11-09-2020, 07:34 | #1 (permalink) |
Junior Member Join Date: Sep 2012 Location: Satara
Member: 1809326 Status: Offline Thanks Meter: 7 | iphone 6s battery drain fast while Using phone checked with dc power supply , it is taking 1.2 amps while using the phone and 0.020 on stand by i have change u2, wifi ic , checked with remove all flex, front back camera,display checked messa line ,it is ok tried rosin method , and i can see cpu is getting hot. |
05-16-2021, 17:19 | #4 (permalink) |
Junior Member Join Date: May 2021 Location: Deutschland Age: 29
Member: 2987744 Status: Offline Sonork: Xx Thanks Meter: 0 | Sometimes the iPhone discharges when you use certain apps. Try observing if the battery drains faster when you use a certain app or if it drains that fast even with normal use. |
