02-10-2016, 13:30 | #1 (permalink) |
Insane Poster Join Date: Mar 2009
Member: 998126 Status: Offline Sonork: 710980 Thanks Meter: 11 | xiaomi imei REPAIR soloution 2016-10-02 - 17:55:08 : Preparing Phone on COM4-Qualcomm HS-USB Android DIAG 901D 2016-10-02 - 17:55:11 : Reading Phone Information ... 2016-10-02 - 17:55:11 : Build No : MPSS.DPM.1.0.c7.18-00023-M8916EAAAANUZM-1-all15 2016-10-02 - 17:55:11 : IMEI : 667935023501281 2016-10-02 - 17:55:11 : ESN : 00000000 2016-10-02 - 17:55:11 : Writing IMEI1... OK 2016-10-02 - 17:55:11 : Writing IMEI2... OK 2016-10-02 - 17:55:11 : 2016-10-02 - 17:55:11 : Please Factory Reset Your Phone to complete the operation 2016-10-02 - 17:55:11 : HINT: (Go to Settings > General > Backup > Erese/Factory data reset press 'Reset phone' and 'Erase everything' buttons) 2016-10-02 - 17:55:11 : Stopping ADB Service... OK 2016-10-02 - 17:55:11 : Operation Time: 00:00:03 after full factory reset imei is not repair help hua team ..issue is very old solve this threat Last edited by gfgfgf; 02-10-2016 at 13:36. |
The Following User Says Thank You to gfgfgf For This Useful Post: |
02-10-2016, 15:12 | #4 (permalink) | ||
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | THIS MODEL IS NOT SUPPORTED BY HUABOX READ QCN AND SEND FOR ME solution for xiaomi phones Quote:
-reset security(lg tab) -check imei is 00000000000000/01 -enable diag port -select diag port -goto unlock/imei tab -enable skip reset security -enter imei1 or imei2 -select method2 -press repair -done -factory reset now Quote:
The Following User Says Thank You to Hua Supporter For This Useful Post: |
02-10-2016, 17:43 | #5 (permalink) | |
Member: 998126 Status: Offline Sonork: 710980 Thanks Meter: 11 | Quote:
here is qcn sir this is only requst not thread hua team LG_QCN_1641_02_10-22_02_53 - Download - 4shared - kkabeer khan | |
02-10-2016, 18:26 | #6 (permalink) | |
read qcn success 02 - 22:32:21 : For Android 4.x.x and Above: 2016-10-02 - 22:32:21 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2016-10-02 - 22:32:21 : 2- Return to General Tab Tap on Developer Options 2016-10-02 - 22:32:21 : 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone 2016-10-02 - 22:32:21 : 4- Select LG Software on Appeared Pop-up Window 2016-10-02 - 22:32:21 : 5- Hit 'R' Button on Software then Select 'LGE AndroidNet USB Serial Port' 2016-10-02 - 22:32:21 : 2016-10-02 - 22:32:24 : Operation Time: 00:00:02 2016-10-02 - 22:32:26 : Please Select QCN File! 2016-10-02 - 22:32:26 : Operation Time: 00:-01:-03 2016-10-02 - 22:32:28 : Please Select QCN File! 2016-10-02 - 22:32:28 : Operation Time: 00:-01:-05 2016-10-02 - 22:32:31 : Please Select QCN File! 2016-10-02 - 22:32:31 : Operation Time: 00:-01:-07 when i fill up file in hua software lg qcn tab says massage ..failed to Decrypt resource help hua team | |
02-17-2016, 08:58 | #7 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Find Me
Member: 2213077 Status: Offline Sonork: 100.1671613 Thanks Meter: 59 | -read security(lg tab) -reset security(lg tab) -check imei is 00000000000000/01 -enable diag port -select diag port -goto unlock/imei tab -enable skip reset security -enter imei1 or imei2 -select method2 -press repair -done -factory reset now problem is not solve plzz help hua team Searching for Phone ...OK Preparing Phone on COM21-Qualcomm HS-USB Diagnostics Reading Phone Information ... Build No : MPSS.DPM.2.0-a8913ba IMEI : 667634091411202 ESN : 00000000 Writing IMEI1... OK Writing IMEI2... OK Please Factory Reset Your Phone to complete the operation HINT: (Go to Settings > General > Backup > Erese/Factory data reset press 'Reset phone' and 'Erase everything' buttons) Operation Time: 00:00:03 |
02-17-2016, 11:57 | #9 (permalink) | |||
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Quote:
02-17-2016, 13:34 | #10 (permalink) | |
02-18-2016, 13:01 | #11 (permalink) |
Member: 998126 Status: Offline Sonork: 710980 Thanks Meter: 11 | this is good phone qcn redmi 2 ..hua team GT-I8262_MPSS.DPM.1.0.c7.18-00021-M8916EAAAANUZM-1-all14_17-2-2016_20-6-12 - Download - 4shared - kkabeer khan |
02-18-2016, 16:04 | #12 (permalink) | |
Member: 2213077 Status: Offline Sonork: 100.1671613 Thanks Meter: 59 | Quote:
Xiaomi Mii 4i Read Qcn File plzz Give Me plzzz thanxx | |
04-23-2019, 17:23 | #14 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Gautam Buddha Nagar Age: 35
Member: 1291309 Status: Offline Sonork: [email protected] Thanks Meter: 58 | xiaomi redmi note 6 pro, every time i write QCN, corrupts nv data koi plzz edit qcn dalo yaar plzz hai tho solution edit kaise hionge imei origneal tho chad jate hai bt edit kiye hwe qcn chadate hi nv data corapted solution gsm form plzzz |
04-24-2019, 08:45 | #15 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | HOW TO REPAIR IMEI XIAOMI QUALCOMM PHONES BY HUA ? MIUI 9 AND 10 IS NOT SUPPORTED *Backup phone original QCN before Repair IMEI by QPST Free Tool* https://www.4shared.com/rar/g86esMYv...N_BY_QPST.html 0. Backup from dump or securtiy with hmi before repair imei 1. Power on the phone and enable "USB Debugging" option 2. Connect phone to pc via USB cables(EDL MODE OR FASTBOOT MODE) 3. Open hqt.EXE and Goto Service Tab 4. GOTO XIAOMI TAB and Press Erase Imei(fastboot mode need unlock bootloader) and then Reset Factory phone(Manually on setting) 5. Press *#06# and Check IMEI IS INVALID 6. Dial(*#*#717717#*#*) For Enable Qualcomm Diag port 7. OPEN AHT/Select Diag Port on Setting 8. GOTO QUALCOMM/XIAOMI TAB Enter Imei1 or 2 and Press Repair 9. Goto Phone Setting and Press Factory Reset 10. Restore Qcn on Phone By QPST FREE TOOL 11. PRESS FACTORY RESET AGAIN 12.DONE |
