02-13-2016, 01:23 | #1 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2530951 Status: Offline Thanks Meter: 0 | iOS9 "Error 53" root causes I have put back the original Home Button assembly onto the new display assembly but I can get rid of "Error 53". 1) Should I be able to recover the phone from Error 53 by putting the original Home Button assembly back assuming there is nothing damaged elsewhere? 2) Has anyone got evidence that replacing the Home Button is NOT the only root cause for Error 53 but that replacing the screen assembly can also be another root cause for Error 53? 3) Has anyone got evidence that replacing the Home Button is NOT the only root cause for Error 53 but that replacing the long Home Cable running behind the LCD can also be another root cause for Error 53? Details: It is already well established that such error is generated when the motherboard can't match the Touch ID number stored in an IC mounted onto the Home Button assembly flex. It is obvious such matching fails if the original Home Button assembly is replaced or if the flex running behind the LCD and connetti g the Home Button assembly to the motherboard is damaged. I don't think there is anything damaged in the iPhone. A number of sources on the Internet report that replacing the Home Button is NOT the only root cause for Error 53 and that replacing the screen assembly can also be another root cause for Error 53. Moreover, other sources (cf. "Replacing the cable will cause the Touch ID sensor to stop working") report that replacing the long Home Cable running behind the LCD can also be another root cause for Error 53; how can this be true if the long Home Cable does not have any IC storing an ID number? |
02-13-2016, 02:18 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | some times when non professional replace lcd he damages some line of the long home button cable so that cable is also responsible for error 53 and some time damage in caps and crack in connector is also a cause of error 53! Regards .::M Irfan::. |
02-13-2016, 10:16 | #3 (permalink) |
Freak Poster Join Date: Aug 2014 Location: UK
Member: 2240742 Status: Offline Thanks Meter: 76 | Simple definition: anything that Disturbed or stop home button from functioning properly is the root cause of error 53! Can be home button itself, can be the long flex and can be the long flex connector on PCB( mostly in water damaged cases hope it helps in understanding root cause of error 53. |
02-14-2016, 01:16 | #5 (permalink) | |
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | Quote:
In case problem from home button only! after Chinese holidays i will ordered some org home button and will check with faulty phones and will update this thread Regards .::M Irfan::. | |
The Following User Says Thank You to .::M Irfan::. For This Useful Post: |
02-14-2016, 15:11 | #8 (permalink) | |
Member: 2240742 Status: Offline Thanks Meter: 76 | Quote:
don't waste your time bro... | |
02-15-2016, 17:37 | #9 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1813092 Status: Offline Sonork: bentaouit Thanks Meter: 1 | try this it's worked for me on iphone 6+ http://www.united-education****/2016...-solution.html |
02-15-2016, 17:41 | #10 (permalink) |
Member: 1813092 Status: Offline Sonork: bentaouit Thanks Meter: 1 | try this guys it's worked for me on iphone 6+ iphone 6 error 53 fix solution ~ U-Education |
