08-24-2020, 08:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: SLK Age: 33
Member: 2291450 Status: Offline Sonork: typing... Thanks Meter: 1,600 | Apple Watch S2 Unable to restore device Code: [warn] Operation aborted by user! [done] Operation finished! [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [erro] Can't find major version?! [erro] can't get URL for latest firmware [done] Operation finished! [info] Using LOCAL IPSW D:\FIRMWARE\APPLE\MFC_Watch2,4_17T530_6.2.1_n75ap_Restore_42mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.2.1 [data] Product Build: 17T530 Major: 17 [info] device serial number is FH7ST7NXHJLJ [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 3185732815643942 [info] Getting ApNonce in recovery mode... [data] FABC99930E9A2F0E911216F6D05FD9526D46CFACD50F0438F61ADA9A40000731 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 0E2CF000E16603D6AAD2FF8F7D64D6DB972EFD27 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_17T530_6.2.1_n75ap_Restore_42mm/048-63671-311.dmg' [info] Found ECID 3185732815643942 [info] Getting ApNonce in recovery mode... [data] FABC99930E9A2F0E911216F6D05FD9526D46CFACD50F0438F61ADA9A40000731 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 0E2CF000E16603D6AAD2FF8F7D64D6DB972EFD27 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (752073 bytes)... [info] Removing USB\VID_05AC&PID_1281&MI_01\6&1D85B68C&0&0001\{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0E_ECID:000B516838D36526_IBFL:3D_SRNM:[FH7ST7NXHJLJ] [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0E_ECID:000B516838D36526_IBFL:3D_SRNM:[FH7ST7NXHJLJ] [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0E_ECID:000B516838D36526_IBFL:3C_SRNM:[FH7ST7NXHJLJ] [info] Adding USB\VID_05AC&PID_1281&MI_01\6&1FD7DF58&0&0001\{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0E_ECID:000B516838D36526_IBFL:3C_SRNM:[FH7ST7NXHJLJ] [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.100.194 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8706 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 048-63605-329.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (13743 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-63605-329.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (68001029 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (110731 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11145385 bytes)... [info] Removing USB\VID_05AC&PID_1281&MI_01\6&1FD7DF58&0&0001\{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0E_ECID:000B516838D36526_IBFL:3C_SRNM:[FH7ST7NXHJLJ] [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8002_CPRV:10_CPFM:03_SCEP:01_BDID:0E_ECID:000B516838D36526_IBFL:3C_SRNM:[FH7ST7NXHJLJ] [info] Waiting for device to enter restore mode... [info] Adding USB\VID_05AC&PID_12AF\CCB452CA4C685C909A985619378D0FB6773782AD [info] Apple device arrival ... searching USBMux for device after 1s [info] About to restore device... [info] Waiting for device... [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device ccb452ca4c685c909a985619378d0fb6773782ad has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 3185732815643942 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n75.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checking filesystems (15) [info] Creating Protected Volume (67) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch2... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done[info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done[info] Installing DeviceTree (61) [info] Flashing firmware (18) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting aopfw-m8aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N75_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 048-63605-329.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 048-63671-311.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Status message: Unhandled status message (56). Saving to UnhandledStatusMessage.plist [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device |
The Following User Says Thank You to askarzee91 For This Useful Post: |
