02-01-2021, 10:53 | #2 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | HOW TO REPAIR IMEI XIAOMI QUALCOMM PHONES BY HUA ? MIUI 9 AND 10 IS NOT SUPPORTED *Backup phone original QCN before Repair IMEI by QPST Free Tool* 0. Backup from dump or securtiy with hqt before repair imei(modemst1,2,fsg) 1. Power on the phone and enable "USB Debugging" option 2. Connect phone to pc via USB cables(EDL MODE OR FASTBOOT MODE) 3. Open hqt.EXE and Goto Service Tab 4. GOTO XIAOMI TAB and Press Erase Imei(fastboot mode need unlock bootloader) and then Reset Factory phone(Manually on setting) 5. Press *#06# and Check IMEI IS INVALID 6. Dial(*#*#717717#*#*) For Enable Qualcomm Diag port 7. OPEN AHT/Select Diag Port on Setting 8. GOTO QUALCOMM/XIAOMI TAB Enter Imei1 or 2 and Press Repair 9. Goto Phone Setting and Press Factory Reset 10. Restore Qcn on Phone By QPST FREE TOOL 11. PRESS FACTORY RESET AGAIN 12.DONE |
02-01-2021, 10:54 | #3 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | How to do: 1) Backup EFS (You Can do this from SEC/Modem/EFS Operations -> Read EFS(ADB/2020) 2) Wipe EFS (You Can do this from SEC/Modem/EFS Operations -> Wipe EFS(TWRP/2020) 3-a) Enable Diag Port (Solutions May be varied depend on your Phone Model/Android version) 3-b) our Newest solution for Enabling Diag Port may help you (you can do this from Qualcomm Android Tab -> Change USB Diag Mode -> Enable Diag (2020) 4) Write Suitable ENG QCN (You need QPST for this operation) 5) Repair Your Phone IMEI with 'New Methos 2020' ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++++++++++++++++ Please read this text carefully before repairing imei. Important Note #1: Backup your Phone EFS Repairing IMEI will be Done with Specific ENG QCN and these are available in our Telegram Messenger Channels. Please Note for SDM710/SDM712 chipset it is Possible to Repair Both IMEI1 and IMEI2, for other chipset only the Second IMEI Will Be Repaired. Important Note #2: after Writing ENG QCN dont RESET Phone at all just Repair IMEI and after that you can RESET Your Phone. Important Note #3: Its Highly Recommended for Dual SIM Phones except SDM710/712 chipset base Just Repair IMEI2 and Leave IMEI1 Field Blank. ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++++++++++++++++ |
The Following User Says Thank You to Hua Supporter For This Useful Post: |
