08-29-2021, 10:15 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Discussion about MFC Version 3.7 Bugfixes & Changes:
Updates:
08-29-2021, 16:28 | #3 (permalink) |
Insane Poster Join Date: Jan 2005 Location: KG
Member: 103940 Status: Offline Thanks Meter: 4 | Apple Watch S1 38mm Windows 10 x64 with normal cable [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [done] Device is now in pwned DFU Mode! [info] Allready installed usb driver. [info] Sending FirstStage [info] Allready installed usb driver. [info] Sending commands ... [info] Sending DiagsStage Device not found but should be allready in Diag Mode if you use a DSCD cable. Please check driver and manually update the driver if required or try again! [done] Operation finished! Apple Watch S1 38mm Windows 10 x64 with DCSD cable [info] Selected port: COM7 [info] Use DCSD cable selected [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [done] Device is now in pwned DFU Mode! [info] Allready installed usb driver. [info] Sending FirstStage [info] Allready installed usb driver. [info] Sending DiagsStage Device not found but should be allready in Diag Mode if you use a DSCD cable. Please check driver and manually update the driver if required or try again! [done] Operation finished! Apple Watch S2 42mm Windows 10 x64 with normal cable [info] Device present connection uses normal backend [info] Connecting... [info] Device present in DFU mode using normal backend [info] Current thread priority is 0x0 [info] stage 1, heap grooming ... [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [done] Device is now in pwned DFU Mode! [info] Allready installed usb driver. [info] Sending FirstStage [info] Allready installed usb driver. [info] Sending commands ... [info] Sending DiagsStage Device not found but should be allready in Diag Mode if you use a DSCD cable. Please check driver and manually update the driver if required or try again! [done] Operation finished! I have tried on 2 differert pcs, but still same Last edited by sotovikcpsg; 08-29-2021 at 16:38. |
08-29-2021, 19:13 | #4 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
You must keep this way in all diag procedure | |
08-30-2021, 06:02 | #7 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | 2021/8/30 Changes - V3.7 Fix 2021/8/30 Changes - V3.7 Fix
08-30-2021, 06:07 | #8 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | The quick fix version of MFC software will automatically recognize the correct driver while flashing, it may required disconnect the USB cable from the PC and reconnect it at the end |
09-01-2021, 15:51 | #9 (permalink) | |
Freak Poster Join Date: Jun 2013 Location: Ukraine
Member: 1964660 Status: Offline Sonork: No Thanks Meter: 54 | Quote:
10-08-2021, 13:50 | #11 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1793635 Status: Offline Thanks Meter: 0 | [info] Connecting... [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [erro] Current DFU device (ChipId: 0x8004 BoardId: 26) does not exist in our database or data is incomplete! [done] Operation finished! Win 10 x64 Watch 3 when i try to boot them in to diag |
