Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 09-23-2022, 08:38   #1 (permalink)
Member: 1229719
Thanks Meter: 4
HELP dongle ssh>connecting to 127.0.0.1: Socket error: disconnected
[info] Removing USB rules!
[info] Connecting using DFU ...
[info] Thread priority before boost is 0x2
[info] Current thread priority is 0xf
[info] stage 1, heap grooming ...
[erro] Heap grooming failed! Aborting...
[warn] Retrying heap grooming
[info] Reset result: Success
[info] stage 2, aquired
[info] stage 3, exploit
[info] Uploading payload
[info] Connecting to ramdisk!
[done] Device is now in pwned DFU Mode!
[info] Loading required files ...
[info] Finished loading required files ...
[info] Successfully patched signature checks!
[info] Heap repaired.
[info] Shsh sent (file size:63144 bytes)
[info] iBss sent (file size:1471378 bytes)
[info] iBec sent (file size:1471378 bytes)
[info] Devicetree sent (file size:40461 bytes)
[info] Ramdisk sent (file size:120590612 bytes)
[info] Adc sent (file size:13269959 bytes)
[info] Rdtrust sent (file size:12226 bytes)
[info] Kernel sent (file size:18721200 bytes)
[info] Connecting...
[info] Ramdisk ramdisk tool jun 29 2020 00:18:13 assigned to current device!
[erro] ssh>connecting to 127.0.0.1: Socket error: disconnected
[info] Disconnecting ...
[warn] Failed to connect!
[erro] Could not connect to Ramdisk
[info] Please put the device in DFU mode and try again!
[info] Removing USB\VID_05AC&PID_12A8\RAMDISK_TOOL_JUN_29_2020_00: 18:13
i had changed usb cable
and motherboad flax cable also
but i didn't get solution
not a single mobile has been unlocked by ramdisk
getting error back to back,
I have EFT dongle which is not supported but it is working without error
i AM EXPECTING IN NEXT UPDATE THAT THERE WILL BE NO ERROR IN MFC DONGLE
Old 09-24-2022, 08:12   #2 (permalink)
Member: 2277861
Thanks Meter: 206
You can contact [email protected] for new beta version 919
Page generated in 0.11308 seconds with 8 queries
