09-27-2022, 15:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Chile
Member: 1797183 Status: Offline Thanks Meter: 148 | [erro] ssh>connecting to 127.0.0.1: Socket error: Unknown error [erro] Error connecting to devices! [erro] ssh>connecting to 127.0.0.1: Socket error: Unknown error [erro] Error connecting to devices! [erro] ssh>connecting to 127.0.0.1: Socket error: Unknown error [warn] Failed to connect! [erro] Could not connect to Ramdisk [info] Please put the device in DFU mode and try again! [info] device disconnect... [info] Connecting to ramdisk! [info] Removing USB rules! [info] Connecting using DFU ... [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Loading required files ... [info] Finished loading required files ... [info] Eclipsa stage start: RESET [info] Transfer completed 0 length [info] Eclipsa stage end: RESET [info] Reset result: Success [info] Eclipsa stage start: SETUP [info] Transfer canceled [info] Transfer stall [info] Transfer completed 0 length [info] Eclipsa stage end: SETUP [info] Reset result: Success [info] Eclipsa stage start: PATCH [info] Transfer stall [info] Transfer completed 0 length [info] Eclipsa stage end: PATCH [info] Reset result: Success [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Shsh sent (file size:67393 bytes) [info] Allready installed usb driver. [info] iBss sent (file size:244447 bytes) [info] iBec sent (file size:419807 bytes) [info] Devicetree sent (file size:32081 bytes) [info] Ramdisk sent (file size:131075105 bytes) [info] Kernel sent (file size:18496050 bytes) [info] Ramdisk ramdisk tool jun 29 2020 00:18:13 assigned to current device! [info] Connecting to ramdisk! [info] Arrival USB\VID_05AC&PID_12A8\RAMDISK_TOOL_JUN_29_2020_00: 18:13 [info] Connecting... [erro] ssh>connecting to 127.0.0.1: Socket error: disconnected [info] Disconnecting ... [warn] Failed to connect! [erro] Could not connect to Ramdisk [info] Please put the device in DFU mode and try again! [info] Removing USB\VID_05AC&PID_12A8\RAMDISK_TOOL_JUN_29_2020_00: 18:13 [info] Connecting... [warn] Tunnel is not running! [erro] Could not connect to Ramdisk [info] Please put the device in DFU mode and try again! [info] Removing USB rules! [info] Connecting using DFU ... [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Loading required files ... [info] Finished loading required files ... [info] Eclipsa stage start: RESET [info] Transfer completed 0 length [info] Eclipsa stage end: RESET [info] Reset result: Success [info] Eclipsa stage start: SETUP [info] Transfer canceled [info] Transfer stall [info] Transfer completed 0 length [info] Eclipsa stage end: SETUP [info] Reset result: Success [info] Eclipsa stage start: PATCH [info] Transfer stall [info] Transfer completed 0 length [info] Eclipsa stage end: PATCH [info] Reset result: Success [info] Installing USB driver for device: "Apple Mobile Device (DFU Mode)" (05AC:1227). [info] Shsh sent (file size:67393 bytes) [info] Allready installed usb driver. [info] iBss sent (file size:244447 bytes) [info] iBec sent (file size:419807 bytes) [info] Devicetree sent (file size:32081 bytes) [info] Ramdisk sent (file size:131075105 bytes) [info] Kernel sent (file size:18496050 bytes) [info] Ramdisk ramdisk tool jun 29 2020 00:18:13 assigned to current device! [info] Connecting to ramdisk! [info] Arrival USB\VID_05AC&PID_12A8\RAMDISK_TOOL_JUN_29_2020_00: 18:13 [info] Connecting... [erro] Error connecting to devices! [erro] ssh>connecting to 127.0.0.1: Socket error: Unknown error [erro] Error connecting to devices! [erro] ssh>connecting to 127.0.0.1: Socket error: Unknown error [warn] Failed to connect! [erro] Could not connect to Ramdisk [info] Please put the device in DFU mode and try again! |
