07-06-2021, 12:42 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Test software for watch FDR only 2021/07/06! If you have FDR issue , try to test this version and give report ! Extract zip file to c:/mfc and run as administrator ! https://www.dropbox.com/s/xy3h7hmplu...FC_TestFDR.zip thanks |
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
07-06-2021, 16:42 | #2 (permalink) |
Insane Poster Join Date: Oct 2016 Location: Azerbijan Baku Age: 39
Member: 2642070 Status: Offline Thanks Meter: 15 | [info] Using LOCAL IPSW F:\APPLE WATCH 7.5\MFC_Watch4,2_7.5_18T567_n131bap_GPS_Restore_44 mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131bap, Watch4,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 7.5 [data] Product Build: 18T567 Major: 18 [info] device serial number is G99Y2D4ZKDHD [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 0018e35e1a06002e [info] Getting ApNonce in recovery mode... [data] 93D2B96E5EA58DF386ECD337262BF29D5CD7C51AD9787349C5 136824EF34359A [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] EDC950C30C7C2E918CB80BF8AEBBDEA6A175E288 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch4,2_7.5_18T567_n131bap_GPS_Restore_44mm/018-19609-077.dmg' [info] Found ECID 0018e35e1a06002e [info] Getting ApNonce in recovery mode... [data] 93D2B96E5EA58DF386ECD337262BF29D5CD7C51AD9787349C5 136824EF34359A [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] EDC950C30C7C2E918CB80BF8AEBBDEA6A175E288 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1129125 bytes)... [info] Device ecid 0018e35e1a06002e disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.120.36 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10948 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1786649 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1861453 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1730909 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1735829 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (848101 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-19158-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16358 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20341 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160145 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31700 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-19158-077.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (82714264 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (39639 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5283198 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11752306 bytes)... [info] Device ecid 0018e35e1a06002e disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-0018E35E1A06002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 10 [info] ChipID: 32774 [info] UniqueChipID: 7005392744087598 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Connecting to FDR client at port 49158 [info] FDR 0CA045B8 Proxy connect request to gg.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 08DADC30 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0CA042B8 Proxy connect request to skl.apple.com:443 [erro] FDR 0CA045B8 Unable to receive proxy payload (-3) [info] Connecting to FDR client at port 49158 [info] FDR 0C9B80A8 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0C9B7700 Proxy connect request to skl.apple.com:443 [erro] FDR 08DADC30 Unable to receive proxy payload (-3) [erro] FDR 0CA042B8 Unable to receive proxy payload (-3) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N131B_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N131b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-19158-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 018-19609-077.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [erro] FDR 0C9B80A8 Unable to receive proxy payload (-3) [info] Updating Stockholm (55) [erro] FDR 0C9B7700 Unable to receive proxy payload (-3) [info] Updating Stockholm (55) [info] Status message: Ramrod firmware update failed. Hint: The display of this model is not compatible, or you can replace the NFC module [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [info] Removing USB\VID_05AC&PID_12AF\00008006-0018E35E1A06002E [erro] Could not read data (-256). Aborting. [erro] Unable to restore device [done] Operation finished! [info] Using LOCAL IPSW F:\APPLE WATCH 7.5\MFC_Watch4,2_7.5_18T567_n131bap_GPS_Restore_44 mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131bap, Watch4,2 [info] Extracting BuildManifest from ipsw [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Could not establish conenction with server! Aborting! Firmware file might be corrupt. Unable to extract BuildManifest from F:\APPLE WATCH 7.5\MFC_Watch4,2_7.5_18T567_n131bap_GPS_Restore_44 mm.ipsw. [done] Operation finished! [info] Using LOCAL IPSW F:\APPLE WATCH 7.5\MFC_Watch4,2_7.5_18T567_n131bap_GPS_Restore_44 mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S4, n131bap, Watch4,2 [info] Extracting BuildManifest from ipsw [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [erro] Connecting to host instance 0 using TCP problem port 9430!WSA code: 10061 - Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. [data] Product Version: 7.5 [data] Product Build: 18T567 Major: 18 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 0018e35e1a06002e [info] Getting ApNonce in dfu mode... [data] 101F4141909DB49879984147516DB22DA4B2424BF39708F385 5ABA92F4F6EE37 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] E6BDDDAA0C3858959495E1678136A0EFA648EB70 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch4,2_7.5_18T567_n131bap_GPS_Restore_44mm/018-19609-077.dmg' [info] Found ECID 0018e35e1a06002e [info] Getting ApNonce in dfu mode... [data] 101F4141909DB49879984147516DB22DA4B2424BF39708F385 5ABA92F4F6EE37 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] E6BDDDAA0C3858959495E1678136A0EFA648EB70 [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting iBSS.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (1129125 bytes)... [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 0018e35e1a06002e disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Found device in Recovery mode [info] Noce: 10 1f 41 41 90 9d b4 98 79 98 41 47 51 6d b2 2d a4 b2 42 4b f3 97 08 f3 85 5a ba 92 f4 f6 ee 37 [info] Extracting iBEC.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1129125 bytes)... [info] Device ecid 0018e35e1a06002e disconnect detected! [info] device serial number is G99Y2D4ZKDHD [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-6723.120.36 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10948 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1786649 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1861453 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending ANE (1730909 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending AOP (1735829 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending GFX (848101 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-19158-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (16358 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending SCE (20341 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160145 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (31700 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-19158-077.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (82714264 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (39639 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (5283198 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11752306 bytes)... [info] Device ecid 0018e35e1a06002e disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-0018E35E1A06002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 10 [info] ChipID: 32774 [info] UniqueChipID: 7005392744087598 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Waiting for NAND (28) [info] Updating NAND Firmware (58) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checking for uncollected logs (44) [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Connecting to FDR client at port 49158 [info] FDR 0C9B78C8 Proxy connect request to gg.