02-09-2023, 23:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | A10 serials not working anymore ? I buy fresh serials for A8 A10 and write to the Watch but the watch unable to pair anymore. Are you people having problems or not nowadays? The serial that I buy is OFF but the watch doesn't want to be activated at all. Also reflashed the watch now for 2nd time: Code: [info] Using local file D:\MFCBOX\iWatch Firmware\MFC_Watch3,4_19U67_8.7.1_n121bAP_GPS_Restore_42mm.ipsw [erro] Trying to automatically install correct USB driver! Please uninstall the current driver manually if this fails! [erro] You can uninstall the driver from Control Panel or by running this command as administrator: [erro] pnputil /delete-driver oem202.inf /uninstall /force [warn] This command only works on this computer! Don't try this command on other computer! [warn] After drivers have been removed please reconnect the device to USB and try again! [info] Waiting for Windows to install the default drivers ... [info] Removed (USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM:03_SCEP:01_BDID:1A_ECID:000D04C620066F26_IBFL:3C_SRTG:[IBOOT-2651.0.0.3.3]) [info] Arrival (USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM:03_SCEP:01_BDID:1A_ECID:000D04C620066F26_IBFL:3C_SRTG:[IBOOT-2651.0.0.3.3]) [info] Drivers update complete! [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.7.1 [data] Product Build: 19U67 Major: 19 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 000d04c620066f26 [info] Getting ApNonce in dfu mode... [data] A2B09DC2E380884D6750A7AA038B266A9F5F58AE0AA885CDD36E1B202F670C9C [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 2CAEF7CD8DF4192E289EA24B2C551E588989C8CB [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [erro] Unable to find component node for Cryptex1,SystemOS [info] Using cached file 'iDeviceTools\MFC_Watch3,4_19U67_8.7.1_n121bAP_GPS_Restore_42mm\078-33421-074.dmg' [info] Found ECID 000d04c620066f26 [info] Getting ApNonce in dfu mode... [data] A2B09DC2E380884D6750A7AA038B266A9F5F58AE0AA885CDD36E1B202F670C9C [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 2CAEF7CD8DF4192E289EA24B2C551E588989C8CB [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Personalizing IMG4 component iBSS... [erro] Tag found [info] Sending iBSS (773157 bytes)... [info] Removed (USB\VID_05AC&PID_1227\CPID:8004_CPRV:10_CPFM:03_SCEP:01_BDID:1A_ECID:000D04C620066F26_IBFL:3C_SRTG:[IBOOT-2651.0.0.3.3]) [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000d04c620066f26 disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Arrival (USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CPFM:03_SCEP:01_BDID:1A_ECID:000D04C620066F26_IBFL:3C_SRNM:[DLXJN9W9F185]) [info] Found device in Recovery mode [info] cpid:0x8004, bdid:0x001A [info] Noce: a2 b0 9d c2 e3 80 88 4d 67 50 a7 aa 03 8b 26 6a 9f 5f 58 ae 0a a8 85 cd d3 6e 1b 20 2f 67 0c 9c [info] Personalizing IMG4 component iBEC... [erro] Tag found [info] Sending iBEC (773157 bytes)... [info] Removed (USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CPFM:03_SCEP:01_BDID:1A_ECID:000D04C620066F26_IBFL:3C_SRNM:[DLXJN9W9F185]) [info] Device ecid 000d04c620066f26 disconnect detected! [info] Arrival (USB\VID_05AC&PID_1281\SDOM:01_CPID:8004_CPRV:10_CPFM:03_SCEP:01_BDID:1A_ECID:000D04C620066F26_IBFL:3C_SRNM:[DLXJN9W9F185]) [info] device serial number is DLXJN9W9F185 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7459.140.15 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Personalizing IMG4 component AppleLogo... [erro] Tag found [info] Sending AppleLogo (9313 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreTrustCache... [erro] Tag found [info] Sending RestoreTrustCache (15624 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreRamDisk... [erro] Tag found [info] Sending RestoreRamDisk (84828514 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreDeviceTree... [erro] Tag found [info] Sending RestoreDeviceTree (32394 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreSEP... [erro] Tag found [info] Sending RestoreSEP (2337346 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreKernelCache... [erro] Tag found [info] Sending RestoreKernelCache (14632856 bytes)... [info] Device ecid 000d04c620066f26 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 854945fb2dbca4517e64797f563eaab84ed4417c has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 3664423684566822 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49170) [warn] Requesting Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Personalizing IMG4 component LLB... [erro] Tag found [info] Personalizing IMG4 component AppleLogo... [erro] Tag found [info] Personalizing IMG4 component Dali... [erro] Tag found [info] Personalizing IMG4 component DeviceTree... [erro] Tag found [info] Personalizing IMG4 component RecoveryMode... [erro] Tag found [info] Personalizing IMG4 component iBoot... [erro] Tag found [info] Personalizing IMG4 component RestoreSEP... [erro] Tag found [info] Personalizing IMG4 component SEP... [erro] Tag found [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] Checkpoint 1699 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1561 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1562 complete with code 0 [info] Connecting to FDR client at port 49170 [info] Checkpoint 1563 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Creating partition map (11) [info] Checkpoint 1569 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checkpoint 1627 complete with code 0 [info] Checkpoint 1664 complete with code 0 [info] Checkpoint 1653 complete with code 0 [info] Checkpoint 1676 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Checking filesystems (15) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Mounting