01-14-2017, 00:52 | #1 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2484073 Status: Offline Thanks Meter: 14 | Help remove nand (HDD) I need help, i remove sucess hdd ipad air2 but i lost 3 capacitor arround HDD.... I trying put back but is soo dificult ... Any one have a another solution ? Thank you |
01-14-2017, 12:45 | #3 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | If the caps are broken. You can proceed with your Nand Reball and installation. It should work without those caps. Anyways you can replace them afterwards. I know its not good to not solder back the Caps but sometimes i do leave them unsoldered. And it works. But it's just what i do.... You can definitely buy a Microscope and solder back those caps on... Hope that helps. |
01-16-2017, 09:03 | #4 (permalink) | |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Quote:
Check the schematics for it! (if somenone has them for ipad air 2 :P ) | |
01-25-2017, 13:05 | #5 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2652992 Status: Offline Thanks Meter: 1 | Whats the kapton tape for ?, kaptop tape isnt a heat shield, it wont protect the cpu from being overheated, its not a heatsink. I can reflow small ic's through kaptop tape, so it pretty much does nothing to stop heat. |
