21:24   #15 (permalink)
Member: 2179353
HOW TO RESET SCREEN LOCK LG QUALCOMM PHONES WITHOUT ROOT ADN USB DEBUGGING?
Remove Screen Lock Manual:
- Connect Phone in 'Download Mode'
For Doing that: with Power off Phone Hold Volume Up Button then Connect USB Cable to Phone
- Install Need Driver if Windows Request
- in Select Port Select 'LGE AndroidNet USB Serial Port'
- Click on 'Remove Screen Lock' and Following rest Procedure
--OLD METHOD IS FOR 5.X.X/6.X.X
--NEW METHOD IS FOR 2017/2018 ENCRYPTED PHONES
VIDEO
The Following 5 Users Say Thank You to Hua Supporter For This Useful Post:
Page generated in 0.28286 seconds with 8 queries
