Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > MFC Dongle (iMFC)
Old 01-25-2018, 19:59   #61 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Arrow MFC Server IPR function updated
  • IPRecovery Function updated to support iOS 11.2.5
The Following 6 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 07-21-2020, 02:30   #62 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 3in1 V3.3 Beta Released ! - 2020/7/21
We're very pleased to announce a major new release MFC Suite 3in1 V3.3 Beta
This has new features and bugfixes:
  • Add support all new Apple iPhone
  • Add support all new Apple Watch
  • Add support all new Apple iPad
  • Add iREWORK and iPOWER X Software inside (We may enable iREWORK and iPOWER X to use iMFC Function in next update)
  • IPR function updated
  • Server side update to support new client 3.3
Upgrading to new Versions:
  • This update file required install full installer version 2.5.1 first, after download the update file you need extract the file to c:/mfc folder. The downloaded version of the software is available now from support page with valid membership.
Ps. As this is a major new release with many changes, we'll be going for an extended testing phase. There are also some gui fixes which we'll describe in more detail after the release is out. Please try and report issues in this thread to avoid duplicate support issue.
https://forum.gsmhosting.com/vbb/f93...7-21-a-2871556
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post:
Old 07-21-2020, 23:12   #63 (permalink)
Member: 79315
Thanks Meter: 6,024
hi,
MFC Suite 3in1 V3.3 Beta 2 Released
Bugfixes & Changes:
  • Changed the idevice connection handling
  • Changed to read ECID once idevice connected
  • Changed the SSL handshake, now SSL is automatically selected based on iOS version
  • Add display USB or Network under Connection Type (NORMAL, DFU ETC)
  • Some gui bugs fixs
Mega download link:
Updates:
  • After download the update file you need extract the file to c:/mfc folder.
Old 07-23-2020, 08:53   #64 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow
MFC Suite 3in1 V3.3 Beta3 Released
Bugfixes & Changes:
  • Improved FDR timeout issue
  • Improved update /restore function under windows 32bit
  • Improved history loading
  • Improved multi same model device operating in same time
  • Added to detect device UDID in recovery mode for the first attach
  • Solved some bugs when closing the software
Updates:
Software Download:
Old 08-10-2020, 06:01   #65 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC V3.3 Final Official Released ! 2020/8/10
MFC Suite 3in1 V3.3 final Released
Bugfixes & Changes:
  • Implemented libusb and WINUSB working in the same time (Reuqired itunes v12.10.8.5)
  • Improved multiple devices connecting sockets non-blocking
  • Improved Apple watch lockdown pair record handling
  • Improved Apple watch S4/S5 restore / update function by using iBUS S4/5 tool
  • Add Purple diagnostic function free (in extended testing)
  • Fix Various memory leak and deadlock bugs
  • Fix gui bugs
Updates:
  • This update required install full installer version 3.3, The downloaded version of the software is available now from support page with valid membership.
The Following 2 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 08-29-2020, 12:43   #66 (permalink)
Member: 79315
Thanks Meter: 6,024
MFC Suite 3 in1 V3.3.1 Released
Bugfixes & Changes:
  • Improved open software blocked issue for non english windows system
  • Improved restore / update function (For watch S3/S4/S5)
  • Add Skip Verify function (will not verify if the flash file is ok before flashing)
  • Define general flash error code description (E.G. 9,14,27,56 and more)
Updates:
  • This update required install full installer version 3.31, The downloaded version of the software is available now from support page with valid membership.
Old 01-24-2021, 21:31   #67 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 3 in1 V3.4 Beta 1 Released
Updated functions:
  • Updated flashing for newer iPhones up to iPhone 12 models and Watch S5 (including for latest iOS version);
  • Usb drivers are automatically selected based on required operation (changed for example to be able to flash the device after performing a Load Diag); because of this requirement software has to be able to run in Administrator mode in windows to be able to install on the fly new USB drivers;
  • Updated iPR for newest iOS versions;
  • Reorganized the software structure. Now all the MFC Dongle functions are inside the MFC tab.
New functions:
  • Added iMFC only accounts (login with username and password for Flash and Load diag functions).
  • Added new settings area
  • In Settings area (Settings tab) you can edit the username and password for iMFC/MFC
  • Main Server and Backup servers can be selected in case Main Server is offline (after selecting a new server Switch Servers & Restart is required)
  • Login is now separated by login type for iMFC. Logging in using MFC dongle to access all functions must be done in the MFC dongle screen (Login button will display MFC Login and so on). Loggin in with iMFC account (username & password only) can be done in iMFC screen.
  • iMFC tab will display log messages until the client logins to the MFC server.
