01-19-2021, 09:39 | #1 (permalink) |
Freak Poster Join Date: Jun 2017 Location: Vietnam
Member: 2723433 Status: Offline Thanks Meter: 97 | Apple Watch Series 4 beta to officially OK [info] Using LOCAL IPSW C:\Users\thain\Downloads\MFC_Watch4,4_18S563_7.2_n 141bap_GPS_Cellular_Restore_44mm.ipsw [info] Device ecid (583073838) added! [info] Updated version data. [info] Found device in DFU mode [info] Gettting dfu mode device ... [data] ProductType:Apple Watch S4 [info] Identified device as Apple Watch S4, n141bap, Watch4,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.2 [data] Product Build: 18S563 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 5635873848754222 [info] Getting ApNonce in dfu mode... [data] D6544B4178D7ABDBA0EDA9C73D326FC824D3F29003A6A0749C 3B166CA479664A [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 8FA22EA5E49F44D5F3737F8AB11D91793BA5D15F [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch4,4_18S563_7.2_n141bap_GPS_Cellular_Resto re_44mm/038-82313-072.dmg' [info] Found ECID 5635873848754222 [info] Getting ApNonce in dfu mode... [data] D6544B4178D7ABDBA0EDA9C73D326FC824D3F29003A6A0749C 3B166CA479664A [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 8FA22EA5E49F44D5F3737F8AB11D91793BA5D15F [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n141b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (1117508 bytes)... [info] Removing USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:0E_ECID:001405CC22C1002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12]\{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\ROOT_HUB30\4&CB12D54&0&0 [info] Removing USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM:03_SC EP:01_BDID:0E_ECID:001405CC22C1002E_IBFL:3C_SRTG:[IBOOT-3988.0.0.2.12] [info] Device ecid (583073838) removed! [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 5635873848754222 disconnect detected! [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:0E_ECID:001405CC22C1002E_IBFL:3 C_SRNM:[D92Y21D4KDTD] [info] Adding USB\VID_05AC&PID_1281&MI_01\6&2F082643&0&0001\{B80 85869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8 006_CPRV:11_CPFM:03_SCEP:01_BDID:0E_ECID:001405CC2 2C1002E_IBFL:3C_SRNM:[D92Y21D4KDTD] [info] Found device in Recovery mode [info] Noce: d6 54 4b 41 78 d7 ab db a0 ed a9 c7 3d 32 6f c8 24 d3 f2 90 03 a6 a0 74 9c 3b 16 6c a4 79 66 4a [info] Extracting iBEC.n141b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1117508 bytes)... [info] Device ecid 5635873848754222 disconnect detected! [info] Removing USB\VID_05AC&PID_1281&MI_01\6&2F082643&0&0001\{B80 85869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8 006_CPRV:11_CPFM:03_SCEP:01_BDID:0E_ECID:001405CC2 2C1002E_IBFL:3C_SRNM:[D92Y21D4KDTD] [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:0E_ECID:001405CC22C1002E_IBFL:3 C_SRNM:[D92Y21D4KDTD] [info] Device ecid (583073838) added!Device ecid (583073838) removed! [info] Adding USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:0E_ECID:001405CC22C1002E_IBFL:3 C_SRNM:[D92Y21D4KDTD] [info] Adding USB\VID_05AC&PID_1281&MI_01\6&2F082643&0&0001\{B80 85869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8 006_CPRV:11_CPFM:03_SCEP:01_BDID:0E_ECID:001405CC2 2C1002E_IBFL:3C_SRNM:[D92Y21D4KDTD] [info] device serial number is D92Y21D4KDTD [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.60.62 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10947 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1722669 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1857125 bytes)... [info] Device ecid (583073838) added! [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1730909 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1535125 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (848101 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-82285-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16314 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20257 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160145 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31956 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-82285-072.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (81531544 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n141bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (41197 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11730704 bytes)... [info] Removing USB\VID_05AC&PID_1281&MI_01\6&2F082643&0&0001\{B80 85869-FEB9-404B-8CB1-1E5C14FA8C54}\USB\VID_05AC&PID_1281\SDOM:01_CPID:8 006_CPRV:11_CPFM:03_SCEP:01_BDID:0E_ECID:001405CC2 2C1002E_IBFL:3C_SRNM:[D92Y21D4KDTD] [info] Removing USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV:11_CP FM:03_SCEP:01_BDID:0E_ECID:001405CC22C1002E_IBFL:3 C_SRNM:[D92Y21D4KDTD] [info] Device ecid 5635873848754222 disconnect detected! [info] Device ecid (583073838) removed! [info] Adding USB\VID_05AC&PID_12AF\00008006-001405CC22C1002E [info] About to restore device... [info] Waiting for device... [erro] can't open device with UDID 829ccab954d3d459db8248f70841326e50cd852f [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-001405CC22C1002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32774 [info] UniqueChipID: 5635873848754222 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49170) [warn] Requesting NOT TO Update Baseband [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n141b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n141b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n141bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n141b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n141b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n141b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Connecting to FDR client at port 49170 [erro] FDR 0937A2E8 Unable to receive message (-4). 0/2 bytes [info] Connecting to FDR client at port 49170 [erro] FDR 0937A510 Unable to receive message (-4). 0/2 bytes [info] Unmounting filesystems (29) [info] [ERROR] received partial data 0/2 (Resource temporarily unavailable)[ERROR] received partial data 0/2 (Resource temporarily unavailable) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N141B_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N141b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-82285-072.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 038-82313-072.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating baseband (19) [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [warn] size mismatch when parsing MBN file. [info] Sending BasebandData now... [done] sending BasebandData [info] Updating Baseband in progress... [info] About to send BasebandData... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending Baseband TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received Baseband SHSH blobs [warn] size mismatch when parsing MBN file. [info] Sending BasebandData now... [done] sending BasebandData [done] Updating Baseband completed. [info] Updating SE Firmware (59) [info] Extracting Stockholm5.RELEASE.sefw... [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Creating Protected Volume (67) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n141bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n141b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n141b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n141bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n141b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n141b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n141b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49170 [erro] FDR 0CF61ED0 Unable to receive message (-4). 0/2 bytes [info] Modifying persistent boot-args (25) [info] Unknown operation (74) [info] [ERROR] received partial data 0/2 (Resource temporarily unavailable) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] [ERROR] received partial data 0/4 (Resource temporarily unavailable) [info] Removing USB\VID_05AC&PID_12AF\00008006-001405CC22C1002E [info] Adding USB\VID_05AC&PID_12AF\00008006001405CC22C1002E [info] device arrival... |
The Following User Says Thank You to thainhattam For This Useful Post: |