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0C9B7400 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0CA01330 Proxy connect request to skl.apple.com:443 [erro] FDR 0C9B78C8 Unable to receive proxy payload (-3) [info] Connecting to FDR client at port 49158 [info] FDR 0CA03298 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0CA03460 Proxy connect request to skl.apple.com:443 [erro] FDR 0C9B7400 Unable to receive proxy payload (-3) [erro] FDR 0CA01330 Unable to receive proxy payload (-3) [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting BT_FW_m9.im4p... [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Extracting wifi_armv7r_m9_rtkit_image.im4p... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Extracting h11_ane_fw_mercury.im4p... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Extracting aopfw-watch4aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting armfw_g11m.im4p... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Extracting N131B_LeapHapticsFirmware.im4p... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Extracting N131b_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 018-19158-077.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting scefw.im4p... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Extracting SmartIOFirmware_ASCv2.im4p... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Extracting 018-19609-077.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [erro] FDR 0CA03298 Unable to receive proxy payload (-3) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [erro] FDR 0CA03460 Unable to receive proxy payload (-3) [info] Updating SE Firmware (59) [info] Extracting Stockholm5.RELEASE.sefw... [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Sending SE TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] Received SE ticket [info] Sending FirmwareResponse data now... [info] Done sending FirmwareUpdater data [info] Unknown operation (81) [info] Connecting to FDR client at port 49158 [info] FDR 08DAD930 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 08DAD4F8 Proxy connect request to skl.apple.com:443 [info] Creating Protected Volume (67) [erro] FDR 08DAD930 Unable to receive proxy payload (-3) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch4... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n131b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@448~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n131b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n131bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@448~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting WirelessPower.watch4.im4p... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Extracting iBoot.n131b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n131b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Fixing up /var (17) [info] Creating system key bag (50) [erro] FDR 08DAD4F8 Unable to receive proxy payload (-3) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Requesting EAN Data (74) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] Removing USB\VID_05AC&PID_12AF\00008006-0018E35E1A06002E Gooood Denis THK |
The Following User Says Thank You to rzayeff200 For This Useful Post: |
07-06-2021, 16:59 | #3 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Looks working great :-), thanks for report | |
07-07-2021, 16:31 | #4 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1144374 Status: Offline Thanks Meter: 64 | Now flashin complete: [info] Using LOCAL IPSW C:\MFC_Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_6. 3_17U208_restore.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 6.3 [data] Product Build: 17U208 Major: 17 [info] device serial number is FHLTJ4WCHDXV [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 00025cda10f1a326 [info] Getting ApNonce in recovery mode... [data] 8A82F76DD4AD4E9A1BAC02AE3C10851078204812CDEEDCB885 85F73E8CB38BC8 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 60FE4B62798C277ADB35F8C531D01463F98BFF2C [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,7_n28dap_42mm_Watch2,4_n75ap_42mm_6.3_1 7U208_restore/038-87845-009.dmg' [info] Found ECID 00025cda10f1a326 [info] Getting ApNonce in recovery mode... [data] 8A82F76DD4AD4E9A1BAC02AE3C10851078204812CDEEDCB885 85F73E8CB38BC8 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 60FE4B62798C277ADB35F8C531D01463F98BFF2C [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (747975 bytes)... [info] Device ecid 00025cda10f1a326 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-5540.144.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (8706 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 038-87586-010.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (13743 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 038-87586-010.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (67956485 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (110731 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2103233 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (11149214 bytes)... [info] Device ecid 00025cda10f1a326 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 97f795a62d913bbc02bcefd4f3ded45f616999ba has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 665041610318630 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [erro] TZ0RequiredCapacity: 0x600000 [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [info] Waiting for NAND (28) [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n75.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Connecting to FDR client at port 49158 [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checking filesystems (15) [info] Creating Protected Volume (67) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] About to send KernelCache... [warn] No path for component KernelCache in TSS, will fetch from build identity [info] Extracting kernelcache.release.watch2... [info] Personalizing IMG4 component KernelCache... [info] Sending KernelCache ... [info] Done sending KernelCache[info] Installing kernelcache (27) [info] About to send DeviceTree... [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Sending DeviceTree ... [info] Done sending DeviceTree[info] Installing DeviceTree (61) [info] Connecting to FDR client at port 49158 [info] FDR 0988A520 Proxy connect request to gg.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 098AF668 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 098891B8 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 098892D8 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0E200038 Proxy connect request to skl.apple.com:443 [info] Flashing firmware (18) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Extracting aopfw-m8aop.im4p... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Extracting N75_Multitouch.im4p... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Extracting rtpfw.im4p... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Extracting 038-87586-010.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Extracting 038-87845-009.dmg.trustcache... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [erro] FDR 098AF668 Unable to receive proxy payload (-3) [erro] FDR 098891B8 Unable to receive proxy payload (-3) [erro] FDR 098892D8 Unable to receive proxy payload (-3) [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component StaticTrustCache [info] Sending IsFUDFirmware image list [info] Updating SE Firmware (59) [info] Connecting to FDR client at port 49158 [info] FDR 0E1E6CF8 Proxy connect request to skl.apple.com:443 [info] Connecting to FDR client at port 49158 [info] FDR 0E1E6DD0 Proxy connect request to skl.apple.com:443 [erro] FDR 0E1E6CF8 Unable to receive proxy payload (-3) [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Connecting to FDR client at port 49158 [info] Modifying persistent boot-args (25) [info] Unmounting filesystems (29) [info] Status message: Restore Finished [info] Cleaning up... [done] Done [done] Operation finished! [info] device disconnect... [info] device arrival... new [info] device disconnect... |