filesystems (16) [info] Mounting filesystems (16) [info] Checkpoint 1574 complete with code 0 [info] Checkpoint 1634 complete with code 0 [info] Checkpoint 1655 complete with code 0 [info] Checkpoint 1658 complete with code 0 [info] Checkpoint 1575 complete with code 0 [info] Checkpoint 1690 complete with code 0 [info] Checkpoint 1691 complete with code 0 [info] Checkpoint 1618 complete with code 0 [info] Checkpoint 1588 complete with code 0 [info] Checkpoint 1661 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Checkpoint 4864 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Checkpoint 4882 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component ACIBT... [erro] Tag found [info] Sending IsFUDFirmware for ACIBT... [info] Personalizing IMG4 component ACIWIFI... [erro] Tag found [info] Sending IsFUDFirmware for ACIWIFI... [info] Personalizing IMG4 component AOP... [erro] Tag found [info] Sending IsFUDFirmware for AOP... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [erro] Tag found [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component Multitouch... [erro] Tag found [info] Sending IsFUDFirmware for Multitouch... [info] Personalizing IMG4 component RTP... [erro] Tag found [info] Sending IsFUDFirmware for RTP... [info] Personalizing IMG4 component RestoreTrustCache... [erro] Tag found [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component StaticTrustCache... [erro] Tag found [info] Sending IsFUDFirmware for StaticTrustCache... [info] Personalizing IMG4 component SystemVolume... [erro] Tag found [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4874 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [erro] Tag found [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component RestoreTrustCache... [erro] Tag found [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component SystemVolume... [erro] Tag found [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 0 [info] Checkpoint 4870 complete with code 0 [info] Checkpoint 4871 complete with code 0 [info] Checkpoint 4872 complete with code 0 [info] Checkpoint 4878 complete with code 0 [info] Checkpoint 4879 complete with code 0 [info] Checkpoint 4875 complete with code 0 [info] Checkpoint 4867 complete with code 0 [info] Checkpoint 4880 complete with code 0 [info] Updating SE Firmware (59) [info] Sending FirmwareResponsePreflight now... [info] Done sending FirmwareUpdaterPreflight response [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Checkpoint 4873 complete with code 0 [info] Unknown operation (79) [info] Checkpoint 4886 complete with code 0 [info] Checkpoint 1589 complete with code 0 [info] Checkpoint 1596 complete with code 0 [info] Checkpoint 5379 complete with code 0 [info] Checkpoint 4889 complete with code 0 [info] Checkpoint 4890 complete with code 0 [info] Requesting EAN Data (74) [info] Checkpoint 5380 complete with code 0 [info] Checkpoint 4884 complete with code 0 [info] Checkpoint 1640 complete with code 0 [info] Checkpoint 1597 complete with code 0 [info] Checkpoint 1647 complete with code 0 [info] Creating Protected Volume (67) [info] Checkpoint 1652 complete with code 0 [info] Checkpoint 1631 complete with code 0 [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Personalizing IMG4 component KernelCache... [erro] Tag found [info] Sending KernelCache ... [info] Done sending KernelCache [info] Installing kernelcache (27) [info] Checkpoint 3584 complete with code 0 [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Personalizing IMG4 component DeviceTree... [erro] Tag found [info] Sending DeviceTree ... [info] Done sending DeviceTree [info] Installing DeviceTree (61) [info] Checkpoint 3585 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Personalizing IMG4 component LLB... [erro] Tag found [info] Personalizing IMG4 component AppleLogo... [erro] Tag found [info] Personalizing IMG4 component Dali... [erro] Tag found [info] Personalizing IMG4 component DeviceTree... [erro] Tag found [info] Personalizing IMG4 component RecoveryMode... [erro] Tag found [info] Personalizing IMG4 component iBoot... [erro] Tag found [info] Personalizing IMG4 component RestoreSEP... [erro] Tag found [info] Personalizing IMG4 component SEP... [erro] Tag found [info] Sending NORData now... [info] Done sending NORData [info] Checkpoint 3588 complete with code 0 [info] Checkpoint 3589 complete with code 0 [info] Checkpoint 3587 complete with code 0 [info] Checkpoint 1576 complete with code 0 [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Checkpoint 3840 complete with code 0 [info] Checkpoint 3841 complete with code 0 [info] Checkpoint 3844 complete with code 0 [info] Connecting to FDR client at port 49170 [info] Checkpoint 3849 complete with code 0 [info] Checkpoint 1613 complete with code 0 [info] Checkpoint 1694 complete with code 0 [info] Checkpoint 1595 complete with code 0 [info] Modifying persistent boot-args (25) [info] Checkpoint 1593 complete with code 0 [info] Checkpoint 1630 complete with code 0 [info] Checkpoint 1672 complete with code 0 [info] Checkpoint 1659 complete with code 0 [info] Checkpoint 5632 complete with code 0 [info] Checkpoint 1599 complete with code 0 [info] Checkpoint 1600 complete with code 0 [info] Checkpoint 1675 complete with code 0 [info] Checkpoint 1641 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checkpoint 1602 complete with code 0 [info] Checkpoint 1660 complete with code 0 [info] Checkpoint 5651 complete with code 0 [info] Checkpoint 1607 complete with code 0 [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! |
02-09-2023, 23:52 | #2 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | After buying an expensiver serial it works at first try, so buying those old serials that cost cheap is not doing the job at all... |
