09-23-2022, 08:38 | #1 (permalink) |
Freak Poster Join Date: Feb 2010 Location: bhuj Age: 37
Member: 1229719 Status: Offline Thanks Meter: 4 | HELP dongle ssh>connecting to 127.0.0.1: Socket error: disconnected [info] Connecting using DFU ... [info] Thread priority before boost is 0x2 [info] Current thread priority is 0xf [info] stage 1, heap grooming ... [erro] Heap grooming failed! Aborting... [warn] Retrying heap grooming [info] stage 1, heap grooming ... [info] Reset result: Success [info] stage 2, aquired [info] stage 3, exploit [info] Uploading payload [info] Connecting to ramdisk! [done] Device is now in pwned DFU Mode! [info] Loading required files ... [info] Finished loading required files ... [info] Successfully patched signature checks! [info] Connecting to ramdisk! [info] Heap repaired. [info] Shsh sent (file size:63144 bytes) [info] iBss sent (file size:1471378 bytes) [info] iBec sent (file size:1471378 bytes) [info] Devicetree sent (file size:40461 bytes) [info] Ramdisk sent (file size:120590612 bytes) [info] Adc sent (file size:13269959 bytes) [info] Rdtrust sent (file size:12226 bytes) [info] Kernel sent (file size:18721200 bytes) [info] Connecting... [info] Ramdisk ramdisk tool jun 29 2020 00:18:13 assigned to current device! [info] Connecting to ramdisk! [erro] ssh>connecting to 127.0.0.1: Socket error: disconnected [info] Disconnecting ... [warn] Failed to connect! [erro] Could not connect to Ramdisk [info] Please put the device in DFU mode and try again! [info] Removing USB\VID_05AC&PID_12A8\RAMDISK_TOOL_JUN_29_2020_00: 18:13 i had changed usb cable and motherboad flax cable also but i didn't get solution not a single mobile has been unlocked by ramdisk getting error back to back, I have EFT dongle which is not supported but it is working without error i AM EXPECTING IN NEXT UPDATE THAT THERE WILL BE NO ERROR IN MFC DONGLE |
09-24-2022, 08:12 | #2 (permalink) |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 206 | You can contact [email protected] for new beta version 919 |
