Help remove nand (HDD) Hello, I need help, i remove sucess hdd ipad air2 but i lost 3 capacitor arround HDD.... I trying put back but is soo dificult ... Any one have a another solution ? https://s27.postimg.org/ynxnviz4j/image.jpg Thank you |
use soldering iron with tiny tips you need
If the caps are broken. You can proceed with your Nand Reball and installation. It should work without those caps. Anyways you can replace them afterwards. I know its not good to not solder back the Caps but sometimes i do leave them unsoldered. And it works. But it's just what i do.... You can definitely buy a Microscope and solder back those caps on... :D Hope that helps. |
Check the schematics for it! (if somenone has them for ipad air 2 :P ) |
Whats the kapton tape for ?, kaptop tape isnt a heat shield, it wont protect the cpu from being overheated, its not a heatsink. I can reflow small ic's through kaptop tape, so it pretty much does nothing to stop heat. |
