02-12-2015, 23:35 | #2 (permalink) |
Banned Join Date: Oct 2002 Location: Feeding Carrots to useless,,
Member: 16490 Status: Offline Sonork: 100.1621293 Thanks Meter: 908 | If I was you should be cautious as with 2 posts you don't give clear description of your problem. . Invisible member... Their support is 24-7 depending on time zone.. |
02-12-2015, 23:47 | #4 (permalink) |
Member: 16490 Status: Offline Sonork: 100.1621293 Thanks Meter: 908 | So why NOW post here if your email was allegedly sent and ended in the Trash..? Should of posted here first,,, It doesn't matter I see all.. |
02-13-2015, 00:06 | #5 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2146917 Status: Offline Thanks Meter: 0 | Allegedly sent LOL I only post on gsmhosting if no reply is given to me on email there is no reason to post on gsmhosting first when the team can reply back to my email. I have explain everything to MFC top to bottom there is no need to explain again. Just received my dongle used only once then stopped working I would of posted a nice print screen of the issue but the system will not allow me. |
02-13-2015, 03:36 | #6 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,027 | Quote:
So as you said 6 days ago you have send me email ([email protected]), then upload some picture show me you are really send. Br., Denis | |
02-13-2015, 03:50 | #7 (permalink) |
Member: 2146917 Status: Offline Thanks Meter: 0 | I am not sure if you can read "I would of posted a nice print screen of the issue but the system will not allow me." Unfortunately gsmhosting does not allow newbie members to post a link for unknown reason. "An error has occurred unlockcodesuk! You must have 10 posts in order to post links. Your current post count is 3." If you check your email exactly to this date and time you will clearly see a screenshot send from me. Sent: 07 February 2015 17:07:33To: Support (supportmfcboxcom) It is not only me having this issue it seem other members having the same problem |
02-13-2015, 04:06 | #8 (permalink) | |
So i think gsmhosting also very bad, does not allow you post link. Btw, i have not got your email from that time as you said, you can send one more time. Br., Denis | |
02-13-2015, 07:12 | #14 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,027 | Ok , master, can you teach me why that forum user also have the issue ? I told don't post something which you don't know to make user confuse! Next time if you post same thing , i will deleted! BR., Denis Last edited by .::Gsmdenis::.; 02-13-2015 at 07:22. |
