12-21-2019, 19:43 | #1 (permalink) |
Junior Member Join Date: Dec 2019 Location: Bulgaria
Member: 2940991 Status: Offline Thanks Meter: 0 | How to Fix iPhone is Disabled error? I have Apple iPhone 6 which is showing iPhone is Disabled, Connect to iTunes. Someone help me in getting rid from this problem because even i don't know how to flash firmware of apple devices. Thanks |
12-21-2019, 20:32 | #2 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Africa
Member: 1917743 Status: Offline Thanks Meter: 36 | here you go https://www.youtube.com/watch?v=O4Tmt3IWKfQ Last edited by kalinichenko; 12-21-2019 at 20:35. Reason: typo |
12-21-2019, 20:42 | #3 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Quote:
First you need to know that Restoring or Flashing an iPhone will erase all your phone's Data. And you would need the existing Apple ID and password to Reactivate your phone after Restore/Flash. To Restore you need to Download and install Itunes from apple.com Once you have installed iTunes on your PC. Switch off your phone, hold your home button and insert the USB cable to the phone while still holding the Home button. Keep holding the home key until you see a connect to iTunes logo on the screen. Once the phone shows this logo. iTunes will prompt you that an iphone has been detected in Recovery mode. You will see two options available there. One is UPDATE and another one is RESTORE. Click RESTORE. After you click restore iTunes will download correct firmware. This will take some time depending on yout internet speed. Once it is downloaded it will automatically extract and restore your device. After your phone is successfully Restored you need to setup your device according to you language and settings you prefer and activate your device. Done . | |
03-30-2020, 07:07 | #4 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2797527 Status: Offline Thanks Meter: 4 | If your iPhone is disabled and can get more chances to enter and try, you should think carefully which passcode is. Otherwise, it will be locked and disabled with no ability to connect to iTunes even. In this case, use iTunes, restore in recovery mode, try iPhone system recovery, or erase with iCloud to fix. |