Added Load Diag function for iPhone 7, up to iPhone X
  • Required usb drivers are automatically selected;
  • Can be used with normal USB cable or with a DCSD cable (don't forget to check if you are using a DCSD cable);
  • If Load Diag fails you need to reset the phone and put it back in DFU mode for each retry;
  • If Load Diag is successfull then a new Com Port will appear on your computer. Sometimes this will require to install USB Serial driver in Control Panel by pressing Update drivers for Apple Mobile Device (VID 05AC PID 1222) phone will be display in WTF DFU state in History screen;
  • Bootchain.diag files must be present in Resources directory in order for Load Diag to function correctly;
  • If com port is available in Control Panel but not displayed in software you can go to History and press Refresh button;
Previous bugs solved:
  • Updated the log display functions that should be faster and more stable now;
  • Improved device detection with different usb drivers in iMFC history;
  • Removed unnecessary error or timeout messages while Upgrading/Restoring flash;
Server:
  • Updated server to support iMFC only login and other login types;
  • Updated server to support Load Diag functions;
  • Updated server to recognize and support latest device models;
  • Added backup server option;
Old 02-10-2021, 07:30   #68 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 3 in1 V3.5 Beta 1 Released
We're very pleased to announce a new release MFC V3.5 Beta
  • Add Com Port Refresh Function
  • Add All Area /Region syscfg Selection
  • Add Backlight testing function
  • Add read Battery All Data function
  • Add read Device Temperature data / Nand Data function
  • Add test function for Compress / Touch / PhotoSensor / Button etc
  • Improved Backup All syscfg Data function
  • Fixed Write Syscfg backup Data function
  • Fixed Driver install for WTF mode
  • Other small bugs fix
  • This update file required install full installer version 3.4 first, after download the update file you need extract the file to c:/mfc folder. The downloaded version of the software is available now from support page with valid membership.
Discussion :
Old 05-03-2021, 18:11   #69 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC 3in 1 V3.53B official released !
We're announce a new release MFC V3.53B
  • Add use Arduino option for diags function (beta ! this will automatic programming Arduino board)
  • Improved apple watch detection
  • Fix Apple watch unknow data request issue
Discussion :
Old 05-27-2021, 03:56   #70 (permalink)
Member: 79315
Thanks Meter: 6,024
MFC Suite 4 in1 V3.6 Beta 1 Released
We're announce a new release MFC V3.6B1
  • Added Watch Load Diag function (Published for S3, MFC or iMFC activation required, iBUS S2 ( Other connectors may not support . Don't use that ) activation required )
  • Added Update RTC Time function
  • Added Syscfg verify backup function
  • Added Syscfg data auto saving in logs function
  • Improved Arduino option working more stable
  • Improved Diag Console function
  • Improved read syscfg function
  • Solved some error when clearing history
Discussion :
The Following 7 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 05-29-2021, 17:14   #71 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 4 in1 V3.6 Beta 2 Released
We're announce a new release MFC V3.6B2
  • Improved Watch Load Diag function by Lightning USB Cable
Discussion :
Old 07-08-2021, 11:13   #72 (permalink)
Member: 79315
Thanks Meter: 6,024
Thumbs up MFC Suite 4 in1 V3.6 Beta 3 Released
Changelogs:
  • Improved USB Detection function
  • Improved Apple Watch Flash / Restore function
  • Update iPOWER X user be able to use iMFC Function
  • This update file required install full installer version 3.4 first, after download the update 3.6B2 file then extract the file to c:/mfc folder. and then download MFC_TestFDR extract the file to c:/mfc folder, run MFC_TestFDR.exe as administrator. The downloaded version of the software is available now from support page with valid membership.
Old 08-29-2021, 10:17   #73 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 4 in1 V3.7 Released
MFC Suite 4 in 1 V3.7 Released
Bugfixes & Changes:
  • Free add Load Diag Function to support Apple Watch Support S1 S2 (iBUS S1 S2 activation required, Other connectors may not support . Don't use that)
  • Improved the diag data load function to be more stable
  • Improved driver issue for restore / update function (Watch)
  • Add support to restore / update the latest iOS version
  • Add support apply a new face changing function for watch
  • iPOWER X Box firmware updated
Updates:
  • This update required install full installer version 3.7, The downloaded version of the software is available now from support page with valid memberships
Discussion:
Old 08-30-2021, 06:01   #74 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 4 in1 V3.7 fix Released
2021/8/30 Changes - V3.7 Fix
  • A quickly fixed version for DFU Driver issue - Cilck To Download MFC_3.7.fix830
  • Required do complete installation through the installer v3.7 first, then download this new fix version extract to C:/mfc
Old 10-16-2021, 06:51   #75 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 4 in1 V3.7.1 Released
2021/10/16 Changes - V3.7.1
  • Bug fixes for your iPhone /iPad /Apple Watch
  • Update to compatible for new iOS version (15+) and new Watch Os version (8+)
  • update support new iPhone models
Discussion : https://forum.gsmhosting.com/vbb/f93...-7-1-a-2991091
Page generated in 0.38627 seconds with 8 queries
